Pallet Wood Flower Box Planter
3,382
95
7
Published
Introduction: Pallet Wood Flower Box Planter
About: I am a digital designer focusing on creating motion.
This Flower Box was crafted from old pallet wood. It is a economical and characteristic solution to give your garden flair. We have searched the neighborhood for old pallets and then dismantled to use it for the flower box.
I want to thank Sven for the help in designing and building this this Flower Box.
Material:
  • 100 screws of 4 x 40mm
  • Pallet wood
  • Root Cloth
  • Cordless drill
  • Hand saw
Step 1: Flower Box Design
Here is the building plan showing how we can use all the pallet wood for the flower box.
Step 2: Saw the Pallet Wood in the Right Size
This are the 3 different sizes of wood you need saw including the sizes in Millimeters
7x 405 mm x 135 mm
4x 445 mm x 135 mm
8x 500 mm x 67.5 mm
You can use the excel sheet to calculate the lengths you needs. Be sure to double check however before you start cutting your planks.
Step 3: Screw the Wooden Frame of the Flower Box Together
This picture shows how planks of the sides look together.
Step 4: Complete the Wooden Construction
The picture shows the complete wooden construction.
Step 5: Attach the Root Cloth Inside of the Flower Box
In order to ensure that the soil and the roots of the flowers remain within the flower box, we use root cloth and staple it on the inside of the flower box.
Step 6: Fill the Flower Box With Fertilized Soil
We have used special fertilized soil to fill the flower box so that we can be sure that the flowers can grow well.
Step 7: Plant Your Favorite Flowers in the Flower Box
Now it's time to put your favorite plant in the flower box and quietly enjoy your garden.
Planter Challenge
This is an entry in the
Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    7 Comments
    Top marks!
    I've been looking for a practical raised-bed-on-legs for ages; found plenty of impractical ones! Have some pallet wood, not sure about lengths, but maybe enough for a planter slightly larger or slightly smaller.
    I voted for this! Nice and simple and perfect instructions! I like it! Easy enough for me to do with my tools.
    I would suggest adding a frame around the top to give it a more finished look and also protect the end grain of the vertical pieces. Good project!
    As suggested I would make them 8' long. Was thinking about using wire mesh for the bottom with the root cloth over that. It might help with drainage some and be less wood to rot. We are not planning to stay where we are for more than a year and these would be easily hauled to where ever we move to. Also easier on the back, as someone said.
    I want to do this one! I'm in Florida, hot and humid. I will paint(at least the inside) with polyurethane to prevent rot. Also add something between the wood and cloth to create a bit of air space to keep the moist soil away from the wood. Not sure what yet. Hardware cloth, trash fence . . . ? Maybe a layer of plastic sheet?
    Great planter! If you just lengthen one side it could be nice big raised bed for those of us with bad backs. Good luck in the contest.
    What's really nice about pallet wood is the distressed look built in. Your planter came out very nice.
