Faux Live Edge Epoxy River Table for Under $100
3,141
52
10
Published
Introduction: Faux Live Edge Epoxy River Table for Under $100
About: I like making stuff.
I made this faux river table for the Rockler Plywood Challenge put on by the Modern Maker Podcast. I use maple plywood and rustoleum epoxy super glaze for this project. In one of their episodes one of the hosts mentioned they hated river tables so I decided that is the project I was gonna make for this challenge. It came out really well and Im using it for my bedside table. This is "Fake" live edge table because its made out of plywood.Overall, I think it came out great!
If you like this project please consider subscribing to my youtube channel or following me on instagram.
www.youtube.com/chippedbuilds
https://www.instagram.com/chippedbuilds
Step 1: Tools & Materials
Table saw
Jigsaw
Drill
Epoxy Resin
Tyvek tape
Sander
Color pigment
Hot glue gun
Screws
Step 2: Cutting and Staining the Wood
I bought a sheet of Maple plywood from Lowes and had them cut it down for me so i could bring it home and cut it to the actual sizes I needed. I then stained the wood a walnut color so it would match the rest of the furniture in my room.
Step 3: Faux Live Edge Effect
I then drew some squiggles on the two boards to mimic a river flowing. I then tilted my jig saw base to 30 degress to get the live edge effect.
Step 4: Making the Mold
The mold is pretty simple to make. Measure out your overall length and width and cut the base to size. Then cut some side pieces at the appropriate height so that the epoxy wont spill out. Then you need to cover all the wood with tyvek tape to seal it so the epoxy wont stick to it. Once that is done seal all the seams with either hot glue or silicone. I did both. Then you can screw or clamp the two pieces of wood to the mold. This is so the wood wont float in the epoxy.
Step 5: Pouring the Epoxy
This part is so satisfying and easy. Just follow the instructions for the specific epoxy you use. Mine was only $30 bucks and you had to mix it for 3 mins. I added some blue and white color pigment to the epoxy to get the color I wanted. Make sure you sealed the mold well other wise you will get some leakage like I got got. I let the epoxy cure for 3 days (just to make sure it was fine) and then removed the wood from the mold. Just take your time so you don't break anything.
Step 6: Fixing Mistakes
One side didn't look very good as I spilled some of the blue epoxy on it and I decided to sand it all down with 80 grit sandpaper. I ended up sanding through the top layer of plywood which was a bummer but it didn't look too bad. I then used a small paintbrush to stain the seam by the epoxy and a bigger brush to finish it off.
Step 7: Making the Legs
Im not good at making table legs and probably would have used hairpin legs for this project if I was gonna do it again. I just measure 2" from the edge on one side and 3" on the other. I then connected this line and used the circular saw to cut this out on the four legs. Once those were cut out I realized I needed a cross brace for the legs and cut the same angle on those pieces with the circular saw. Next i glued and nailed the pieces together. I drilled some pocket holes into the cross braces and stained the legs to match the table. Once they were dry I used a spacer block and attached the legs to the table.
Step 8: Enjoy Your New Table!
I loved how this turned out! It matches my room perfectly and it showcases my favorite color. This project can be done in under $100 bucks which is super awesome. Please let me know if you have questions or if you make one in the comments.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    10 Comments
    I am not a fan of the river thing, but yours is pretty nice none the less, and you have a billion times any feeble skills I have.
    BUT
    you wrote
    " In
    challenge."
    If you are trying to win, why do what they hate?
    It is nice so good luck.
    Thanks. I mostly did it cause I thought it would be funny. Going into this contest I knew there was gonna be a lot of people entering with greater skills than what I have so I didn't really enter the contest to win. I did it just to participate.
    Hi. Beautiful work on your table!!! What a great idea for the live edge.
    I was just curious what product you used to finish up the wood top. It has a nice sheen and looks very professional.
    Thanks. I just used semi gloss spray lacquer
    Nice job! I like the 30° angle part. Is it possible to do some sort of an inlay route towards the bottom & inside the wood of the table you could insert an led strip? What epoxy was it? just from a big dept store like home Depot or a special epoxy from smooth on?
    Thanks. It would be totally easy to route a part for leds. I used rustoleum super glaze epoxy. It’s like $30 bucks at Home Depot.
    You have just given me unlimited ideas. Great instructable.
