Creeper Keychain
1,209
6
5
Posted
Introduction: Creeper Keychain
Epilog Challenge 9
This is an entry in the
Epilog Challenge 9
Minecraft Challenge 2018
In this Instructables I'm going to show you how to model a creeper keychain for 3d printing in fusion 360.
Hope you enjoy!
Step 1: Making a Box
The first step is to create a sketch do so by going un SKETCH-> Create Sketch. Then select one of the 3 planes it shows in orange. With the line tool (which you can also find under the sketch tab or the hotkey for it is L) sketch a 8mm by 8mm box.
Step 2: Sketching the Face
Zoom out so the squares on the grid are 1mm big so 1 mm = 1 pixel. Then start sketching the face with the line tool.
Step 3: Extruding It
Go under CREATE -> Extrude select all the faces and extrude them 8mm.
Step 4: Unhide the Sketch
When you extrude a part from a sketch it hides the sketch. To show the sketch again in the top left corner click the arrow by Sketches, then show it again by clicking on the light bulb.
Step 5: Extruding the Face
Go under CREATE -> Extrude then select the eyes and mouth of the creeper sketch, and move them 1mm into the box with the operation cut.
Step 6: Scaling It
The head is only 8mm big (about .3 inches) so let's change that. To scale it go under MODIFY -> Scale then scale it by a factor of 3.
Step 7: Adding a Bevel
To make it look better you can add a bevel. To do this go under MODIFY -> Chamfer then select all the outside edges of the cube and input 2mm for the distance.
Step 8: Starting Keychain Hook
Start a sketch on opposite side to the face, then in a corner use the line tool to mark out 2mm on both sides of the bevel.
Step 9: Marking Points
From those points draw a line 45°(or 135°depending on what corner you picked) down to the inner square.
Step 10: Forming the Shape
Then make the line come out by 6mm on both sides. Connect the 2 ends next.
Step 11: Extruding It
Extrude that shape toward the face by 2mm.
Step 12: Add a Fillet
With the fillet tool (which can be found under MODIFY -> Fillet) Make the edges close to a semicircle. This doesn't have to be perfect.
Step 13: Make a Circle
Make a sketch on the surface of the keychain hook then roughly in the middle make a circle by going under SKETCH -> Circle -> Center Diameter Circle.
Step 14: Cut the Circle Into It
Extrude that circle sketch into the surface with the operation cut.
Step 15: Turning It Into a STL
Now that it's done you need to turn it into a STL file to be able to print it. To do this go under MAKE -> 3D Print
Click on the model then in the box that popped uncheck Send to 3D Print Utility.
Step 16: 3D Print and Enjoy
Now all it needs is to just be be printed! Hope this helped.
Feel free to ask questions if you have any and I'll try to answer them the best I can.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
1 Questions
what if it explodes?
Nice! I think the beveled edges are a nice touch, too!
