Murphy Bed
921
27
Posted in WorkshopWoodworking
Introduction: Murphy Bed
Hi everyone! This is my first time writing an Instructable and have learned a lot and gotten ideas from other users here. This project was also the largest build I've done to-date. When we purchased our house we also purchased some of the furniture along with it. As part of that was a very large oak entertainment center. This piece was very nice, but it was custom built for the old rear projection big screen TVs (that were huge and weighed a ton). Since our flat screen would not fit in the space, I decided to build a different TV stand and turn this piece into a murphy bed.
There are kits that you can purchase that come with plans and all the hardware, but I chose to go a different route (mainly because I'm cheap and I wanted to challenge myself). Since this was a custom project and I didn't use any plans, I haven't included any measurements. I mainly intend this to give others some ideas if attempting to do something similar.
Step 1: Demo Time
To give an idea of what the entertainment center looked like beforehand, here is a picture. We had to downgrade the TV and get one to fit in that space (I wasn't too happy about it, but that's OK). After a while and a tax refund, we purchased a bigger TV and it was time to move this behemoth out and start the demo process. I didn't get any pictures during this, but basically just cut out all the inside panels and removed the doors/shelves so all that was left was the outside panels.
Step 2: Bed Frame
When everything was removed from the inside of the cabinet, I made a simple shelf to store sheets/pillow/lamp. This was done by re-using some of the panels that were removed and securing with pocket holes. I built the bed frame (sized for a full bed) using pine boards and oak. The pine boards were glued and screwed together in an L shape to add strength. Once complete the bed frame was attached to the cabinet using boat seat swivels as seen in picture #6 (I got this idea from a couple YouTube videos I've seen and they've been working out great).
I made a door using oak boards and raised panel cabinet router bits and attached it to the right side using 3 soft close inset cabinet hinges.
Step 3: Face
Next I made a false front that will be attached to the bed frame using oak boards. I determined the dimensions of the overall face and used that to determine the dimensions for each panel. The rails and stiles are 2.5" wide. I edge glued the boards together and cut the panels down to the correct measurements. Using the raised panel router bits, each piece was cut.
After it was all stained and finished, I glued the rails and stiles in place going 1 at a time to ensure that everything was square. The raised panels are not glued in and are left "floating" to account for wood expansion.
Step 4: Flip Out Feet
Once the false front was complete I cut out holes where the feet would go. I attached the bed frame (without the false front) to the cabinet, lowered it down and supported it so that was level. From this I took the measurement to the ground. This measurement will be how long the feet needed to be minus 3/4" for the false front. The feet were cut from oak boards and stained to match. They are attached using inset cabinet hinges. I attached these so that when the legs are flipped out, they rest against the false front. That way all the weight is resting on the feet and not on the hinges.
After the feet were in place, the bed frame was attached to the false front
Step 5: Install
At this point it was ready to be moved into place. Unfortunately it was too big to fit through the doorway in the intended room because the hallway was too narrow to turn it correctly. So I ended up having to cut it half and reassemble it in the room. I made the cut to be even with the middle rails to look consistent.
The 2 halves were brought in and the bed frame was attached to the bottom half. Stringer boards were screwed to both halves to add stability and also to secure to the wall to prevent it from tipping over. Once everything was in place, I cut some 2.5" oak boards to cover up the sides where the cabinet was sawed in half.
150 lb gas struts were used to assist with lifting and lowering the bed. They made a huge difference, but it can't be lifted/lowered with 2 fingers like some of the demo videos of the actual kits. However it makes it light enough that my wife can do it by herself.
Thanks for checking it out! Please leave some comments or questions.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
    This is awesome! I love murphy bed designs. Such a great way to save space!
    Thanks! It was a fun build. My 6 y/o nephew didn't believe there was a bed in there when he first saw it.
