Introduction: Lazy Lamp
Picture of Lazy Lamp
Is this situation ever freak you out that when you are ready to bed, after turning off the light, you cannot see anything. Has it ever happened to you that when you are chilling on your bed, somehow you are too sleepy to get up turn off the switch?
If so, let’s make a lazy lamp which can detective the motion( by a motion sensor) and volume(microphone) of your room. So if you are getting sleepy, and stopping moving or making any sound, the lamp will get dimmer till turn off.
Want to build your own one? Let’s go.
Tools: Wire strippers;Soldering iron;Lathe;Laser cutter;Table saw;Blend saw;(Or 600$ + 3D printing);Materials: Arduino Uno;Motion sensor;Microphone:Breadboard:Acrylic;Breadboard wires;Solder;Dotstar LED stripper
Step 1: Soldering and Connecting Circuit
Picture of Soldering and Connecting Circuit
Step 2: Coding
crucial parts of coding
if(brightness >0){if(sample >= line || motionValue == 1){brightness = brightness + plus;if(brightness>=255){brightness=255;}}
if(sample < line && motionValue == 0){brightness = brightness – fadeAmount;}} fillAll(strip.Color(brightness, brightness, brightness));if(brightness<50){delay(100);}delay(50);}
Step 3: Making the Shape of the Lamp
Picture of Making the Shape of the Lamp
1.Laser cut acrylic
a.Stripper: the width of the stripper is a little bit wider than the LED stripper, so that you can glue them on later.
b.Circles for the bottom.
2.Build dowels
a.Glue wood sheets together overnight;
b.Use table saw to cut the cuboid;
c.Use lathe to make your own dowels;
d.use blend saw to cut them in pieces;
3. Bend your acrylic.
a.Use tape glue the pieces together and fix it with clamps;
b.Heat the acrylic;
c.Bend it;
d.Cool down;
e.Untaped
f. A little bit sanding
4. Glue
Step 4: Assembled Each Part
Picture of Assembled Each Part
tomatoskins (author)2017-12-20
What a great idea and coding implementation! I love it!
About This Instructable
419views
7favorites
License:
More by qwang11:Lazy Lamp
Add instructable to:
