How to Make a Khopesh Wooden Sword
Published
Introduction: How to Make a Khopesh Wooden Sword
About: I'm not an expert in anything. I just enjoy making things sometimes for the process sometimes for the end product.
I first saw this sword being made on Forge in Fire and I thought it was the dumbest design ever. I made a small version of the sword as letter opener, just as a wacky thing to make, but after finishing the mini version I fell in love with the shape. It grew on me and I got the itch to make a full size wooden version. The best part of this project was that I used material I had lying around and left over pieces.
Step 1:
I found a picture of a Khopesh on Google. I copied and enlarged the image before printing it out on multiple sheets of paper which I then taped together. The overall length is about 24 inches. The template in the picture is the cleaned up version of the print out.
The wood I used for the blade is mesquite wood flooring that was given to me as payment for another project.
I taped the template to the wood and traced the outside edge. I try to follow the line as carefully as I can, for some reason I thought a silver colored marker would show up better.
The silver marker didn't workout like I had planned but you can still see the shape of the sword.
Step 2:
I used my band saw to cut out the rough shape of the sword. If you don't have a band saw you could use a jigsaw or if you want a work out a coping will do the trick as well.
You can see my cut lines aren't that graceful, that's why when I make the cut I stay on the outside of the marker line. It gives me more room for error.
The last picture shows the rough shape of the sword.
Step 3:
The wood flooring has some ridges on the bottom that I had to sand off.
If you use store bought lumber you can avoid this step. It takes a little while to sand off the ridges but the belt sander works well for this process.
The last pic shows the sanded handle.
Step 4:
More sanding and smoothing all the lines. I used the curves of the belt sander to clean up the curves of the blade.
Some spots were just to tight so I had to sand those by hand. Here I am using a wooden dowel wrapped with sand paper to clean up the inside of this tight little curve.
Step 5:
Once every thing is cleaned up, it was time to add the bevels. First I had to find the center of the blade and make a mark down the entire length. This time I used a black marker.
Then its back to the belt sander. While keeping the blade at a slight angle I work the sword back and forth working my way up to my center line mark. I repeat the process for the other side.
The bevel is starting to take shape.
Step 6:
The most time consuming part of the making this sword is the sanding there is a lot of sanding. I eventually switched to hand sanding to clean up any marks left by the rougher grits. Here I am sanding with 220 grit sand paper.
Step 7:
After sanding it was time to make the handle. I don't know what this wood is, its very soft and a dark chocolate brown and smells really good when I cut it. I traced the shape of both sides of the handle on to the wood.
And yup I used the silver marker again for some reason.
Step 8:
Here again I used my band saw to cut out the handle.
The wood was pretty thick so I decided to split this handle in two instead of cutting another handle.
The last pic shows the two rough pieces cut.
Step 9:
I made sure to sand one side of each handle flat so that there won't be any gaps when I glue them to the sword.
Next I add glue to all the surfaces.
I sandwiched up all the pieces and clamped them tight. I let the glue dry overnight.
The final pic shows the sword after the glue dried.
Step 10:
And time for more sanding. I used the different curves of my belt sander to do the majority of the work and clean up and shape the handle.
I finished off the handle by hand sanding it. I ended up sanding everything up to 600 grit for a really nice and smooth finish.
Step 11:
After wiping off all the sawdust I applied about 4-5 coats of Danish Tung Oil per the instructions on the can.
The camera doesn't really do the wood justice, it really is very pretty with a lot of figure in the blade.
Step 12:
Like I said earlier the shape of this sword really grew on me and I know it won't be the last one I make. Thanks for reading my Instructable and I hope you found it helpful. See you next time.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
