DIY Portable LED Panel
28,458
230
13
Published
Introduction: DIY Portable LED Panel
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to create a powerful and robust 70W LED panel that can be powered by a Li-Ion or Li-Po battery pack. The control circuit can dim the pure white and warm white 5630 LED strips individually and does not cause any flicker problems due to the fast pulse frequency. Let's get started!
Step 1: Watch the Videos!
The two videos give you a basic understanding on how to create the portable LED panel. In the next steps though, I will give you additional information to make this project even simpler to recreate.
Step 2: Build the Frame!
The first video was all about the mechanical build of the LED panel. You can recreate my design by following the guidelines and measurements mentioned in the video. Feel free to also use the attached reference pictures of my panel. You will need the following materials to complete the mechanical build:
Ebay:
10m 5630 LED Strip (Germany): http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
10m 5630 LED Strip (Worldwide): http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
300x400x2mm Aluminum Plate (Germany): http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1000x1x2cm Aluminum Flat Bar (Germany): http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.com:
5m 5630 LED Strip Warm White: http://amzn.to/2lYb2J5
5m 5630 LED Strip Pure White: http://amzn.to/2lIPwXK
Amazon.de:
5m 5630 LED Strip Warm White: http://amzn.to/2lnctgR
5m 5630 LED Strip Pure White: http://amzn.to/2lnmVoA
Hardware Store:
Screws & Nuts (as shown in the video), acrylic glass, aluminum plate, aluminum flat bars, handles
Step 3: Order the Electrical Components!
Here you can find a parts list with example sellers for the components that you will need for the dimmer circuit.
Ebay:
1x Buck/Boost Converter:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x XT60 Connector: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Balance Connector:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x TLC555: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x TC4420 MOSFET Driver IC: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x IRLZ44N MOSFET: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x PCB Terminal: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x DC Jack: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
4x 47µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 100nF, 2x 1nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
4x 1N4148 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 50kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 10Ω, 2x470Ω Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x DPDT Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LiPo Voltage Tester: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.com:
1x Buck/Boost Converter: http://amzn.to/2n2asa1
1x XT60 Connector: http://amzn.to/2mTdajb
1x Balance Connector: http://amzn.to/2mTiwLi
2x TLC555: http://amzn.to/2n2j14N
2x TC4420 MOSFET Driver IC: http://amzn.to/2lNW5Gn
2x IRLZ44N MOSFET: http://amzn.to/2m7UZ9u
3x PCB Terminal: http://amzn.to/2mTnJmn
1x DC Jack: http://amzn.to/2lsV7TQ
4x 47µF Capacitor: http://amzn.to/2lsRMUK
2x 100nF, 2x 1nF Capacitor: http://amzn.to/2lsRMUK
4x 1N4148 Diode: http://amzn.to/2lsKbFS
2x 50kΩ Potentiometer: http://amzn.to/2mH1MtJ
2x 10Ω, 2x470Ω Resistor: http://amzn.to/2lsGIqt
1x DPDT Switch: http://amzn.to/2n247M7
1x LiPo Voltage Tester: http://amzn.to/2mTjCXq
Amazon.de:
1x Buck/Boost Converter: http://amzn.to/2n22NIW
1x XT60 Connector: http://amzn.to/2lbVsGx
1x Balance Connector: http://amzn.to/2n25lqB
2x TLC555: http://amzn.to/2gCxOTT
2x TC4420 MOSFET Driver IC: http://amzn.to/2n2byTi
2x IRLZ44N MOSFET: http://amzn.to/2hiGVqx
3x PCB Terminal: http://amzn.to/2lNNW4H
1x DC Jack: http://amzn.to/2kHaG8v
4x 47µF Capacitor:http://amzn.to/2n2kUyp
2x 100nF, 2x 1nF Capacitor: http://amzn.to/2hlE012
4x 1N4148 Diode: http://amzn.to/2eRqlNs
2x 50kΩ Potentiometer: http://amzn.to/2n2cd7e
2x 10Ω, 2x470Ω Resistor: http://amzn.to/2aAsWdV
1x DPDT Switch: http://amzn.to/2n2nd4s
1x LiPo Voltage Tester: http://amzn.to/2n29Cub
Step 4: Build the Circuit!
Here you can find the schematic of the control circuit as well as reference pictures of my circuit.
Step 5: Print the Enclosure!
Here you can download the design of my housing for123D Design. Import it with the software and export is as a STL file in order to slice it with your favorite 3D printing software.
Step 6: Success!
You did it! You just created your own portable LED panel!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    13 Comments
    Nice! But would be nice to make one more lesson only about dimmers.
    Hi, why did you use a mosfet driver instead of connecting the mosfet directly to the IC555?
    Wow, I have a lot to learn
    sugestion use rubber gromets in the hole you drilled for the wires.
    Or just like this scotty!!!
    what do you think Teacher Scott.gr from a long time subscriber from holland, your neighbour.
    WannaDuino
    IMG_20161005_200755.jpgIMG_20161005_201009.jpgIMG_20161006_204322.jpgIMG_20161031_215908 - kopie.jpgIMG_20161119_032008.jpgIMG_20161121_231837.jpgIMG_20161121_233744.jpg
    I didn't see the username at first but when I read "Let's get started!" I immediately knew who it was! I love your videos and instructables, keep up the good work!!
    Great project.! I have built several of your battery packs for other projects. They work very well. I would like to build this one. Could you please make available the .STL files to save me the trouble of re-designing the enclosure?
    Thank you for sharing your project.
    You've used buck/boost converter with the maximum output current of 5A, while the maximum circuit current is slightly higher and reaches 6A.
    So I have a question regarding the converter. Is the maximum current specified for the maximum working voltage of 35V, or it does not depends on voltage and you use it with overload?
    Cool device. I made something similar with WW/CW on the same ribbon in 24V with an Arduino Nano, a pot for balancing (a real balance as in stereos) another for dimming. Here, there's no need for the drivers, the 555 can deliver far more than needed by the mosfet inputs. There's nomore need for the converter, the 555 can work up to 15V. eventually a small regulator could be add to stabilize fequencies, even if this is not important, only cyclic ratio counts and it doesn't depend on the voltage stability.
    Very clean work and awesome project!
    Sounds reasonable considering it has 2 handles.
    Was there a specific reason for why you chose LED strips, and not something like those 10-100W COB chips? Because with LED strips it can be flat, unlike a huge heatsink that would be needed for a big COB chip?
    Awesome project!
