Introduction: Pellet Fed Rocket Stove
Picture of Pellet Fed Rocket Stove
Rocket Stoves, combined with Wood Pellets for fuel are an excellent match. Rocket stoves were invented in the early 1980s and were originally developed as a solution to reducing deforestation in third world nations that consumed wood for cooking and heating. Their clean burning nature also helps reduce health problems from inhalation of smoke and carbon monoxide associated with poor combustion from traditional open fire pits. Today, Rocket Stoves are the answer to anyone, anywhere wishing to reduce dependence on fossil fuels and central power distribution to heat their home. Properly designed, Rocket Stoves require no external power to operate and can run constantly with only occasional ash removal as maintenance. No moving parts to wear out means years of dependable service. Further additions of copper piping can distill water or be the source for a hydronic heating unit. Add an additional flat plate of steel and cook your daily meals using Sustainable fuels like wood pellets or other forms of biomass can add to your fuel diversity. Connection to a Stirling Engine linked to an alternator can generate electricity and charge a battery bank as an added bonus and icing on the cake for any Homestead!
It is time to become energy independent and Rocket Stoves appears to be a part of this plan!
Rocket stoves like to run hot and as a result they burn clean. Add a fuel with a consistent heat density delivered in small pellets, it is possible to have a small stove generate a lot of heat with a small footprint. Rocket Stoves are efficient and wood pellets are a Sustainable Resource; a win - win right from the get go! Using relatively inexpensive construction materials, one can build a pellet stove that efficiently heats a room and can continue to heat the room using it's "banked heat" long after the stove has burned the last pellet in the hopper.
After many hours of sifting through what seemed to be every version of a rocket stove on the internet, I got tons of ideas on what my stove needed to do.
It needed to:
1) Be Safe. Safety with fire is always paramount. I also wanted to keep most of the high heat area out of the reach of children as this stove would be in a kitchen / living room open concept. So the decision to make the body of the stove out of Refractory Cement. The cement does get hot to the touch but not like the side of a conventional steel wood stove. Also, an added benefit of the cement is that it slowly radiates heat for hours after the stove is off.
2) Be Small. By Small I mean economically heat a 650 square foot area and do so with a constant output. I did not want large temperature swings, so a small 2" x 2" firebox. Most pellet stoves are designed for over 1300 square feet and that is twice the stove capacity that I needed. The other small is small footprint. The base of this rocket stove is 12" x 12" and utilises vertical space to it's advantage; using 5' of vertical space and one square foot on the floor.
3) Be the Curiosity Focal Point in the room; OR at least, Be a topic of conversation in a warm environment! Yes, there was an Executive Order (from my wife) that the Stove be painted Pink!
4) Be economical. Original design consideration was for the stove to run from 8am to 8pm. Shutdown each night. Clean out of ash box each morning. A 40 lb. bag of pellets sells locally for around $8 Cdn. This stove burns a pound an hour ; so operating costs is $2.40 per day of comfortable, eco-friendly, sustainable heat. Not a single dinosaur was hurt, except for the transport of the bags of pellets from the big box store to home.
5) Be easy to install. Pellet Stoves can be vented straight out a wall with 3" insulated pipe and a 4' Rise.
I chose to go with a design that started with the smallest metal burner that could hold a pellet basket and manage to handle the largest advertised pellet length of 40mm. Then a cast refractory cement body for safety and the thermal mass component. Finally a 30 lb modified propane cylinder to be the Heat Bell before exiting a 3" insulated flange to outside exhaust stack.
I am grateful for my wife for her faith and patience in the development of this rather unique method of heating our home. My gift to her. I also wish to gift this design to the approximately one billion people on this planet that still rely of biomass for cooking and heating their homes. I also gift this stove design to anyone wishing to strive to a more sustainable carbon - neutral fuel resource.
Step 1: Introducing ..... Franken Stove: My Pellet Fed Mini Thermal Mass Heater Rocket Stove!
Picture of Introducing ..... Franken Stove: My Pellet Fed Mini Thermal Mass Heater Rocket Stove!
Here is my version of what I call "Franken Stove". Although the Rocket Stove and Pellet feed hopper are easily recognisable, a fabrication style that has hints of Steampunk Design giving it the aura that this item may have been pulled out of an Industrial setting. Here is a YouTube link of the stove in action: www.youtube.com/watch?v=KpnZwKVNzbQ. If the link does not work, try a search using the title: Pellet Fed Rocket Stove / Rocket Mass Heater- “Franken-Stove”. Here you will see a video explaining the finer design parameters. Oh, and by the way, I did get that wall receptacle cover installed! Thanks for your concern.
To achieve this look I chose to combine metal fabrication for the burner, hopper and Heat Bell but with a casting of refractory cement to make up the Cubic base of the Heater. By using Refractory cement for the body of the stove you are given the benefit of having a small thermal mass that radiates heat for hours after the stove is shut down. By continuing with refractory up into the Heat Bell the advantage of added thermal mass is obvious and an added safety measure of preventing direct contact to the hot metal pipe riser.It operates in the 250 to 300* C range, consuming approx. 500g of wood pellets an hour. It requires no electricity to operate and pellets are gravity fed from an 8 hour burntime capable hopper. It heats 650 square feet comfortably. Requires minimal supervision. Five minute cleanout in the morning is a snap and it starts up using a propane torch.
The design as described is currently operating in the 200* to 300* C range ( at Sensor location on stove). Temperatures at the top of the Heat Bell rarely exceed 250* C This is to be expected as this is directly above where the flame exits the insulated metal riser. Less than a cup of ash and unburned pellets are left in the ash bin and less than a half in the Fly Ash Jar, each morning. I also incorporated an auxilary atmospheric steam supply right behind the pellet feeder which improves combustion . This stove is preheated with a propane torch and usually takes 3 to 5 minutes to start by slowly adding pellets after the preheat. Stove usually reaches operational temperatures within 30 minutes. Air adjustment for flame optimization is by two simple metal baffles allowing air to enter the Primary (Combustion) and Secondary Air Chambers. The final ash glass, located immediately below the riser is vented with two 1/8" holes drilled in the Mason Jar; it appears to help reduce downdrafts, aid in final combustion of any particulate and keep Bell Temperatures under 550*F Indicated . It also serves as the initial preheat point for the first 2-3 minutes. I have found that preheating the riser first expedites the draft process. Usually, by the time I have the Final Ash Glass cleaned out and ready to replace for startup, the Indicated temperature is around 100*F and there is enough draft to redirect the propane torch to the Primary Combustion Tube to continue to adding pellets for the next stage of the light up process. This startup process cuts back on back draft smoke during light up.
Step 2: The Tools for This Trade!
Flux core Welder, 4.5” grinders, drill press, impact gun, wrenches, table saw, metal cut off saw, squares, levels, pipe wrench and ratchet straps.
Step 3: The Treasure Hunt!
30 lb Empty and de-valved propane cylinder (Heat Bell) NOTE: Find an Instructable on how to safely do it!
10 lb Empty and de-valved propane cylinder ( Hopper)
3" Muffler Pipe approx 32' (Riser)
Portland Cement, Bentonite Clay, Perlite, Silica (Refractory Cement Components)
Threaded Rod 3/8" bolts and washers - to hold cast body together and act as attachment points for add - ons
3' of 2.5" x 2.5" thick wall square tubing.
1.5" Flat bar - Band around the Heat Bell and part of the Burn Tray
Melamine sheet - This is the outside mold of the Cement Section.
1/2" black pipe - These are the spacers and ribs of the Refractory Cement Section of the Stove.
BBQ grill (Pellet Burn Tray)
Angle Brackets (Secure Riser to Black Pipe)
Angle Iron (Stand and Hopper Alignment)
Sheet Metal ( Air Adjustment for Combustion and Secondary )
thermo gauge. Laser Digital Thermometer - better for accurately measuring the heat profile versus one point!
1.5" styrofoam sheet - to fabricate the combustion tube to the Riser
Aluminum Duct Tape - to hold styrofoam sheet together.
Hot Melt Glue Gun - to secure the styrofoam form to the base of the Stove
Trowels - to work the cement into all the crevises in the mold
1/2" copper pipe and fittings. solder flux and solder, sand cloth - to make the afterburner / Steam Reformer
Propane torch, Mason Jar and Screw lid, Old BBQ grill for burner basket, BBQ temp gauge
High Temp Paint
Pellet Stove Exhaust Kit ( buy at Big Box Store (insulated 3" pipe))
Step 4: Acknowledgements Those Who Built Rocket Stoves Before Me.
There is a plethora of designs of Rocket Stoves and I am sure that everyone posted has served its purpose to some level of success that the original builder has desired. This speaks well of the overall design of rocket stoves in general and I have found that it is possible to glean a little knowledge from each and every builder / designer that has had the courage and determination to face the world and display their efforts on an open forum. As I write this list I am certain that I may have missed acknowledgement so if you see an idea of yours in my build, please contact me and I will be sure to give credit where credit is due. I have included a short 3:26 minute video on the overall operation of "Franken-Stove" here as many have questions on heat profiles and the travel path of the combustion gases.
I sourced mainly YouTube for most of my research on Rocket Stoves because I wanted to see how they worked. I also wanted to experience the builders point of view, how he operated his heat machine and any ideas on what he felt in his opinion made his design work better than others. I personally, have difficulty reading reams of information and retaining it. Visually, however, I have the ability to process and piece things together better. That is why I have included a video of Franken-Stove in operation so others like myself can get a better idea. I am writing an Instructable because, I feel, that I can convey more details all in one place to help save anyone else who wishes to build Their Version of a Franken-Stove. Here is my YouTube video: www.youtube.com/watch?v=KpnZwKVNzbQ
So, I wish to acknowledge the following YouTube contributors:
T2H - for giving an excellent overall view of how Rocket Stoves work and his ideas on swirling the combustion gas and the need for more oxygen addition after the pellet combustion chamber.
David s - for showing how a rocket stove can be made from square tubing on its own. Also for providing the valuable insight on having the combustion chamber ratio of 3 times the length of the combustion tube diameter. For example, The combustion tube of Franken-Stove is a 2"x2" square opening. The length of the combustion chamber after the edge of the pellet inlet tube is approx 6" before the gases hit the "T" to travel up the Riser.
Stressedout 72 - This gentleman demonstrated how to build the refractory core of Franken-Stove. I regret not heeding his recommendation for the drying time required for this type of cement in colder temperatures.
Step 5: Heavy Lifting - the Building of the Thermal Mass Block Box
Picture of Heavy Lifting - the Building of the Thermal Mass Block Box
The Refractory form for this project measures 12" x 12" x 12". Melamine makes a good form as it acts a mold release when the cement mixture is dry and set.
On the Front Face cut a 2.5" x 2.5" square hole that will fit the Fire tube. Also drill 4 holes in each corner for the addition of 1/2" black pipe spacers and threaded rod. Drill additional holes for the Burner Tube mounting bolts. Weld rebar to each black pipe to give the refractory strength and to affix the Riser Tube for strength and security.
Take 1.5" styrofoam sheet and cut 3" wide strips. These strips are used to make the square channel way Tee that allows for an ash bucket below the Fire Tube ( this is a secondary ash trap to catch fly ash) and the draftway into the metal 3" pipe riser above. The part of the Tee that fits into Burner Tube will need to be shaved down a bit and the corners rounded to fit into the 3' riser pipe. Fix the pieces of styrofoam using aluminium duct tape. This will burn away during the first burn of the stove. Hint: for a faster initial burn out, Dado out a 1/2" channel way and make the burn out from the top of the riser down. The styrofoam will become it's own feed fuel and the 1" x 1" hole in the styrofoam will be the supply air. This will also slowly preheat the Refractory which is the best way to initiate a burn to condition this material for higher temperatures. It is difficult to see this relatively small but important part of the build but if you look closely, you should be able to see it in the pics.The second pic from the left shows the best angle. Observant viewers will notice the old 45 degree incline on the first fab of the pellet tube feed on the original burner assembly. A steeper, more vertical feet tube was retrofitted as pellets hung up too much on the lower incline.
Insert the Burner tube into the mold, fit the styrofoam Tee into the Burner Tube and hot melt the secondary clean out end of the Tee to the melamine base.
The Mold is now ready for the Big Pour. Dry Mix a equal amount of: Portland Cement, Silica Sand, Perlite and Bentonite Clay. Add water and mix to a wet sloppy consistency using a drill and cement mixer attachment. As the area is quite busy with reinforcing rods, styrofoam channel ways and metal riser, it will be necessary to use thin rods to poke the refractory mixture all around to float in the mix. It is easier to do this with a sloppy mix but one must allow more time for drying and setting.
Pour in wet mix and float in the mixture all around the metal bars and be careful not to contact the styrofoam Tee as this may dislodge it from its contacts and the work will be lost. Pour to top of box and let sit. Be patient as it may take a few DAYS to set and dry. If you do not let it dry the the work will crack on first firing and you will be left with a lesson on patience the hard way. I was guilty of this on my first stove; Learn from my impatience, unless you wish to make two stoves!
Step 6: Modifications.
Picture of  Modifications.
Modifications are normal in the build design process. Here are two worthy of mention on this build.
Modification 1. Steam Reformer to Afterburner.
By attaching a 500 ml Stainless Steel water bottle to the Burner Assembly, it was possible to heat water via conduction to boiling. By allowing this steam to super heat as it is drawn into the Afterburner, a better burn pattern was observed by looking down the Heat Bell. Burn Temperature stabilised to 550*F and the throat of the pellet basket appeared to stay clear of ash. This idea came about from a video of a rice husk rocket stove using water / steam injection to improve combustion. A photo of the Steam Reformer can be seen above. As it is in tangential contact with the outside of the combustion tube, the water in the stainless steel bottle gently boils and is drawn up into the copper pipe and into the afterburner inlet. The water generally last as long as the pellets in the hopper. This happened more by chance than design. It’s better to be luckier than good I guess! There are also two photos of the flame pattern that show the difference with the addition of steam to the afterburner. The photo with steam addition is a bright ball of orange -white flame whereas the photo with the orange tounged flames is just air entering the afterburner inlet. It may seem counterintuitive that Steam aids in combustion but that is all part of combustion chemistry.
Modification 2. Pellet Feed Tube Angle.
The Pellet Feed Tube angle was modified to allow for a more vertical pellet feed. The angle of the pellet feed is 22.5* off vertical and an ash tube was then incorporated to have better Secondary Air Flow and a larger ash compartment.
Modification 3. Pellet Basket.
Pellet Baskets are important to bring Pellets, heat and Oxygen all together so you get an efficient burn. It is necessary to have a simple design to allow the pellets to fall, burn and decrease in their size and ultimately fall into the ash box. This is very difficult to do in a 2" x 2" square metal tube. It is here where the most revisions and trial and tribulations took place. The only suggestion I have for you here is to build two identical pellet baskets and slowly modify one at a time and observe the results.
Modification 4. Secondary Ash Container.
I really wanted to observe what was going on in the Heat Riser. The original way to watch was to look down the 3/4" NPT plug on the top of the Heat Bell, but doing so hot gas would rise up and into the room and was inconvenient as I would have to climb up a step latter every time I wanted to make an observation. By Installing a glass secondary ash container directly under the Heat Riser, I managed to solve three problems with one modification: 1) I could catch light ash that would end up in the Heat Bell. 2) I could get a reflection of the flame travelling up the Heat Riser. 3) By drilling 3 small holes in the glass with a diamond drill, I could add a little more air and have it preheated exactly where it was needed. This also appeared to prevent down draft puffs of smoke. Another unrelated benefit of the Secondary Ash Container is that it gives a better start preheat inlet as it is necessary to use a propane flame to start these Rocket stoves.
Step 7: Building the Burner Tube Assembly- Weld 'Em and Grind!
Picture of Building the Burner Tube Assembly- Weld 'Em and Grind!
The Burner Tube Assembly consists of:
1) Combustion Chamber also known as the Primary Air Inlet - This is the horizontal tube where wood pellets fall into and burn in an intensely hot chamber
2) Ash Container which doubles as the Secondary Air Inlet - Directly below the Combustion Chamber there is a hole where ash and small pellet embers fall thru the Pellet Burn Tray. Secondary Air travels up thru this ash and ember pile; continuing to burn what is left and supplying hot additional oxygen to the burning pellets
3) Pellet Feed Tube - Pellets feed via gravity down this to find their way into the Pellet Burn Tray.
4) Pellet Burn Tray - This holds the burning masses of pellets until they are small enough to fall thru and end up in the Ash Container. The design of the Pellet Burn Tray will probably be the most difficult task to get right as it is here where everything comes together for an efficient burn. Pellets must fall freely into the basket and not get hung up in the Feed Tube. They also must not crash down and choke the throat of the Combustion Chamber. Yet the embers that fall thru the Burn Tray cannot choke the Secondary Air Inlet either. I spent many hours and many Burn Tray configurations before I came up with the reliable design that I am now using. I still have a few other designs I'd like to try but it ain't broke yet so I will write an Instructable instead!
5) Afterburner Air Inlet - I found that there was a need for even more air required to efficiently burn the pellets. Many designs I viewed cut a slit behind the Pellet Feed Tube to allow more air past the Pellet Burn Tray. However, if the slit was too large, wisps of smoke would push out during a start up or on exceptionally gusty days where a sudden downdraft would temporarily reverse flow. To solve this problem I drilled two 1/8” holes in the fly ash jar and have noticed no wisps of smoke after this revision. I suspect that this additional air is required to burn the pellets that are experiencing pyrolysis just above the pellets in the Burn Tray. That is why I call it an Afterburner Air Inlet; you are adding superheated air ( or as I now use: superheated steam) to unburned fuel behind a combustion chamber (just like fighter jets ( but less glamorous and a lot slower and quieter)). Mounting Bar - Secures the Burner Tube Assembly to the Thermal Mass Base.
Cut pieces of Square Tubing on a Metal Saw. This makes for pieces fitting together and welding together better. Some cuts will have to be made with a hand grinder. Ensure that there is nothing for the pellets to get hung up on as they transition from the Feed Tube to the Pellet Tray.
As mentioned earlier, the Pellet Burn Tray is the most difficult part of the build as it is here where everything comes together; Fire, Air, Fuel. The spacing of the Pellet Tray has to be made such that there is a balance as to what will fall thru and when. Many designs of Pellet Fed Rocket Stoves fail at this stage. There is an art to these designs; I have found a design that works on a 4 square inch fire face. It may not work on any other size fire. Another consideration is the material kind of material to fabricate this Tray. Due to extreme heat in the Fire Zone, I found that BBQ grates work well and can be welded reasonably well if you grind off the porcelian coatings. The grates I found were triangular and have held together well thru many heat cycles. I also found that perforated stainless steel can be used in the design to slow the fall thru rate of the pellets and help direct airflow in this critical area. Refer to Pictures of Burn Tray. The Burn Tray has small spacers on it's base to allow combustion air to travel under the burning pellets.The Burn Tray sits directly over the Secondary Air Inlet and the feet of the Burn Tray straddle this opening. Sliding the Burn Tray slightly forward decreases feed rate of pellets and lowers burn rate and operational temperature slightly.
I chose to add superheated steam to the afterburner inlet because at high temperatures the steam dissociates to H H O and reacts with any unreacted carbon in the exhaust stream. Also I am denying the addition or nitrogen that is present in the air from entering the combustion chamber. This lowers the risk of producing Notrogen Oxides or NOx gases.
Step 8: Sub - Assemblies: Pellet Basket, Afterburner, Spy Glass, Fly Ash Containment
Picture of Sub - Assemblies: Pellet Basket, Afterburner, Spy Glass, Fly Ash Containment
Here, I will talk about four of the unique pieces of Franken-Stove that come together to make this stove work so well.
1) Pellet Tray- The Pellet Tray is a very important component of the Rocket Stove. It is here where Fuel, Heat and Oxygen all come together for the Combustion Dance. The Pellet tray must fit inside the Combustion Tube with close tolerances so it can slide forward into the Combustion Tube and slide backward for removal and cleaning. This forward and aft movement over the Secondary Air Tube give some adjustment to the Rate of Combustion and ultimately the Indicated Temperature and overall Performance of the Rocket Stove. The fingers of the Pellet Tray are made from high Temp BBQ grills. Spacing is wide enough to let pellets drop into the Vee but not too wide for them to fall straight down into the Secondary Air / Ash box. Many versions were tried to get to this balance right and let the small embers fall thru. I strongly recommending building several and experiment with them and modify one thing at a time and see if it gives an improved result. The pellet basket above works well with long wood pellets. It tends to allow small pellets to fall thru and clog up the Secondary Air / Primary Ash Containment. You may need to build several Pellet Trays to work with different brands of wood pellets. All wood pellets are not created the same. It is here where I found the need to have a visual as to what was going on so I designed the next unique part.
2) The Spy Glass- The Spy Glass is a Magnifying Glass wrapped with a Bike chain and mounted to the Primary Burner Tube. It gives the operator the ability to watch what is going on in the Pellet Basket where Combustion is taking place. The chain gets warm to the touch but is manageable as the glass is hotter. Being able to see the fire is a welcome option with Rocket Stoves as the burn chamber is usually hidden behind a metal door in almost every design I have seen.
3) The Afterburner Assembly- As the wood pellets experience the extreme heat in the pellet tray, they begin to pyrolize and disintegrate into gases. By adding an opening to allow heated combustion air (or steam) downstream of the pellet basket, hot oxygen rich combustion air is introduced and allowed to combust any unburned material as it travels up the riser. This makes for a hotter flame an a cleaner burn. By positioning the inlet of the afterburner near the inlet of the Secondary Air, smoky downdrafts are prevented and the air is allowed to be heated by thermal radiation from the hot metal burner. Measurements from an Infrared Digital Thermometer have observed over 100 degrees F increase over the inlet air. The Afterburner is now piped to an Atmospheric Steam Generator which improves combustion and provides HHO into the high temp region which facilitates a cleaner burn.
4) Fly Ash Jar - Located directly under the Riser, the Fly Ash Jar preformes three tasks. First, the Jar catches any ash or embers that are too heavy to travel up the Riser. Second, it adds a small amount of cooling air (small 1/8" hole drilled in glass jar, see pic) to travel up the Riser and keep a strong draft continuing up the riser. Finally, it gives a reflected view of the flame travelling up the Riser. A small stainless steel cup prevents embers from resting directly on glass to prevent cracking. The Jar is threaded to it's metal ring which is secured to the base of refractory cement using cement screws and high temperature silicone.The metal ring is crimped to the flat sheet metal that is secured to the cement base to allow for threading and unthreading. The 3" x 3" hole is a result of the styrofoam "T" cast in the firebox during the cement addition.
Step 9: Suggestions for an Even Better Franken-Stove
Picture of Suggestions for an Even Better Franken-Stove
Hello World!
It has been just over 24 hours since I posted this Ible and have already had over 2k views! I’m Honored that there are so many of you out there that have an interest in my creation. Once again, at 9238 views! I have made some changes to this Instructable, mainly the addition of the problematic original video and some dimensions a few steps below at the end.
I have a few suggestions for those who wish to make one for themselves....
1) Go Vertical!
It is worth an extra cubic foot of refractory cement as the heat dissipation will last longer and you can do the whole pour at once.
Because...... my vertical refractory column is just slightly off vertical. I also had to do a second pour for the lower part of the 30 lb Heat Bell
2) Make it your Own! Ceramic tiles pre mounted (inside the form) will bond nicely to the Portland cement in the mix.
Invest in a diamond 1”boring bit and pass the support rods thru the whole mold to prevent it from bursting apart under the weight of the refractory.
A boring bit can be found for under $20 at any decent hardware store. Absolutely worth it!
Because..... glazed ceramic accepts heat resistant paint readily and the tiles you choose add a personal touch!
3) Don’t fight Gravity!
Engineer your pellet feeder to drop pellets vertical. Everything in this stove gets hot eventually and if there is something that gets included in these wood pellets while they are being manufactured ( like a piece of plastic) it may fuse to the surface and begin the log jam. (Which shuts down your Toasty paradise. )
And Because....the increased length of the Primary Combustion Chamber will also improve the combustion characteristics. I read somewhere (but forgot where) that the length of the combustion tube should be at least three times the diameter of the combustion opening. ( I seem to remember a gentleman on YouTube by the name of David S referring to this ratio)
4) Let’s get Flexible!
The bolt-on nature of the Burner Assembly allows for different fuel sources. Designing a Burner Assembly to accept small pieces of scrap wood like construction waste and old pallets
adds another dimension to frugal heating.
5) The Dreaded Angle of Repose!
I waited a long time to get the perfect picture of pellets finding their magic Angle of Repose where the wood pellets found a way not to go down the Pellet Feed Tube. Any particulate material has its characteristic angle of repose and it appears to be around 45 degrees for wood pellets. I would recommend building rectangular pellet hoppers that had sides at 45 degrees to prevent this from happening.
New Note: I have posted a video of the Franken-Stove operational with the Steam Reformer Addition. Enjoy!
Please go to the YouTube video listed above to get a full picture of how this particular Rocket Stove operates. ?
Please subscribe for more up until contest close. Peace and be warm.
Step 10: Dollars and Sense! the Bottom Line!
The Labour of Love is Free. Given the basic tools listed and knowledge of welding this is a worthy project that should last for years with next to no maintenance.
Take your time... save even more!
Measure Twice; Cut Once ...$Priceless
Wear your PPE!
$12 Portland cement
$15 Perlite
$12 Bentonite Clay (cheap cat litter)
$35 Silica
$25 muffler pipe 3” (3’ bought from muffler shop
$25 heavy wall square tube
$00 old expired propane tanks
$20 threaded rod, nuts washers.
LESS than $150 CDN - and I think that it can even be built for less!
Operational Cost
$0.20 CDN per Hour! Given a 40 lb. bag of wood pellets are $8.00 CDN with Tax
Electricity $0.00
Are there any off-gridders out there? ??
The Sense: There is something very comforting from wood heat. There is also something to be said for being warm in your own home and not fretting over how fast that wheel is spinning on the electrical meter or gas meter or the bill from the oil truck. Not to mention the Service bill for a furnace to repair it in the middle of winter. We live in an area where winter storms wreak havoc with our electrical utility and we are now a little more prepared!
Step 11: Burner Assembly Dimensions
Picture of Burner Assembly Dimensions
Here are photos of the Burner Assembly and Associated Parts. The measuring tape is blurry in one photo but it is possible to get the overall idea on the construction of the parts in question.
I have included three pics of my light up procedure so you can get an idea how "Franken-Stove" gets fired up in short order. First, I remove the Glass Ash Container at the bottom of the Stove. I insert the lit torch in the vertical Heat Riser and heat until the temperature reaches 100*F. At this point the Heat Bell is "heat primed" an a light draft is created to the outside. Second I place my "kindling" (egg carton, wood pellets, melted wax) into the Secondary Air compartment and light it with the torch that has been moved from the vertical riser. ( the glass Ash container is obvious in place at this time). Once the kindling is burning well, the torch is then moved to the Primary Air / Combustion chamber and wood pellets are slowly introduced down the pellet feed tube. Stove reaches steady state temperature of 450* to 500* F Indicated on the Heat Bell. The far right pic shows the wood pellets introduced and the torch removed from the Primary Combustion chamber.
NOTE: You will notice that the spyglass is shattered. Yes... I did that on purpose. I was not sure if it was a tempered lens or if there was even such an animal. I did not want to have it explode in my face so I touched it with a wet rag when it was hot and the stove was running. The result is observed that it was not tempered and the crack relieved a lot of stress in the glass so I no longer worry about exploding glass shrapnel. I think it gives a little character to the design as an afterthought! :)
Although this is a Rocket Stove, one should not feel that they have to be a Rocket Scientist to build your own. I am treating this Instructable as a living document and I am adding tidbits of information as I receive feedback from subscribers and I appreciate anything that will positively help at improving the build or design. The Rocket Stove I have built has been fairly forgiving in dimensions as long as the welds hold! About the only advice I have on building the burner is to make sure it is build on a flat plane so it does not look crooked when you look at it.
RimasK1 (author)2018-01-14
This is challenge to design. Could you please add a photo from a side? All your video and photos are taken mostly from the front which is less illustrative.
GizmoGuy347 (author)RimasK12018-01-17
Hello, photos of the left and right hand side have been taken with a measuring tape to give sense of scale. I hope this helps.
charlessenf-gm (author)2018-01-12
Impressive build. Thank you for sharing.
I think you had better put a cover plate on that duplex outlet lest someone from the Canadian Fire Department sees this page and turns you in for maintaining an electrical fire hazard. ;)
What is that can thing (w/?-mark)?
Please show the 'chimney' - where does it go? (exit the room?)
I did not find a video on this page. I, too, would like to see drawings and views of front, sides, back.
Hello, Thanks for the interest. Cover plate is replaced, I removed it to paint / repair the drywall and promptly forgot. The area marked with a question mark is the pellet hopper. Chimney exits wall to exterior of structure. You can buy the 3" wood pellet exhaust kit at any big box store. I got the kit for $400 CDN, taxes in. I am having difficulty with the youtube link but if you search for "Franken-Stove" you will find my channel. Subscribe to get updates and schematics as time permits. Be Safe, Be warm!
Hi, Thanks for the interest. I'm having some issues with copy / paste from YouTube. The video title is:
a search in youtube will find it. It is 3:26 minutes long and best describes how it works.
The Thing with the ? is the Pellet hopper. Better seen in the video.
Receptacle cover plate has been installed. Outlet of stove exits the structure and is a purchased "Big Box" pellet stove installation kit.
Just a small note for those not familiar with how this stove works; it does not generate the blazing heat from the sides of the stove as the refractory cement captures the heat and slowly delivers it to the room. You can actually touch the pink walls and not burn your hand.
Thank you for your feedback and concern.
DanielS336 (author)2018-01-13
Excellent job, Ive been trying to talk my wife into a similar contraption, this is very helpful! Can i make a small suggestion that should boost the heat gain considerably? At the moment it is drawing in cold air from the house, which means the house is drawing cold air in from outside. This is a similar problem that open fires have. If you could rig up the air intakes from outside, you should be laughing.
GizmoGuy347 (author)DanielS3362018-01-14
Thank you for the excellent suggestion. I'm certain I will implement it on the next generation of "Franken-Stove" where all the modifications listed at the end of my Instructable will be incorporated with a little more "Design Flair". As a "proof of concept" model, this stove has satisfied many questions I originally had before building my first. Subscribe and dimensional drawings will be added shortly. My wife is over the moon that our living room and kitchen are nice and warm ; a recent notification from our utility congratulating us on a 30% reduction in usage (we have electric heated floors and baseboards) has also rewarded my combustion engineering credibility! I may add that the heat generated from this stove is nothing like a wood stove; it is more like a "warm hug" as you can stand right beside it and not "feel the burn" like you do with normal air tight stoves. My theory is that focusing the heat of a small amount of fuel (4 sq. inches) into a big chunk of refractory cement is more like how a torch works on a piece of steel; the focal point where the flame hits is insanely hot, but heat intensity decreases from the point of flame impingement ie, it takes time for the heat to radiate via conduction . The change in direction of the flame; first 90 degrees to travel up the riser and then 180 degrees off the heat bell also rob a lot of the kinetic energy of the flame. Enough of my "combusto-babble", I end with, a warm happy wife makes for a comfortable happy life!
MartyMart (author)2018-01-11
Very nice! Thanks for posting this. It would be really cool to run the exhaust through another heat exchanger to suck even more heat out of it!
I definitely want to build one.
tesselation (author)2018-01-11
I like it!
I have been wanting to make something similar, only using pine cones as the pellet fuel. I have collected garbage cans full when I do walks in a nearby park. Not sure which tree species they are but they open up for lots of air flow seem to be low in pitch. Gravity flow is my biggest challenge.
You might consider adding a few more pictures in your instructable that shows side profile view(s), as I was only able to understand your construction after viewing your you-tube video.
DIY Hacks and How Tos (author)2017-12-30
Nice design. Don't just make something cool. Make it look cool too. You have got my vote.
Thanks for appreciating my work!
acheide (author)2017-12-30
Very nice. Thank you. It looks like this design would be perfect for my small work space.
Do you have any sketches that you could upload?
GizmoGuy347 (author)acheide2017-12-31
Thank you! Please subscribe as I will be adding drawings and dimensions in the near future.
gm280 (author)2017-12-30
Most interesting. I may be looking for something like that to heat my large work shop. Could you provide more data. Like sketches and such?
GizmoGuy347 (author)gm2802017-12-31
Hello, I am currently working on a dimensional drawing. Please subscribe as I will post on the last page of the Instructable along with some tips for improvement for the next Generation of Franken-Stoves
About This Instructable
9,250views
106favorites
License:
Bio: I'm Bald and I build things!
More by GizmoGuy347:Pellet Fed Rocket Stove
Add instructable to:
