Live Edge Side Table
2,991
53
7
Posted in WorkshopFurniture
Introduction: Live Edge Side Table
About: My name is Mitch. I make videos about the things I make and what I learn along the way. I have a Youtube Channel called Made by Mitch. I also love the coffee and the outdoors.
A few months ago my wife found this stump side table with hairpin legs from on online store. It was a great looking table but the only problem was that it was $250 dollars. Since I love making things, I was up for the challenge of replicating this table. I made my own version of the same table for under $50 dollars. It was a lot of fun and I learned a lot of stuff for this project. I hope you enjoy. Up front I want to tell you that making this for under $50 dollars is assuming that you have the tools necessary to make it. A lot of times, if there is a tool I don’t have to make something, someone I know is usually willing to allow me to borrow it and that is the case with some of the tools in this project. So if you don’t have a chainsaw or some of the other tools in this, know that I don’t either, but it is still possible.
Step 1: Tools and Materials
MATERIALS
TOOLS
Affiliate links are used on this page. Thank you for your support!
Step 2: Find Your Stump
Since I knew the look I was going for for this table, I searched around some of the wooded area close to my house and found a decent tree that had fallen and been down for a year or so. I knew it had some time to dry out a bit, so I cut it up unto cookie slabs to use for the table. If you don’t have something like this you can just grab close by, you could always try to call a saw mill or find a lumber yard. There are also online stores that sell slabs like this. They can get expensive, but it is possible. Once you get the right stump/cookie you are looking for, you will need to let it cure for some time if it hasn’t already before prepping.
Step 3: Flatten Your Stump
After your stump is ready to go you can begin the flattening process. For me this was a mixture of hand planing, sanding, and using a router sled to flatten. I have a video on making a router sled if it is something you need to do this project. The router sled basically allows you to flatten the stump without needing a planer. This works great especially if you don’t have a planer to use or your stump won’t fit through the planer. As you are flattening your stump, you can use a level to monitor and check the level of your stump. I just repeated these three things until my stump was flat. This can take a long time, so don’t get discouraged in the flattening process. Also during this time, I used a chisel to get the bark off of the table and prep the sides.
Step 4: Add Bowties (if Necessary)
If your stump does not have a crack in it, then you can skip this step. As my stump dried out, it got a pretty nasty crack down one side of it. I wasn’t crazy about it at first, but I started to like it so I decided to add a couple bow ties to it, to prevent the crack from worsening.
The first step was to cut out my bow tie. Then I placed it on the stump along the crack where I wanted it to be. Once I was happy with the placement, I traced the bowtie and then I used a chisel and hammer to start taking out the wood where the bow tie would be. I went down about 3/4” for the bowtie to sit into the wood. What ended up doing is using a router to take out the bulk of the material and then I used a chisel to clean up the edges and that worked pretty well. Once my bowties were chiseled out, I glued them in and then sanded them down even with the rest of the table once the glue dried. There was a small gap around the edge of the bow tie that I wanted to fill. So I got 5 minute epoxy, mixed it with walnut sawdust, and I filled this in around the edge of the bow ties to give it a nice dark line to almost highlight the bowties. I used epoxy instead of wood glue mainly because epoxy expands a little so it filled in the crack a little better. I want to warn you though, try not to get the epoxy on the wood outside of the crack. I did, and I had a very challenging time trying to sand the epoxy off the wood. I went through a lot of sandpaper in order to get the epoxy out of the wood so avoid this if you can.
Step 5: Sand and Finish
After the bow ties were in the table, It was time to sand the table down. I started at 80 grit and went to 220 grit. I had a lot of marks from the router flattening sled that I had to smooth out, so the 80 grit made quick work of this. Next I applied finish to the piece. I chose polycrylic from minwax. I like this finish because it is water based and it goes on a little thick. I thought it would do the best with filling in some of the stump’s imperfections.
Step 6: Attach the Legs
Once the table was all finished, I installed the legs. I used ¼-20 insert nuts with a hex head to mount the legs to the table. These are simple to install. First I set the legs where I wanted them to go and marked the drill spots with a pencil. Then I drilled a hole for the insert nuts to be installed into. I made sure to not drill too deep when I installed the nuts. I used two different sized bits to be sure I wouldn’t harm the table or mess anything up. After drilling the holes, I installed the nuts with an allen wrench. Once the nuts were installed, I could screw the legs on the table and that was it. The project is complete.
Step 7: Enjoy
This was a very fun project to do. I learned a lot of things doing it and I will probably try to make more of this type of thing in the future. I really like the table legs I used. I will for sure be using them again. I have a link in the materials section for the exact legs that I purchased and you can also get the hardware I used for them as well. Let me know if you have any questions about this table. You can check out the video to go along with this to see exactly how I did this.
You can also find me on YouTube along with many other projects.
My Website (madebymitch.net)
Instagram
Twitter
Pinterest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    Well done, i made a similar side table (partial live edge) but used only three legs, this prevents it from rocking on an uneven surface. Btw, my first welding experience was creating the three hairpins. Great and simple way to be introduced to welding, and extra bonus, you don't see the welds :-)
    7 Comments
    This is very simple and beautiful. Well done! Everything is around us. It's just fantasy and desire.
    What do you mean by live edge?? That is the only thing i do not understand...
    Yea like prid1 mentioned this means it is the outside of the actual tree. It isn't cut or squared off like a board. Hope this helps.
    I think thats the natural outside of the tree but without the bark.
