Bed With No Screws or Glue (160 X 200 Cm)
1,668
24
Posted in WorkshopFurniture
Introduction: Bed With No Screws or Glue (160 X 200 Cm)
About: Welcome to my profile, please check my YT and Facebook channel to see what I create.
Hello,
In here you will get a few steps on how to build a very easy to make bed without using a single screw or a dab of glue. You're more than welcome to see my video on youtube with the build.
The whole bed stands on four 12x12 cm logs, 2 on one side, 2 on the other, with cut out grooves for 14 lets call them '2x4s' that are actually 4x7cm here.
YT vid: https://www.youtube.com/watch?v=XvXq7hOCKlw
Step 1: Collect the Materials
For the base I used 4 logs 12x12cm
For the mattress support I used 14 pieces 200 cm long that were sturdy enough to hold my weight when standing on them separately.
Step 2: Mark the Router Paths
Next I have marked all the marks on the base logs to cut out for the longer pieces.
You probably should use some guide for your router to make the grooves perfect.
I did not since it was my first time using a router and I really wanted to get to know it better.
Step 3: Cut the Longer Pieces
Using a stopblock and a miter saw I have cut the longer pieces to exactly the same size with a miter on 1 side.
Then I eased out the edges with a file.
The final dimension was just so the timber would sit hidden 2-3cm under the mattress, so it can't really bother you when you stand up from the bed or want to 'fall' on it
Step 4: Cut the Base Log to Lenght and Sand Everything.
Cut the base parts with a miter saw or a hand saw (my miter saw was too small for them)
Sand everything as much as you want. I just roughly sanded every piece so it wouldn't have any unpleasant areas. You can just leave it rough if it doesnt bother you.
Step 5: Assemble the Bed
When everything is cut and finished nicely just assemble the pieces and put your mattress on.
The assembly takes only a couple minutes and doesn't require any tools or more people.
I have slept on it for over 6 months now and it hasn't moved a bit. The base logs aren't screwd to each other either, they just lay one on another freely.
I found this design somewhere on Pinterest. If you can find it - let me know so I can contribute that person as well in here.
More details in the video:
Show me how it turned out for you and enjoy your bed!
Karaon
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    2 Comments
    Awesome! Make sure to plan the height right, so kids can store something underneath ;) I made mine slightly higher than the Ikea storage boxes, but suit your needs.
    Cheers
