Epoxy Resin Ocean Table
1,175
31
4
Published
Introduction: Epoxy Resin Ocean Table
About: Hi Everyone, I'm Jeremy Hoffpauir. I love creating cool things. I love making old things look cool, I love making new things look old, I love making things that are unique, I love making things that inspire...
In this instructable, I show you how to make an epoxy resin ocean table and why this table has special meaning to my family and me. Be sure to watch the video and visit my website for more detail as well as additional information.
My family and I love spending time at the beach. We love the sand, the ocean, the warm sun, and everything a day at the beach has to offer. On second thought, we love everything minus the occasional chain-smoker upwind and the sporadic sibling argument over plastic shovels.
My wife and I purchased a home in Destin, Florida in 2012 and we live there 3 months out of the year. Destin, Florida is only a 3 hour and 30 minute drive from our home in Louisiana and I've visited this southern paradise (aka 'Redneck Riviera') since I can remember. Stacey (my wife) has a cricut and she is quite crafty when time permits (Time permits = our kids aren't calling her name every 3 seconds). Furthermore, the cricut has yet to find a permanent home despite the fact I bought her the cricut over 1 year ago. As a result, I decided to build a table with storage as a Mother's Day gift for Stacey. My goal was to incorporate as many things (places, items, etc.) into this table that I possibly could. In other words, I want this table to make her smile each time she has an opportunity to sit in front of it. I also put a few sea shells, sand dollars, and Mickey Mouse ears on the table. Stacey loves to find seashells, find sand dollars, and anything related to Disney. The epoxy resin ocean table bottom is comprised of two storage cabinets with 4 drawers each. In an effort to keep the video at a reasonable length for today's ever-shrinking attention spans, I decided to make that a separate project. Be on the lookout for that video soon.
Step 1: Gather Materials
I used simple pine 2x4s to make this epoxy resin ocean table top along with the tools and materials listed in the previous section.
In total, I used 16 2x4s @ 8ft long. I highly recommend to be selective when purchasing 2x4s from your local home center (i.e. big box stores). If I had to guess, at least 25% of the 2x4s at a big box store are severely warped and/or damaged. Consequently, I save a lot of time during the milling process.
Pro Marine Table Top Epoxy
Before I begin explaining the epoxy resin pours, this is an appropriate time to answer a common question I get from people because I don't always take pictures of the products I use. I used Pro Marine Epoxy Resin for this project. In my opinion, this is the best epoxy resin on the market at the best price. Click here to purchase some of your own on Amazon.
Tools & Materials I Used
Below are the tools I used for this epoxy resin ocean table.
Step 2: Mill Lumber
Since the 2x4s were relatively straight and flat, I cleaned up each side on my table saw by removing just enough material for a nice, straight edge.
Also, most 2x4s have a slight rounded edge and it's important to remove this before proceeding to the glue up.
Step 3: Glue 2x4s
After I milled the 2x4s, I separated them in 2 groups of 8 and glued them together. This is also referred to as laminating 2x4s.
I spread the glue across the entire surface to make certain the bond is strong.
Next, I clamped them together using my bar clamps. I didn't have enough clamps, so I had to use my worx multifunction table.
It's important to keep the 2x4s as level as possible during the glue up as this saves a ton of time in later steps. I do this by placing clamps on the bottom and top of the wood and slowly tightening each clamp. Once all the clamps were tight, I removed as much of the excess glue as possible with a damp rag.
After the glue dried, I removed the clamps and used my glue scraper to remove the excess glue.
Step 4: Plane and Glue
I ran each 12" section through my planer to get a flat surface.
This step is much easier when the laminated 2x4s are as flat as possible during the previous step.
Next, I spread glue and clamped the 2 12" sections together.
Step 5: Install Steel Rods
These two pieces of the ocean table was simply too heavy to rely on glue to keep them together. I decided to reinforce the ocean table with 3/4" square steel rods.
After the glue dried, I removed the clamps and decided which side of the table would be the top. Ultimately, it didn't matter because I flattened each side of this epoxy resin ocean table with my planer. I oriented the epoxy resin ocean table so the bottom would be facing up. Then, I cut the steel rods to 18" long on my miter saw. Next, I measured 24" from each end and used the square steel rod to draw a straight line. I measured 2.5" from each side along the line and made a mark. These 2 marks from each end of the table marked the starting and stopping point of the channel.
I used my Jig It Drill Guide (Link in Tools List) with a 1" forstner bit to drill the starting and ending point of each channel. The hole needed to be 1" wide x 1" deep and the drill guide helped me drill a perfect vertical hole and control the depth.
Once the 2 holes were drilled to the proper depth, I used my trim router with a 3/4" straight bit to route the rest of the channel. Next, I clamped down the steel rod to serve as a guide for my trim router. I removed 1/4" of material per pass until I reached the desired depth. Additionally, I had to widen the hole by 1/4" to 1" because the straight bit was only 3/4" wide.
After I removed the wood chips and dust, I scraped each steel rod with a wire brush to make the surface more bond-friendly.
Next, I laid the steel rods in the channel and mixed Bondo in small batches to secure the rod.
Finally, I let this dry overnight although it doesn't need that much time to dry.
Step 6: Create Beach Slope
To create the beach slope, I used the crease between the 2 pieces as a marker to start the downward slope. Additionally, I used my grinder along with a Kutzall extreme disc to carve a sloping ocean floor.
I carried the table outside and placed it on 2 saw horses because I knew the next step would be very messy. The kutzall extreme disc makes quick work of carving the wood. To start the carving, I ran the kutzall disc across the middle seam of the table and worked my way down, carving deeper into the wood as I went. The Kutzall disc also made it easy to make a wavy pattern, which mimics sand on the ocean floor.
After about 20 minutes of carving, the table started to resemble an ocean floor.
It started raining, so I brought the table back inside and used my electric handheld planer to remove some of the high spots. I could have also used a belt sander to flatten the high spots and it would have worked just as well. The kutzall extreme disc is a fantastic tool to carve wood with a grinder; however, it leaves uneven spots when used for an application such as this epoxy resin ocean table.
Step 7: Trim Table to Final Size
I prepared the surface for the resin pour by trimming the back of the ocean table with my festool track saw.
In addition, I trimmed each side of the ocean table as well. After I trimmed the sides, I flipped the table over and used my circular saw to trim the first front 12" by 1.5". Next, I used my hand saw to cut this piece off. I carved more of the beach to ensure the resin could fully enclose the sloping ocean table floor.
Step 8: Prepare Surface for Resin Pour
I've used just about every resin mold option I can think of. I've used an enclosed melamine box, a melamine board with a damn at each end, and MDF with masking tape.
In my opinion, the most efficient method is using MDF or old wood covered with masking tape and furniture wax. So, that is what I did for this epoxy resin ocean table project. I had an old piece of MDF I used as the bottom of the resin mold. Next, I laid the ocean table on top of the MDF, centered it (side to side, front to back), and made sure I had 3 inches of excess on the 2 sides and 2 ends. Then, I covered the table with masking tape 6 inches from all 4 ends and covered it with furniture wax. Furniture wax is a great release agent for epoxy resin.
I centered the ocean table in the same place as it was when I centered it previously. Next, I put silicone caulk around the perimeter of the ocean table and the MDF bottom.
In order to form a tub for the epoxy resin, I used strips of MDF covered with packaging tape on the front, back, and 2 sides.
Step 9: Create Sandy Beach
Please note, this step is not necessary and I'm not sure why I decided to do it. Instead of skipping the step altogether, I'm writing about it to be transparent as possible about the process of building this ocean table.
To create a rough texture and mimic sand on a beach, I mixed Zinnser texture additive to antique white chalk paint and painted the surface of the table with a chalk paint brush. I didn't measure the mixture ratio - I simply mixed until I achieved the texture I wanted.
Next, I fogged beige spray paint on the surface to create an irregular pattern and darken the white paint.
Step 10: Paint Ocean Bottom
Originally, I planned to make the ocean the same color as the beach (light beige) since the real ocean has the same sand as the beach on the ocean floor.
I changed my mind because I thought it would be difficult to create a blue ocean if the bottom were beige. After all, it probably would have been easier to tint the resin with transparent dye and create a blue ocean but I just didn't have much confidence. So, I decided to paint the ocean floor the color I wanted the resin. I've seen many projects when tint was used in resin to achieve a desired effect; however, the bottom color of the resin was stronger than the color used to tint the resin. Transparent dye works very well when there is no bottom in my opinion. The beach in Destin, Florida has different shades of blue with a hint of green, which is why people refer to it as the 'Emerald Coast'. I didn't have any green paint, so I painted the entire ocean table floor with light blue.
Next, I used dark blue and put it on top of the light blue. I made it darker as the ocean table floor got deeper.
Next, I used a tiny bit of white chalk paint mixed with pearl white pigment powder to make the crest of waves near the beach. Then, I used a popsicle stick to mix the material and spread it out on the table. Later, I realized it was better to apply this with my finger while wearing a pair of gloves.
Step 11: Make Resin Seashells & Mickey Ears
Since this table was for my wife, I wanted to incorporate as many of the things she loves into the table. Stacey (my wife) loves collecting seashells and anything Disney, so I purchased a silicone mold of seashells and a few sea critters to put on the bottom of the ocean table.
I mixed 16 total ounces of resin. Next, I separated the resin in 4 different cups and mixed 1 ounce of orange, white, green, and blue glow powder. Then, I poured the resin into the seashell silicone mold. Also, I had a silicone mold of Mickey Mouse Ears from a previous project so I used that as well to make a few Mickey Ears.
I allowed it to cure overnight before removing them from the silicone mold.
Step 12: Glowing Ocean Table Floor
To create a slight glow on the wave crests and beach, I mixed 12 ounces of resin with 1/2 ounce of white glow powder and pearl white pigment powder. I didn't put a lot of glow powder because I wanted the glow to be subtle.
Next, I used a chip brush and applied it on the wave crests and beach. I wanted the waves and parts of the beach to have a slight white glow.
After I covered the beach, I sprinkled more pearl white pigment powder on the beach and brushed it in.
Then, I used the same technique to cover the light blue and dark blue parts of the table. This will help the sea creatures, seashells, and sand dollars stick to the bottom.
Next, I placed the seashells, sea creatures, and sand dollars in various spots on the ocean table bottom while the resin from the previous step was still wet.
I let the resin harden for about 3 hours before proceeding to the first resin pour.
Step 13: First Resin Pour
Now to the fun part.
I mixed 12 ounces of resin for the first seal coat. Next, I poured the epoxy resin in front of the beach entry and let it run down.
Then, I used my torch to remove the bubbles and let this cure for 12 hours.
Step 14: Second Resin Pour
The second resin pour was the same process as the first seal coat. I mixed 12 ounces of resin, poured the epoxy resin close to the beach entry, removed air pockets with my torch, and allowed the resin to cure overnight.
Step 15: Test Glow Powder
While the second seal coat was curing, I decided to test the glow powder using a black light. I did this before I proceeded to the seal coats as it's not too late at this stage in the process to make a few changes.
Glow powder can be quickly charged with a black light. This technique is much quicker than waiting for natural light to charge the glow powder, which is much slower. I turned off the lights in my shop and covered my one window to block as much light as possible.
Next, I shined the black light on the ocean table to test the brightness of the glow.
Ultimately, I was happy with the glow so I proceeded to the epoxy resin fill coats.
Step 16: Third Resin Pour
For the first fill coat, I mixed 2 24 ounces of epoxy resin (48 ounces total).
Quick Tip: I find it easier to mix the resin in smaller batches. Smaller batches help reduce bubbles and promote proper mixing techniques. Next, I poured the resin in the front trough. Unlike the seal coats, I want the resin to fill the table from the front up towards the beach.
I removed the bubbles and immediately proceeded to the next step.
Step 17: Fourth Resin Pour
Immediately after the first fill coat, I realized I needed the blue water over the seashells, sea creatures, and sand dollars to make the table look as real as possible. I mixed 32 ounces of epoxy resin, separated the mixture into 2 containers (16 ounces per container), and then put one drop of blue transparent dye in each container.
During the mixing process, I was very careful to not use a lot of transparent blue dye in the epoxy resin for 2 reasons:
  1. Since this ocean table would need numerous fill coats, I knew the epoxy resin would get darker with each new layer.
  2. The ocean table bottom is already blue.
I poured the resin as I did in the previous step.
Next, I removed the bubbles with my blow torch.
Finally, I let this cure overnight.
Step 18: Fifth Resin Pour
The resin was finally beginning to climb up the ocean floor. For this fill coat, I mixed the same amount of resin the exact same way as the previous step. I used 32 ounces of resin split into 2 containers with 1 drop of transparent dye.
Instead of using my torch, I decided to use my heat gun to remove the bubbles and move the resin around better. The blow torch does a great job at removing bubbles, but the heat gun removes bubbles and moves the resin.
So, why do I not use the heat gun all the time? As hard as I try to keep my shop clean, it is always dusty. The heat gun blows air and increases the likelihood unwanted contaminants will litter my epoxy resin.
Step 19: Sixth Resin Pour
The epoxy resin ocean table was finally beginning to look like an ocean.
For this fill coat, I used 96 ounces of resin. The 96 ounces of resin was split into 2 containers with 48 ounces and 1 drop of transparent blue dye in each.
Then, I used my torch to remove the bubbles and then my heat gun to move the resin around a bit.
Finally, I allowed this to dry over night.
Quick Tip for Mixing Epoxy Resin
Epoxy Resin can be difficult to stir in large batches; however, this is the most important part of any epoxy resin project. I find it easier to scrape the bottom of the container and turn the material on top of itself about 25 times before mixing in a circular pattern.
Step 20: Seventh Resin Pour
For the final fill coat, I used 48 ounces of epoxy resin.
After I completely mixed the resin, I poured 4 ounces into a separate plastic container and mixed 1/2 ounce of pearl white pigment powder and 1/2 ounce of white glow powder. I didn't add any transparent dye to this batch because the table had the exact shade of blue I hoped for. By adding another fill coat with transparent dye, the table would have darkened a bit, which I did not want. I poured the 44 ounces on the ocean table and watched as it leveled off even with the beach.
Next, I took the small cup of resin and created white lines near the beach to look like waves breaking near the beach. The painted wave crests looked ok, but I thought they could look better.
Then, I used my torch to quickly remove the bubbles. Additionally, I used my heat gun to blend the white wave crests for a more natural look.
I didn't allow this to dry before proceeding to the next step.
Step 21: Eighth Resin Pour
This epoxy resin pour can be classified as flood coat. It is meant to cover the rough/sandy beach portion of the table only.
In total, I used 12 ounces of resin during this step. I spread it around with a rubber spreader and let it blend in with the final fill coat from the last step.
Step 22: Remove Resin Mold From Ocean Table
After the table cured for 48 hours, I removed the MDF form using my rubber mallet and some elbow grease.
Packaging tape coated with furniture wax works extremely well and makes it super simple to remove the mold.
Step 23: Sand Table
I used my random orbital sander attached to my vacuum with 220 grit sandpaper to sand
Sanding what appears to be a finished table scared me during my first epoxy resin table project. I thought I ruined the table because it turns very cloudy. Seriously, I almost passed out.
To remove the cloudiness from sanding the table, I wiped it down with acetone. This not only removes the dullness, but it also removes loose residue from the table.
Step 24: Ninth Resin Pour (Flood Coat)
Since I just finished building a epoxy resin table for my sister's birthday a few weeks ago, I had leftover Stonecoat Countertop Epoxy and decided to use it as the final flood coat on my ocean table.
Pro Marine Epoxy would work just fine, but I simply wanted to use the rest of this material rather than watch it sit on my shelf for the next few months.
Stonecoat Countertop Epoxy is different than most epoxy products as it is very durable. Also, it requires a different mixing and application process.
It can be mixed with a drill and mixing paddle.
Next, the material has to be spread on the table with a rubber squeegee.
Then, I used a 1/8" trowel to spread the material across the table and allowed a little bit to drip over the sides. I came back over the table with my hand to ensure the material was spread evenly on the sides of the table. Refer to my video for additional details or my previous project where I cover this process in greater detail.
I put 2 coats of this product on top of the table - repeating the aforementioned process. I let it completely cure for 48 hours before moving it in the house.
Step 25: Table Bottom Storage Cabinets
The table bottom project video and tutorial will be in a separate project. Check back often for this tutorial and downloadable DIY plans.
Step 26: Move Ocean Table to Final Location
My son, along with a dolly, helped me haul the ocean table out of my shop, into our house, up the stairs, and into our loft. Needless to say, it is very heavy.
I placed the epoxy resin table on the table bottom storage cabinets and secured them with pocket holes I pre-drilled in a previous step.
After I secured the table, I let it charge in the natural light and waited until night to see if it would glow.
It was awesome - the picture below does the epoxy resin ocean table glowing features very little justice as I have yet to figure out how to take a quality photo in the dark.
Also, please message me if anyone has tips on how to take quality photos in the dark.
Step 27: Conclusion
I started doing custom builds with minor customizations for all my projects. If you are interested, be sure to contact me for a custom quote.
I hope this project provided you with some value because this is, and always will be, my ultimate goal.
Please consider subscribing to my YouTube channel and visiting my website for more projects and other fun stuff. Feel free to contact me anytime if you have any questions. I'm happy to help!
Casting Contest
This is an entry in the
Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    4 Comments
