Edible Plastic Pouches
10,691
145
36
Published
Introduction: Edible Plastic Pouches
About: Inspired by my cat Chili, who is full of fun and energy, I like to share about food and other home crafts with a new twist of 'chili'-fun. (This user was previously called Snowball10)
I have the most amazing life hack for you guys!
Have you ever tried being on a hike and trying to stuff a handful of trail mix into your mouth, hands dirty and all, while dropping way too much of the precious nibbles along the way? Or have you tried letting the kids eat snacks in the car and then found half of it scattered all over the back seat afterwards?
I have the perfect solution! Welcome: edible plastic pouches containing trail mix (or whatever else you like)! They are perfectly pocket-sized and spill-free.
Gone are the days when edible plastic was only a fun and tasteless decorating addition on fancy cakes. Now, this science hack can actually be used for something useful.
The idea behind this edible plastic is actually quite simple. First, we gel water using agar or gelatine, and then, this gel is dehydrated to create an edible, plastic-like sheet that can be used for a variety of purposes.
Sounds good? If you don't care about the nerdy science behind this, go straight to the next step. Otherwise, keep reading.
Agar and gelatine can both be used to solidify a liquid, but they are structurally quite different. Agar is a carbohydrate, and gelatin is a protein. While gelatin is derived from animal collagen, agar comes from algae and is thus plant based (and vegan). Agar melts around 85 degrees C (185 F) whereas gelatin melts at 35 degrees C (95 F), making it less stable. This also means that gelatin will melt in your mouth while agar will not.
Step 1: Ingredients
To make enough plastic for a baking sheet (about 6 pouches -- the plastic shrinks as it dries), you will need
- 1 tsp. agar powder
- 2 dl. water
I chose to fill the plastic pockets with trail mix, but you could potentially use anything, like spice blends, tea, etc. (just throw the bag into the pot of hot soup or tea water, and it will melt!)
NOTE: For a recipe using gelatine instead of agar, click here .
Step 2: Boil
Mix the water and agar in a pot, bring it to a boil, and let it boil for 30 seconds. Take the pot off the heat, and let the bubbles escape. Skim off any foam from the top.
Let the liquid cool till it stops steaming. This will make it easier to coat the parchment paper evenly. Pour the liquid onto a baking sheet with parchment paper and quickly tilt it to distribute the liquid in an even, thin layer.
Set the baking sheet aside, and let the plastic dry for at least 24 hours or more.
NOTE: I have tried both pouring the plastic onto aluminum foil and directly onto a plate, and neither worked as the plastic stuck. Parchment paper is the way to go.
Step 3: Cut
When the plastic is completely dry, it should peel off easily. Carefully remove it from the parchment paper. Trim the edges, and cut the plastic into appropriately sized squares.
Step 4: Fill
Put your desired filling (I used trail mix) onto one half of a piece of plastic, and check to see that the other half can be folded over to close the pocket.
Brush some water around the edges of one half of the plastic, and fold over the other half, pressing on the edges to adhere. If the edges do not adhere very well, try folding the edges to secure the filling better.
Let the seams dry for half an hour before packing and enjoying the little pouches.
Step 5: Verdict
VERDICT:
Taste: I think these trail mix pouches actually taste quite good, even though they challenge the sensory experience of eating trail mix a bit. The first impression is that you are stuffing, well, plastic in your mouth, and the plastic can have a very slight salty flavor from the agar, but as soon as you start chewing, the plastic disappears, and you get all the goodness from the trail mix. If you really think about it, the edible plastic adds a slight, chewy gummy-bear texture in the background, but it goes perfectly with the dried fruit.
Durability: The plastic holds up pretty well to scrunching, even though it may rip in areas that are very thin. However, the seams are a bit fragile and can easily open so that trail mix falls out. Also, the plastic is sensitive to humidity. So I probably wouldn't stuff these goodie bags in the kids' pockets if I knew they were going to play in the rain or stick their hands in the pocket a thousand times to feel if the treat is still there (even though I think I might actually slip one of these in my own pocket, hmmm, but for the kids, maybe put it as a surprise in the sack lunch for school). I think the best way to store and carry these plastic pockets with trail mix would be in a real food-grade plastic bag or container.
I hope you liked this instructable! If you did, please vote for me in the Science of Cooking contest and Pocket-Sized contest. Thank you! Also, if you try this out, please share the result and any modifications in the comments!
Pocket-Sized Contest
Runner Up in the
Science of Cooking
First Prize in the
Science of Cooking
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
    5 Questions
    Question unrelated. But Does anyone know how to favorite this one? I cant find the button after the new interface.
    hey Marvelmx. If you scroll down from the top of the instructable, a hover bar should appear at the top of the page with a "favorite" option :)
    Love this idea! Have you tried putting the trail mix on the sheet after it dries, then dribbling another layer of agar on top, for a sort of blister-packed-granola-bar result? Would the challenge be achieving a thin but consistent top coat?
    No, I haven't tried that, but another reader suggested the same idea. I think the agar plastic would become too thick and unpleasant to eat, but it is definitely worth a try!
    I've rice paper used as edible wrapping (especially of Japanese candies) Can you make a rice paper baggie the same way?
    I don't know. Maybe. I think rice paper would be thicker and crunchier, though. This plastic is very thin and pliable even when dry.
    What measurement is dl?
    I believe deciliter. 2 deciliter = 200 mL (milliliter).
    I've never heard of agar... is it only available online?
    You can get it at any heath food store, or online. It’s also used as the base food substance to grow bacterial and viral cultures in Petri dishes by laboratories. Very comment n in Asian cuisine. You can by it in any size from small packets to 5 lb jars. There is “human food grade” and “laboratory grade”. The laboratory grade is typically more expensive because they need to ensure precise quality and zero contaminants. I’m not saying that “human food grade” is contaminated with anything bad for humans, it’s just that laboratories can have “anything” except 100% pure agar, or they would never know if their cultures get cross contaminated. But you boil it anyway, so anything alive will die when it reach 212°F/100°C. So the “human food grade” is all you need. Don’t accidentally pay for laboratory grade or it will cost you 10-50x more money and you’ll get nothing in return for the extra money spent. I can assure you, that if you ever eaten various Chinese food dishes (especially their deserts), or numerous gummy-type candies, then you’ve already eaten agar many many times in your life and didn’t even realize it.
    2 more answers
    Awesome, thanks!
    you can get it in stores. i have seen it. look for agar agar .
    36 Comments
    This is April Fools' material. :D
    Thanks for the idea!
    I am wondering if this method will work using sodium alginate and calcium chloride/lactate? Will have to think when/how to mix the two solutions but the advantage will be that it can be done cold. It might also produce a thicker/stronger pouch...
    That would be great kids could help make
    Interesting idea... I have never worked with sodium alginate, so I don't know if it would work. Please share if you try it out!
    Great idea, I have been wanting to pack some of my coffee with the raw sugar I use when going out as not all places have the coffee I like plus sometimes I am not in the mood for a flat white when at McDonalds this way I could make up a few pouches and place in my tea tin for a choice of tea or coffee now :-) this is a brilliant idea and I already have some in the cupboard as I do a lot of Asian cooking so always keep it on hand.
    I do like the idea for making my own protine bars as I am not able to eat the shop bought ones due to allergies this way I can make my own and never have to worry about an allergie attack :-)
    Thanks for sharing this going to make some up when the sun comes up lolo I think 5:30 am is a little to early to start cooking :-)
    Haha, yeah 5:30 is a bit early, but I have done it once when I was going to bring a cake to work that I didn't finish the night before. You know, DIY people can be a bit crazy once in a while! :D
    What a great idea to make personal coffee pouches! I have thought about the same but with sugar-free hot cocoa, as I don't drink coffee and can't have the sugar sweet cocoas served everywhere.
    I tried to read the one on Geletin but there was an add half way across the instructions and I was not able to remove the ad’s at all to read it. I did manage to get the gist of it so that’s fine but it was annoying having this big black strip down the right hand side....
    Yeah, that´s annoying. Unfortunately, I am not the writer of that post, so I can't do anything about it. I just found the recipe on the internet and used it as inspiration for my own recipe using agar.
    Great! Please share your results!
    This is super awesome! Just voted for you in both contests.
    BE VERY CARE GIVING THIS TO SMALL CHILDREN! They might believe that ALL plastic bags are edible and choke themselves. Teach them the difference.
    youre using agar and you state it melts at 85C 135F which is hotter than a mouth ... so how does it melt in mouth ?
    In the introduction, I state that because of the melting points, gelatin will melt in the mouth, but agar will not. :) You simple chew the plastic with the trail mix, and the flavor and texture of the plastic will be overpowered by the trail mix.
    It melts in your mouth not because of the temperature, but rather because it gets wet. Perhaps it would be better to describe this as dissolving instead of melting.
