Japanese Mirror Frame
7,286
141
Published
Introduction: Japanese Mirror Frame
About: ♾️ TOOLS TOGETHER is making woodworking and DIY hack videos for people who want to build their own furniture.♾️
By this project you can practice Japanese joinery techniques. No glue or screws are used by woodworking. This will make this woodworking project rather challenging even for experienced carpenter.
We use a milling router for all the joiners but it is possible to master these with hand tools only if you have no access to the power tools.
Step 1: Cutting the Wood
Cut all the parts of the mirror as shown on the drawings.
Step 2: Milling the Joiners of the Mirror Legs
First mark the joiners and then cut the joiners with the miller. Use the chisel to get it perfectly done. The right leg is mirroring the left. See the exact sizes on the drawing.
Step 3: Cutting and Milling the Upper Frame
First make the upper frame thinner at the both ends, then mark the joiners and mill. Use chisel to get it perfectly clean.
You can see it on the 23th second of the video above (click on play to watch).
Try the frames together if they fit. Make corrections if necessary.
Step 4: Mill the Grooves
Make the grooves to all the inner sides of the mirror frame using milling machine.
Step 5: Joiners for the Keels
Make the joiners for the keels. These are rather small details so you can use a little help of a hand drill.
You can watch this on 2:47.
Step 6: Making the Joiner for the Support Leg
Use the drill no 19.
Step 7: Milling the Torii
Milling with the milling machine. Watch the video on 3:02 for tips.
Step 8: Assemble the Frame
Assemble the frame to see if everything fits as it is supposed to fit. Now is the time to make the corrections if necessary.
Step 9: Making the Support Leg for the Mirror
Use the milling machine to cut the corners of the stick seen on the drawing j.
Cut all the joiners shown on the drawing b, g and j.
Step 10: Making the Joiners With the Keel
For adding the keel to the joiner you need to cut the keel and stick it in between the joiner.
Now cut using the Japanese saw the "leftovers" and sand the surface.
Step 11: Sanding Everything
Now sand all the surfaces and make the corners also smoother using a mini planer.
Step 12: Adding the Keels
Don`t forget to add the smallest details - the Keels.
Step 13:
Remove all the dust and start finishing. We use the colorless oil but you can also consider a polisher.
Step 14: Assemble the Mirror Frame
After letting the oil dry you can assemble the mirror frame.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    What kind of table saw are you using. I want one, bad.
    2 Comments
    I like keels :) You always should assume somebody can wish to fix/renovate/improve it, so easy disassembling is must have!
