K'Nex Grandfather Clock
308
8
4
Published
Introduction: K'Nex Grandfather Clock
About: Wacky retired chap who just can't resist going to car boot sales; a hoarder. Having retired 15 years ago after working for 33 years, he decided that he would spend the next 33 years playing.
Introduction
This Instructable shows how to create a working K'Nex clock from scratch. A few liberties have been taken as described below. If you are only able to rigidly follow instructions, then this is not for you; some creativity will be required because It does not cover the complete construction of the grandfather clock in the first video; rather, it covers the essential elements (the escapement, the pendulum, the gear trains, the assembly for the hands, etc) which enables that kind of clock to be built. The second video shows a working cut-down version of the clock which this Instructable does cover. The clock in the first video ticks for 24 hours on a single wind. It does not have a striking mechanism. It uses two weights, one on each side of the clock. This instructable covers only part of one side, the other being a mirror image of it, and so there is only one weight.
The serendipitous discovery of a K'Nex yellow gear with 84 teeth was the inspiration for this clock. There are three types of K'Nex gear: the small blue captive gear has 14 teeth; the read gear has 34 teeth, and the large yellow gear normally has 82 teeth. These cannot be directly used to create the 12 to 1 ratio that a clock's minute and hour hands need, but the yellow gear with 84 teeth changed all that; a 6 to 1 ratio was now available, which was half way there! The K'Nex user Shadowman39 pointed out that it might have come from a solar set. It also appears in one of the educational sets.
Owing to the weakness of some of the K'Nex components, there are some non-K'Nex elements. A few screws have been used to clamp some pieces together to avoid destructive torsion in rods, and some lead weights have been used (a heavy one to drive the clock, and two light ones to balance the hands). Some pieces (not many) have been cut, and so K'Nex purists may wish to abandon this Instructable now! There is some electrical wiring in the clock in the first video, as well as a couple of micro switches and an electric bell. It is fair to say, though, that over 99.9% of the clock is made from K'Nex.
A pendulum clock works by using a swinging pendulum to allow an escape wheel to rotate at a constant rate (the teeth of the wheel 'escape' the pallets). The escape wheel is at the end of a train of gears; at the other end is either a barrel which contains a mainspring, or a spool which is turned by a heavy weight. Whichever method is used, the escape wheel is given a rotational force which gives the pallets, and therefore the pendulum, an impulse each time it swings to the left or to the right. Use Google for more (and perhaps better) details.
The intention was to make a clock which ticked once a second, just like a real grandfather clock. The escape wheel has 16 teeth and so it needed to turn once every 32 seconds, i.e. 112½ times each hour. A red gear in mesh with a blue gear gives a ratio of 17/7, and so three of these in series will give a ratio of 173 / 73 = 14.32... This is about 1/8th of the target, and so an approximate one-second tick can be achieved with three lots of red/blue gears and a pseudo 8-1 gearing (which can be done by using 8-way connectors). The precise duration of the tick would therefore be 3600 / (173 / 73 x 8 x 32) = 0.98177 secs. This is pretty close to one second and is the best that can be achieved. In practice it sounds like a one-second tick.
There is a limit to the weight that K'Nex components can bear, and so the clock is driven by two 3kg weights (one of each side of the clock) rather than by just one heavy one.
The steps in this Instructable are as follows:
Step 1: The Escape Wheel
Step 2: The Pallets
Step 3: The Crutch
Step 4: Combining the Escape Wheel, Pallets and Crutch
Step 5: The Gear Train
Step 6: The Winding Spool
Step 7: The Pulleys and the Weights
Step 8: The Pendulum
Step 9: The Transmission to the Hands
Step 10: The Hands Assembly
Step 11: Winding the Clock
Step 12: Regulating the Clock
Step 13: Maintaining the Clock
The escape wheel needs to be a solid block; any flexing in the teeth will sap energy from the escapement.
When attaching the eight rotational connectors in the 8th and 9th pictures, make sure that they click into position - it is very easy for one to look in place when it isn't.
In the 10th picture, rotational connectors have been added around the outside of the escape wheel. The purpose of these is to make sure that the slots to the left are tight, so that when the 'teeth' are inserted (see the penultimate picture) there will be minimal flexing when a tooth hits a pallet.
The last picture shows that the escape wheel teeth are staggered, but it won't matter because the pallets will be three connectors deep.
Step 2: The Pallets
Like the escape wheel, there must be no flexing of the parts, otherwise some energy will be lost. By the time the weight's energy has reached the escape wheel it is very weak, but that is all that is required to give an impulse to the pendulum to maintain its swing (as long as it doesn't get depleted through unnecessary flexing somewhere).
The fourth to sixth pictures show the assembly of the pallet block. This is one of the few places where some K'Nex pieces had to be cut. The top front of the orange pallet was found to have struck the teeth of the escape wheel, only slighly and hardly noticeable, but it is better avoided. The 6th picture shows exactly where the cuts were made.
Step 3: The Crutch
The crutch is the part of the escapement which slots into the pendulum.
In the picture above, the assembly will be attached to the pallet block and the blue rod will hook into the pendulum.
The first two pictures show, respectively, the front and back of the structure which will hold the escapement assembly.
The front side of the escape wheel has on its axle two silver spacers and a blue spacer. On the rear side is a tan clip gripping the escape wheel and three silver spacers.
The front side of the pallet assembly has on its axle three silver spaces, and on the rear side are two silver spacers and a blue spacer.
The pendulum will be done in Step 8.
In the first picture it can be seen that the escape wheel shaft has on it an empty section equivalent to the length of three silver spacers, a tan clip attached to a blue gear, and another tan clip attached to a blue gear; a blue spacer.
The large yellow gear shown in the 1st and 2nd pictures has a K'Nex ratchet attached to it.
The axle shown in the 3rd picture will have a lot of torsion on it between the red and yellow gears because of the heavy weight driving the red gear. The assembly has therefore had to be strengthened with four 4.5 x 60mm screws.
Part of the side of the clock has been added, but the important aspect of the next few pictures is the train of red gears which will connect with the winding spool (which will be higher up).
The last picture shows the spacers, tan connectors and red gears from the side.
Eight yellow rods need to be slotted in to three white connectors. The first one is easy; the adjacent ones are harder. All goes well until there is one left. This is a pig, because there is no longer any flexibility in the adjacent (occupied) slots.
The best way to do it is to lay the eight yellow rods along the slots and then lay a red rod on the top of the yellow one. Now use a vice (or a pair of strong hands) to push the red rod down onto the yellow rod, thus clicking it into position.
The spool is another example of where the K'Nex pieces need to be reinforced. Two 4.5 x 60mm screws have been used, shown in the 4th picture.
A structure will need to be made to support the weight, as shown in the 5th picture.
Note that in this mock-up there is only one weight and just a single pulley on top of it. In the grandfather clock in the first video there is a more complex pulley system - see the next step.
A pulley is normally used to gain a mechanical advantage where, say, a 1lb force can be used to lift a weight of 4lbs, but with the pulling end of the rope moving four times as much as the weight end.
In a traditional grandfather clock the mechanical advantage relates to the winding: for every inch of cord wound onto the spool, the weight only rises half an inch.
As depicted in the PDF above, in the clock in the first video there are two pulleys (actually, 25mm K'Nex wheels) on top of the weight and a fixed pulley at the top of the clock directly above the weight (see the 3rd image). One end of the cord is fixed at the top of the clock on its side. The cord then goes down to the first pulley on the weight, up to the fixed pulley, down again to the second pulley on the weight, and up to the winding spool via another fixed pulley at the top of the clock. The result is that for every inch the weight falls, four inches of cord are unwound from the spool. This mean that when the weight falls the full height of 78 inches, the cord unwinds 312 inches. This, combined with the fact that the escape wheel has 16 teeth rather than the obvious 8, is how the clock can tick for so long on a single wind. Another factor is that the cord (which is very strong fishing line) is very thin so that there is very little overlapping on the spool (this would increase its effective diameter and thus use more cord for each revolution).
In the construction in this Instructable there is just one weight with a single pulley on top of it (see the last image).
One of the advantages of a grandfather clock is its excellent timekeeping, mainly due to the long, slow-swinging pendulum.
For a one-second beat the centre of gravity of the pendulum must be around 39 inches from its top.
The first picture shows the basic design of the one for this clock. In the first video, at around 1m 33s, the full pendulum can be seen. It's a little more elaborate than the ones shown in the picture because it has a couple of wheels on it to make the tick even, and there is a regulator on it.
The fourth picture shows how the pendulum is supported, and the fifth shows the spacers required on the pendulum's arbor.
The power from the weight is transmitted to the hands via a gear train.Minute-handarb
The first picture shows the red gear which lies directly above and is in mesh with the blue gear of the escape wheel shaft. Let's call this the transmitter.
The second picture shows a spindle which has on it a white connector with eight prongs on it. Let's call this the receiver.
As the escape wheel rotates, once in every revolution the transmitter will knock the receiver. This arrangement creates the 8 to 1 ratio that we need as part of the near-one-second beat, but it also has another very important function: when the transmitter and receiver are not in mesh (which is most of the time), there is no direct link between the escape wheel and the hands, meaning that the hands can be moved freely.
The third picture shows the red gear which is in mesh with the blue gear of the receiver assembly, and the fourth picture shows the next step in the chain. The fifth picture shows them all put together.
The sixth picture shows the view from the front and the seventh picture shows another view from the side.
The minute-hand shaft is shown in the eighth picture, the ninth picture showing a side view.
Finally, the last picture shows a view from the front.
It is here that the 84-tooth yellow gear comes into its own. In combination with a blue gear there is a 6 to 1 ratio, and so if it is combined with a 2 to 1 gear ratio the required 12 to 1 ratio will be achieved.
The 2 to 1 ratio has been achieved by using a pseudo-8-leaved pinion (see picture 3) in combination with a pseudo-16-tooth gear (see pictures 8 to 10)
The pinion has to be built onto the black minute-hand arbor because there are two rotational connectors inside it (see picture 3). It is shown fitted in pictures 4, 5 and 6.
Picture 7 shows the black minute-hand arbor with two blue spacers and two rotational connectors on it.
Pictures 8 to 10 show the construction of the pseudo-16-tooth gear, and picture 11 shows the minute-hand arbor which it will be fitted to.
Picture 12 prepares the assembly for the hour hand.
To fit the minute hand a tan connector is fitted to the black arbor with the prong outwards, and a black connector is pushed onto it. It is held in place by a blue clip.
It is very important that the hands are balanced. Only a little force is imparted by the escape wheel teeth, and if a hand is heavier or lighter at 9 o'clock than it is at 3 o'clock, it could cause the clock to stop. The hands' counterweights are made from lead - there is no K'Nex piece that is heavy enough to be elegant.
The penultimate picture shows a red gear with a ratchet on it. This red gear is on the end of the arbor of the 'receiver' as described earlier. It prevents the receiver from being jogged out of position as the clock ticks (which could cause a jam).
The last picture shows the clock with the hands fitted.
In the picture, the red gear on the bottom right needs to be turned anticlockwise in order to wind the clock.
In the first video, at 2m 38s, the clock is being wound. There is a red gear at the bottom with a white connector in front of it. It is the red gear to the top left of it that is being turned anticlockwise.
The clock is wound using a 12v K'Nex motor. The shaft with the red gear / white connector on it has another red gear behind it in mesh with a blue gear. It is the shaft with the blue gear that has the motor's white gear on it (this is driven by the motor's worm gear).
The motor's worm gear must be engaged with the train of gears before winding, and then disengaged afterwards.
In the video, at 2m 5s, a lever is moved to start the winding. This turns on a micro switch and engages the worm drive at the same time.
When the weight has risen to the top, a micro switch is activated which diverts the current from the motor to a bell to give a warning that the lever is to be returned to its original position.
In the grandfather clock in the first video (but not in the mock-up in this Instructable), there is a crude power-maintaining device which keeps the clock ticking while it is being wound. It consists of a small weight (c200g) on the end of a K'Nex chain which is manually raised before the winding is started. It simply drives a large yellow gear (which is manually engaged after the weight has been raised) which is in mesh with a pinion (a blue gear) on the end of the escape wheel shaft. When the clock has been fully wound, the yellow gear is manually disengaged. See the first video at 1m 22s to 1m 32s, and see the device being activated at 1m 46s to 2m 10s.
A pendulum clock is regulated by raising or lowering the bob. This changes its effective centre of gravity.
The grandfather clock in the first video is regulated by placing a tyred wheel at an appropriate point (see the annotated picture).
In practice, the clock is a very good timekeeper, varying by only a few seconds each day.
The gears and axles must be liberally oiled, as must the escape wheel teeth. This should be done every few months. On no account must the K'Nex ratchet be lubricated in any way - it must be completely dry. Oiling it is a sure-fire way to make it stop working.
In the first video, the escape wheel was not strengthened like the one shown in this Instructable and had to be replaced with the new version; it suffered from fatigue after a year of ticking (over 32 million ticks).
It is possible that over the years other parts will show fatigue - K'Nex pieces are made from quite soft plastic.
Clocks Contest
This is an entry in the
Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Wow. Wow. Wow! Nothing like showing the whippersnappers out there how it's done. Great Instructable!
    KJ
    Wow, that's so cool!!!
    This is incredible! Highly impressed with the ambition and execution here. Well done!!
    Thank you, kind sir!
