Introduction: Carter's Lasercut Iris Box V2
Picture of Carter's Lasercut Iris Box V2
Hello ! this is the instruction of the iris hinge assembly for my lasercut iris box.
You can download it on Thingiverse : https://www.thingiverse.com/thing:2704046
For one box, you will need :
  • x5 M3 10mm screws,
  • x5 M3 12mm screws,
  • some wood glue.
In this instructable, i will make a small model for example.
Step 1: Organize the Layers
Picture of Organize the Layers
There are four layers for the hinge :
  1. The rotating top,
  2. The petals,
  3. The rails part,
  4. The spacers (just here to have a nice length for the screws) .
Step 2: The Petal Hinges
Picture of The Petal Hinges
Align and glue the 5 spacers on the holes of the rails part. Screw the 10mm screw in there. There is 4mm of screw that are poking out, it will be used to make the petals pivoting.
Step 3: Fix the Rotating Top
Picture of Fix the Rotating Top
Add the 12mm screws on the curved rails up to the holes of the rotating top. don't screw it entirely, leave some space, so it can slide without be stucked.
Step 4: The Box
Picture of The Box
Put all the slats on the bottom.
It may be difficult, so be patient. Don't forget not to put glue next to the rails, it could stuck the mechanism.
Well done ! your box is nox finished ! Make sure to open/close your box a few times at the beginning to unstuck it.
Waste Of Space (author)2017-12-12
So where are the DXFs for making one of these?
akcoder (author)Waste Of Space2018-01-13
They are on thingiverse
jrobins43 (author)2018-01-09
To assemble the slats I lined them up against a straight edge then taped them all together with masking tape. That makes it much easier to get the slats installed in the bottom and top assembly. Great project i like how these look and operate thanks for sharing.
subnet (author)2017-12-12
Really great, thanks for sharing!
Is the wood 3mm? I hope so, my laser can't cut more than this :-)
AlanP116 (author)subnet2018-01-06
the wood is 3mm as the length of screw is 10 mm and three layers of MDF was added with a 1mm excess this means that the thickness of the MDF is 3mm
wonderkid64 (author)subnet2017-12-12
try multiple passes
JackCarter (author)subnet2017-12-12
exactly !
shatrovmaxim (author)2017-12-12
Excellent!!!
About This Instructable
6,152views
146favorites
License:
Bio: I love lasercut. I love tanks. Let's conciliate dis.
More by JackCarter:Carter's Lasercut Tank - ShermanCarter's Lasercut Iris Box V2Carter's Lasercut Tank - StuG III Ausf. F
Add instructable to:
