Ghost/Snowman Out of Logs, It's Reversible
1,006
37
Published
Introduction: Ghost/Snowman Out of Logs, It's Reversible
About: Hi my name is David, I have been working with wood since I was a teenager. I like to build things, also like to take things apart and fixed them. I worked in a Furniture Factory for 22 years before it shutdo...
Today I will show you how I made these cute little Ghost and Snowmen out of old logs.
I cut an old limb off my trees, that was hanging over my Garage. I don't like anything go to waste, so I thought what could I make with it. Finally after letting it set out beside the garage a few months, then it came to me, make some logs for Halloween and Christmas decorations.
This is what I came up with, a real simple project. I hope you will enjoy it.
Step 1: What's Needed
3 logs ( I used 3 different sizes)
Chainsaw or Sawzall
Hammer
Chisel
Sander and 120 grit sandpaper
White paint ( I used outdoor house paint)
paint brush
Craft paint ( Black and Orange Pumpkin)
Small paint brush
Pencil
Step 2: Cutting Logs
I used a chainsaw to cut the limb off the tree, then I used a Sawzall to trim them down to size. If you wanted to, you could use the chainsaw instead. I cut three logs, one about 24" long and another a few inches shorter, then a smaller one for the child.
Note my tree limb had been setting for a few months, If you cut a fresh limb or tree, you will need it to dry out before using it.
Step 3: Debark
Now is time to debark the logs, I used a hammer and chisel.
Note after I debarked the logs, I let them set outside a couple of days to dry out more, the bark holds in moisture.
Step 4: Sanding
I then used a Orbital sander with 120 grit sandpaper, to clean up the rest of the bark.
Note that this doesn't have to be a perfect, you just want to sand good enough that the paint will stick to it.
Step 5: Paint Log
Now is time to paint the logs, I used some left over outdoor house paint. I painted the bottom first, then painted the rest. Let the paint dry overnight, before continuing.
Step 6: Draw and Paint Faces
Now use your imagination for the faces, I looked at some Google images, and this is what I came up with.
First use a pencil to draw the faces onto the logs, then paint with Craft paint. I used Black and Pumpkin Orange.
Step 7: Enjoy
Once your logs are finished, set back and enjoy. I added some hats to the snowmen.
Now you have two decorations, one for Halloween and then one for Christmas.
I hope you have enjoyed this Instructable, I think they came out great.
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Comments
