Custom Cut Coin Necklaces
15,516
241
49
Posted
Introduction: Custom Cut Coin Necklaces
Homemade Gifts Contest 2017
First Prize in the
Metal Contest 2017
Grand Prize in the
Metal Contest 2017
Epilog Challenge 9
Runner Up in the
Epilog Challenge 9
THIS INSTRUCTABLE IS BEING SHOWCASED IN "METALS CONTEST" AND "HOMEMADE GIFTS CONTEST," IF YOU LIKE IT, VOTE FOR IT!
I got the inspiration to use coins three years ago when I was in high school. It was my girlfriend's birthday the next day, and being the procrastinator that I was (and always will be :P), I hadn't considered her birthday gift yet! In panic mode, a quarter was the easiest necklace material to come by. Not the most glamorous of metals, but hey, It worked <3. Lets hope she doesn't see this Instructables..... :')
In this Instructable I show you how you can make your own cut-coin pendants and interlocking necklaces with a few specific tools and others you might already have as a DIYer. This is a great way to impress anyone, its a truly versatile type of gift! We've all had the struggle of not knowing what to get someone besides a gift card. This is something not many people have seen before., so an investment in cutting tools will allow you to make gifts for people for the years to come. Slap on a key chain, or a necklace, OR a bracelet and give it to a special him or her. This gift will showcase not only your creativity and aptitude, but your attention to detail and exquisite dexterity.
Ready?
Step 1: Materials
The following links show examples of what you could (but are not limited to) use:
Step 2: Create a Cut Pattern From an Image
Possibilities are endless when it comes to choosing a pattern to cut. In this instructable I'll show you how to make a cutting pattern from almost any image on google. Preferably one with a white background. If you want to skip straight to the cutting without worrying about making a custom pattern, check out the final step where you will find some premade patterns.
If you found a silhouette online that suits your needs:
  • Import the silhouette to Photoshop
  • Skip to the step where the elliptical marquee tool is used to crop the silhouette
  • Proceed through the steps to resize the image and print it out (I recommend printing out multiple copies of the pattern in case you make a mistake and need to start again)
Now, import the photo into Adobe Photoshop, or any other image editing software of choice (Gimp, Inkscape, MS Paint, even PowerPoint works for this project). The idea is to silhouette the image so that we have a solid border to cut along when we print out the pattern.
To silhouette the image adjust the threshold of the image until it is a solid silhouette:
top menu > image > adjustments > threshold
Pick a notable part of your silhouette to pattern. In this case I want to make a necklace of the dog's head, so I will use any of the three Lasso tools to cutout the head.
toolbar > lasso > polygon lasso tool
Next, we need to isolate our selected region. To do this:
right click on region whilst still using the lasso tool > new layer via cut
You will notice that a new layer has been created in the "layers" window. If you don't see the layers window:
top menu > window > layers
To delete everything but the selected region, we need to delete the background layer. To do this, unlock the background by clicking on the lock icon in the layers window. Then hit delete.
Right now, the isolated region is just "floating in space." In order to tell Photoshop we want to keep this region:
right click on the layer in the layers window > Flatten layer
This pattern is enough to get started with. To take this project to the next level, you can consider cutting out different cavities within the solid as well as refining the contours of the pattern using the brush tools:
toolbar > brushes > Brush tool
To change the color of the brush to white (if it isn't already white)
hold Alt Key + click in a white area to "copy" the color into the clipboard
When drawing internal cavities, consider having a smooth contour without sharp kinks and corners (sharp corners are difficult to cut around without the risk of twist snapping the blade which may get caught in the corner).
Pro-tip, ensure that the corner radius is at minimum, equal to the "diameter" of the saw blade). I won't bore you with the details of refining contours and drawing cavities, but this is the final pattern I came up with (for download at the end of this instructable):
Now we need to resize this image so that it prints to the correct size (the size of a quarter, or another coin). The diameter of a quarter is 0.955 inches, so this is what we will use. First, using the elliptical marquee tool, draw a circle around your pattern -- centering the pattern with the top and bottom edge just contacting the edges of the circle
Toolbar > marquee > elliptical marquee tool
to crop the current artboard to the size of the pattern:
top menu > image > crop
this will crop out everything, leaving the enclosed region of the circle:
We now size the image to fit within the edges of a quarter with diameter 0.955 inches:
top menu > image > image size
Input 0.955 inches into both the height or width boxes -- ensuring the chain link is broken to break the aspect ratio lock.
If you're using Photoshop, you can print directly:
top menu > file> print
Double check to see that the pattern size small relative to the letter sized paper. Doing this ball park check, will prevent you from accidentally wasting ink on a full sized pattern.
Step 3: Prepare the Coin for Cutting
It's time to overlay our pattern on the coin. First, cutout the pattern. It doesn't need to be a clean cut, as excess paper surrounding the pattern will give the pattern more surface area to stick to the coin. Apply a liberal amount of stick glue and quickly dry it with a heat gun or a blow dryer. As the glue dries and contracts, it pulls the paper tightly against the coin, which helps the paper from peeling off due to the oscillatory motion of the saw that is to follow.
Next, cut a "V" notch about an inch long and half an inch wide on the edge of a wooden board. The board can be anywhere from 1/4"-1" ideally. The purpose of this notch is to give the sawblade room to move while still giving the craftsman a supporting platform to hold down the coin.
Now, clamp down the coin over the V-notch with a pair of vise grips. We'll need to drill small holes in the coin where the cavities will eventually be cut out. These holes are necessary for the saw blade to be threaded through. Below is a diagram with hypothetical drill points depicted by red dots
Drilling Tips:
  1. DO Use very light pressure when drilling metal coins.
  2. DON'T Push too hard. This can over torque the bit and snap it in half. DO handle this drill bit as you would a piece of 0.5 pencil lead.
  3. Use a center punch to make a pilot hole. This will prevent the drill bit from wandering around the surface of the coin.
  4. After you drill through, DO remain calm. Pulling the drill bit back out is often when it breaks. Slowly pull the drill bit back out, perpendicularly to the face of the coin. Do this while the dremel is still on to reduce the friction between the hole and the bit.
Below, you can see some holes drilled where the cavities would later be cut out. It doesn't hurt to drill extra holes. DO remember to prolong the life of your drill bit with cutting oil. Broken drill bits = frustration (Trust me!)
Next, feed the hair-thin saw blade through the hole. Reattaching the ends of the saw blade to the saw. I forgot to document this step before cutting part of the coin, but the following should get the point across.
To learn how to use a jewelers saw, refer to this instructable. It goes into detail about how to use the "V" notch base, as well as proper blade mounting. Essentially, we want the blade teeth to be facing down so that the cutting stroke is a pull downward with gravity. This makes for a smoother cut and less likely to snap the thin blade.
Now you may begin to cut along the inside edge of the cavities. A diagram below depicts one potential route to take, when cutting out all the cavities.
When starting a cut from a pilot hole, remember that you don't need to make one continuous perimeter cut. You can make a cut, return to the pilot, and begin a cut in a different direction. Below are diagrams to demonstrate this:
The latter cutting approach takes slightly more time but is easier to do and reduces the chance of breaking a blade while taking a corner. The latter approach keeps the blade traveling in a straight/semi-straight trajectory -- reducing torsional load on the blade. As you cut and travel along a curved trajectory, lift and turn the coin to reposition it on the V-notch.
Step 4: Cutting the Coin
Now you can add a drop of vegetable oil or cutting oil to the blade using a cotton swab, and begin cutting. Do not add any oil to the coin itself. This may cause the pattern to come off the coin. Remember to:
  • Use constant up and down strokes when cutting
  • Apply even pressure as the blade glides through the coin to prolong the lifespan of the blade by wearing each tooth on the blade an equal amount per pass
  • Keep in mind that the saw doesn't cut in the reverse direction, so remember to
  • Ease off on the pressure for the up stroke
  • Reapply even pressure on the down stroke
  • Add more cutting oil when a more distinct grinding noise begins, or when you feel more resistance (some of the cutting oil is taken away by the falling dust).
  • Keep your strokes as collinear as possible to avoid bending the blade which can lead to snapping
Below, is a diagram for one potential cutting path you can take. You can technically start anywhere and connect the dots depending on where you drilled your holes.
  1. If you choose to take the perimeter cutting approach, here's the strategy for going around sharp corners:
  2. As you approach the root of the corner, maintain a consistent up and down motion in place
  3. As you continue to oscillate up and down in place, slowly rotate the saw blade about the corner (WHILE MAINTAINING up and down strokes).
As you turn the blade, the sides of each tooth will carve a very small circular profile in the corner, allowing you to take the corner without twisting the blade. Repeat this process for each cavity - working your way from the center out. DO NOT cut the outermost profile first, you won't have anything to hold onto. Finally, after cutting out each cavity, cut the outermost profile of the entire pattern until you're left with the above solid.
Just like filing your nails, you can use a pair of mini files to deburr the sharp edges left behind by the jewelers saw blade. To be more precise, use a conical, pointed diamond coated rotary bit:
Step 5: Finishing Touches
Once you're satisfied with your work, you can link it to a necklace chain with a ring. I typically use 6 mm rings because they're large enough to have some play when looped around the chain, but also small enough to not outshine the pendant itself.
VOILA! You just made a one of a kind necklace! (Aside from the one I made). Feel free to use any of the patterns I provided. If you have any questions, let me know where you're stuck in the comments below! I appreciate all of the feedback!
Step 6: Pattern Files
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    Just so long as you don't try to pay for something with this necklace you should be fine. Awesome project.
    4 Questions
    Hi I was just wondering whether you would think of making (and selling) one of these to me? Either with a custom design or one of your prior ones.
    love this project how long did it take to master
    how old can you be to learn it? Does it take a long time to learn?
    is this hard? How long did it take you to learn? How old must you be?
    36 Comments
    looks good...Just be careful cutting or distorting American money without permission is illegal
    This is one of those things where many believe that's the case, but it isn't true. It comes up all the time with coin rings I've made and even with all those penny presses at various places. It's only illegal for fraudulent purposes, like trying to pass of a silver coin as gold or a quarter as an SBA dollar, etc. Here is the part of the US code that states while not encouraged, there are no sanctions or penalties.
    Section 331 of Title 18 of the United States code provides criminal penalties for anyone who “fraudulently alters, defaces, mutilates impairs, diminishes, falsifies, scales, or lightens any of the coins coined at the Mints of the United States.” This statute means that you may be violating the law if you change the appearance of the coin and fraudulently represent it to be other than the altered coin that it is. As a matter of policy, the U.S. Mint does not promote coloring, plating or altering U.S. coinage: however, there are no sanctions against such activity absent fraudulent intent.
    I thought so at first too, but as long as there is no fraudulent intent*
    (18 U.S.C. §331)*
    great instructable!
    So beautiful !!!
    Congrats ! You made it...into the finals.
    Really nice! Voted
    This is awesome (searching through the couch) haha I got one well it's not shiny but it will do!
