LED 12V Camping Lights
5,640
46
17
Posted in TechnologyLeds
Introduction: LED 12V Camping Lights
About: Hi! You can call me Matt. I'm a problem solver with interests in many fields. I will try to post some of my more interesting projects when I have the time.
My dad needed an efficient light source for the inside of a camping van. The lights needed to be able to run multiple nights without draining the battery while still producing decent quality light. The following is the construction of such lights.
The lights use Cree LEDs with 90 CRI and efficiency of 110lm/W (400mA). A warmer 3000K color temperature was chosen to facilitate falling asleep at night. The light output is continually adjustable from 150lm (0.8W) to 900lm (10W) using LEDdynamics' BuckPuck 1000mA drivers. The lights also have reverse battery protection from P-channel MOSFETs.
The ears on top are for hanging the lights using paracord.
Metal Contest 2017
Runner Up in the
Metal Contest 2017
Step 1: Parts and Materials
Materials (pictures show material for two lights)
      • 1/2" aluminum plate
      • 3/4" aluminum rod
      • Acrylic diffuse 0.118" ACRYLITE Satinice 0D010 DF (left over from another LED lighting project)
      • LED emitter Cree Xlamp CXB1304, 9v 3000K 90CRI 110lm/w, CXB1304-0000-000C0UB230G
      • LED driver LEDdynamics BuckPuck 1000mA 7-32v 3021-D-E-1000
      • 220uF 25V electrolytic capacitor
      • MOSFET P-channel IRF5305PBF
      • Power jack 2X5.5mm PJ-065A
      • Cable 2.1X5.5mm 2m 10-00110
      • Power jack 2.1X5.5mm 50-00025
      • Cigarette lighter plug with 2.1X5.5mm plug on other end of cable (select desired cable length for light placement)
      • 2X 8-32 1" stainless button head cap screws
      • 2x 6-32 1/4" stainless button head cap screws
      • 6-32 1/8" set screw
      • 2X #6 plastic washers
      • 2X #6 stainless washers
      • Thermal paste
      • 4.7K ohm B4K7 linear potentiometer with ON/OFF Switch (6mm shaft with flat)
      • Two part epoxy
      • Glow-in-the-dark powder (from glonation.com)
      Tools
      • CNC mill and 11/32" end mill (min 1/2" depth of cut)
      • Metal lathe with normal tooling (for turning the knob, could also purchase one)
      • Drill press
      • Drill bits: #29, #36,1/8", 3/16", 5/16", 7/8", 6mm
      • Hex keys
      • 6-32 and 8-32 taps with handle
      • Hacksaw blade (for cutting the tabs after milling)
      • Disk sander, file and 220 grit sandpaper (for smoothing tabs)
      • Soldering iron, solder and flux
      • Heat gun or lighter (for heat shrink tubing)
      • Heat shrink tubing to cover wiring and MOSFET
      Step 2: Drawings
      SolidWorks (2016) and STL files are provided.
      box back 2.SLDPRT
      box front 2.SLDPRT
      knob.SLDPRT
      lens.SLDPRT
      Step 3: ​CNC Mill Housing
      • Clamp the 1/2" aluminum plate in the mill vice
      • Generate the G-code for the two halves of the housing (I used tabs to hold the parts in place)
      • Let the machine do its thing (11/32, 2 flute HSS end mill was used)
      • Drill the connecting holes (I only drilled 1/8" for now and finished on drill press)
      • Mark the LED fastener locations or drill them to size
      Step 4: ​Remove Parts and Smooth Tabs
      • Free the parts from the plate using a hacksaw blade
      • Smooth the tabs flat on a sander being careful not to sand too deep
      • Finish smoothing with a fine file and 220 grit sandpaper
      Step 5: CNC Mill ​Diffuser
        • Attach the diffuser material to a sacrificial back plate held in the mill vise (drywall screws into plywood)
        • Generate the G-code for the diffuser
        • Remove parts from the sheet using the hacksaw blade
        • Remove tabs on sander
            Step 6: ​Drill and Tap Assembly Holes
            • Drill box back holes (#29 bit) and LED mounting holes (#36 bit)
            • Tap box back holes (8-32) and LED mounting holes (6-32)
            • Drill box front clearance holes (3/16")
            Step 7: ​Drill Power Jack and Control Knob Holes
            • Mark the location of the holes for the potentiometer and power jack on the two halves
            • Notch the marks using a hacksaw blade (only leave a shallow cut for a drill bit to follow)
            • Assemble the two halves with 8-32 fasteners
            • Drill a 1/8" pilot hole into the notches
            • Follow the pilot holes with a 5/16"
            • Drill the center web by going through the bottom hole
            Step 8: ​Install LED ​and Diffuser
            • Apply thermal past on the back side of the LED and place into the holder
            • Slide stainless washer then plastic washer onto 6-32 fasteners
            • Install the fasteners so the LEDs are held in place
            • Slide the diffuser lens into box front
            Step 9: Wire the Insides
            • Using soldering iron attach wires to the potentiometer and power jack (remember to cover the joints with heat-shrink tubing as you go)
            • Work the potentiometer and power jack into the back half of the box
            • Attach wires to LED driver and apply heat-shrink tubing
            • Add the capacitor across the power terminals on the LED driver
            • Wire in the P-channel MOSFET and cover with heat-shrink tubing
            • Solder wires to LED
            • Work all components into place
            Optional drop cable for LED light
            The cable on the cigarette lighter can be used directly with the light but is detached easily. The drop cable screws into the power jack on the LED light allowing for more permanent attachment while still offering a separation point at the other end if excessive force is applied to the cable.
            • Cut the 2.1X5.5mm 2m cable in half and solder on the power jack (50-00025) ,
            • Cover the soldered end of the power jack with heat-shrink tubing
            Step 10: Add Glow
            • Mix enough two part epoxy to fill the voids on either side pf the LED
            • Add glow-in-the-dark powder (about 25% powder) to the epoxy
            • Fill voids with mix and let cure
            Step 11: Turn Knob
            • Load 3/4" aluminum round into lathe
            • Face the knob and add center drill mark
            • Drill 6mm hole to 0.58"
            • Drill 7/8" hole to 0.18"
            • Knurl outside
            • Part off at 0.73"
            • Face other side of knob and chamfer edge
            • Drill and tap 6-32 hole about halfway up the knob
            Step 12: ​Assemble Case
            • Screw both halves together with 8-32 fasteners
            • Install knob using 6-32 set screw (make sure it does not rub on the case)
            • Make loops from paracord to hang the light
            Enjoy!
              • Spotless Contest
                Spotless Contest
              • Trash to Treasure
                Trash to Treasure
              • Microcontroller Contest
              17 Comments
              Thank you!
              Super duper cool.
              I bet you coudl find a market for these.
              Thank you!
              Yes, but they do require some machining time.
              Nice tools! I haven't used those for years... I wish I had enough space to place them :-)
              Thank you!
              Really well enfineered product. What is the purpose of the Mosfet? If it's to stop reverse connection, why not use a diode?
              Thank you!
              It is to prevent reverse connection damage. The MOSFET has much less voltage drop when on (0.06 ohm for the MOSFET when on, V=I*R=0.83*0.06=0.05V on max or 0.067*0.06=0.004V on low) a typical rectifier diode is 0.7V. A MOSFET is a better choice if you are concerned about device efficiency. The power loss from the diode is 0.7V/12V=0.058 and the MOSFET 0.05V/12V=0.0042 (5.8% vs 0.42%).
              Thanks for your reply. I suspected as much. I've used Schottky diodes in the past for the same reason but your solution is more efficient.
              Thank you! CNC mills are not too bad to purchase if you can spend some time rebuilding one.
              Very cool lights.
              Can you please explain how they work.
              How long they run or glow. Do they charge up or do you have to run power to them all the time.
              Thanks!
              They need to be plugged into a car battery (12V), I'm using a cigarette lighter plug. On low (which is plenty of light for most things) they should be able to run for over a month of continual use before the battery needs to be charged. The glow is for finding the light in the dark and should last up to 12 hours before needing to be exposed to light again.
              Very cool lights! Thanks for sharing it!
              I'm glad you like it!
              Amazing build. Good luck in the contests. Beautifully machined, will last for years for sure!
              Thank you!
