How to Make Italian Cheesecake
5,802
96
10
Published
Introduction: How to Make Italian Cheesecake
About: Architect/designer based between Chicago and SE Minnesota. Resource based problem solver... in other words, I always take a minute to peek in construction dumpsters :)
For years my gf has been perfecting this family recipe shared from a friend in college. The gentle variations have paid off. The most recent Italian Cheesecake was the best one yet! Here's a walk through the recipe.
The Goal. As always it is to remove any hurdles from cooking. Especially baking. Typically recipes provided here are general instructions but this one gets specific as it's a recipe worth sharing in detail.
Step 1: Ingredients - Built Around Ricotta
Wet Ingredients
  • (3 lg) Egg
  • (1 lb) Cream Cheese
  • (8 oz) Sour Cream
  • (15 oz) Ricotta
  • (1/4 lb) Melted Butter (unsalted + salt OR salted)
Dry Ingredients
Crust
  • (1 sleeve) Graham Crackers
  • 1 Fat Scoop of Shortening (or 1/8 lb of Butter) ---considering the 38lb bucket the way we go through shortening... not there yet. crisco pack is twice the $/lb in the 16oz. ok, for now :)
*recommendation from raphan - in italy the proper approach is to use goat's milk ricotta and mascarpone (rather than cream cheese).
Step 2: Mixing
Mixing is a simple process that starts with the wet ingredients and moves to the dry.
  1. Wet Ingredients - combine together in mixing bowl. --great if you have a kitchenaid but not necessary.
  2. Melt butter in the microwave.
  3. Dry Ingredients - take it from the top of the list and add ingredients moving down the list
For us, the stand mixer removes a barrier to baking by requiring less physical activity to mix. That said, both me and gf baked for years without a mixer. Everything can be incorporated in a bowl with a whisk + spatula.
Whisks
Step 3: Crust
Simple, Delicious Crust
  1. Grahams - break up the package into a mixing bowl
  2. Shortening - add a heaping scoop or 1/2 stick of soft butter
  3. Mash - use your hands to work the two ingredients together.
Graham Tips. Easiest to break up the graham crackers in the package. More or less grahams only impacts the thickness of the crust. Ideally the mixture of grahams + shortening clumps when you pinch it... but if it doesn't everything comes out perfectly well.
Step 4: Layer + Bake
Steps for baking the cheesecake.
  1. Layer into a springform pan---shown is a 9" pan (roughly 160 cu. inches)
  2. PreBake Crust for 15-25min
  3. Bake at 325F (160C) for 1 hour
  4. Rest in oven for 1 hour
  5. Rest on counter for 20 minutes minimum
  6. Refrigerate overnight
Water Bath. to avoid top cracking you'll need a water bath. That means baking your cheesecake with .5 to 1 inch of water around the baking pan using a larger pan. ---no need to use a water bath provided you don't mind a split surface. I see the chasms as space for filling...
Step 5: Enjoy + Thank You
What makes this cheesecake so perfect? the variety of the cheese! Nothing fancy. Ricotta has a beautiful texture and thickness that makes it a staple for our baking.
Freezing. Cheesecake freezes beautifully. Easy to make this cake well in advance or you can save small slices to mix with yogurt. A great breakfast.
Recipes. This is a family recipe shared from my gf's best college friend. It's classic Mediterranean. These three cookbooks are our standard reference material.
Our Dream. One day we'd like to have a cafe. Here's our new instagram @cafeoneday!
Thank you. Hope you've enjoyed this instructable as much as we did making + eating + sharing!
Here are a few more desserts we put together this month:
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
    10 Discussions
    Thanks V for asking - 9" pan. Will update the notes
    I'm sorry. Just because there is ricotta in the list of ingredients it doesn't mean that is an italian food.
    In the Italian menu there is not any cheese cake.
    Italian ricotta cheese can be made with either cows or goats milk. Most Northern Italian ricotta is cows milk, as many Northern Italian cheeses are cows milk cheeses although there are some Northern Italian goat and sheep milk cheeses.. Southern Italian ricotta is usually goats milk. Sicilian ricotta is mostly goats milk as many Sicilian cheeses are goat or sheep's milk cheeses. There's even a hard ricotta called ricotta salata. This is more of a grating cheese and is inappropriate for Italian cheesecake. Here in the USA it's hard to find goat or sheep milk ricotta outside of Italian neighborhoods or a well stocked Italian delicatessen - market. When making an Italian cheesecake it's important that the ricotta be dry as some have more moisture than others. If necessary, line a strainer with a paper towel and dump the ricotta into it and allow it to drain over a bowl overnight in the refrigerator. Any whey, the cloudy liquid in the bottom of the container can be used for baking or cooking.
    Great looking cake. Cream Cheese is not in Italian Cheesecake. Butter makes a better product than shortening.
    raphan
    4 days ago
    Miam !
    Italians add Mascarpone in equal part with Ricotta to decrease goat's taste, but the Ricotta we find outside of Italy is made with cows milk.
    Yes, we were working with cow milk... these are improvements we need to make!! -will add a note
