3dPrinted Ring Light
1,638
40
Published
Introduction: 3dPrinted Ring Light
About: radom diy projects
build a nice and easy ring light for your dslr camera
Step 1: .stl Files
after many shapes in tinkercad, i made 4 .stl files
the first file is for my pendax k-50 for 18-55 lenses.remake this for your dslr if needed
the diameter of the ring is 140 mm
Step 2: Instand Glue
add instand glue carefully like the pics
Step 3: Dimentions
check the dimentions for the next step
Step 4: I Dont Have Black Meterial
i dont have black meterial to use and i paint it
Step 5: White Sheet
make two cicles like the pic and cut the plastic white sheet with scissor
THOSE METERIALS ARE FROM A 20CM-18W-220V LED LIGHT
Step 6:
glue like the pics, the plastic sheet
Step 7: The Leds
i use led strip 14.4 watts per meter, cool white
cut carefully the one edge like the pics (check from the fist if it still works)
Step 8: Add the Leds
before you take of the paper from leds make sure if are fits nice
negative outside , +12 inside
Step 9: Sodering
solder naked wires or use white cables
Step 10: Test
test it before next steps
Step 11: Reflector
like the pics make one or print one with white meterial
...i don't make .stl file for this...
Step 12: Connector
make a hole at a nice point for the cable, i secure this with some instant glue
TEST IT AGAIN
Step 13:
glue the two rings with the reflector and with the leds
Step 14: Its Ready
this works with 12 v
if you want you can find a DC to DC converter 5v to 12v to use it with a power bank
Step 15: End
FOLLOW ME HERE
AND SUBSCRIBE TO MY YOUTUBE CHANNEL !!!
THANKS !!!
    • Make it Move Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    3 Comments
    Nice instructable and thanks for sharing :)
    A Nice Project.
    What 3D Printer can you recommend? Under 1000$. Is it possible
