Planters From Kitchen Tools
494
Published
Introduction: Planters From Kitchen Tools
About: I like to try anything once and dabble in a bit of everything.
Do you have old pots and pans that you'd hate to throw out? Let's reuse them as planters! It's simple, anything can be used as a planter as long as you have proper drainage. I'll show you how to make a few different types of planters from kitchen pots and pans.
Step 1: Coffee Pot Terrarium Planter
This is what you will need to make a coffee pot terrarium planter:
-an old coffee pot (with or without the lid)
-small rocks
-soil
-plants (great choices are air plants or succulents)
-small trinkets for decor
Step 2: Coffee Pot Terrarium Planter - Continued
First place some rocks on the bottom of the coffee pot. One layer should do. This is essential as it will allow for drainage after watering.
For succulents:
Put in a small layer of soil with a small well for where you will put the succulents. Take succulents out of the pot, and position in the soil well. Cover the remaining area with soil.
For air plants:
Add another layer of rock (if you have another colour, that works too). Place the air plants on top.
You can add little trickets such as gems and small figurines to personalize the terrarium.
Be careful when watering. You don't need to water too much because there is no drainage hole. You should be able to see through the rock layer how much water has been added.
Step 3: Strainer Hanging Planter
This is what you need for a strainer/colander hanging planter:
-metal colander
-spray paint (optional)
-landscape fabric
-jute or hemp rope
-trailing plants
-soil
Step 4: Strainer Hanging Planter - Continued
The optional step for this planter is to spray paint your strainer. Shiny metallic objects can scare away birds from the garden. If you don't want birds coming, than leave the strainer as is. If you want to encourage birds to your garden, it is highly recommended that you spray paint your strainer. Focus on light colours if you are spraying, so that the root system doesn't get too hot. If you are choosing to spray paint your planter, do that first on the outside. You don't need to spray the inside.
Step 5: Strainer Hanging Planter - Continued
Wrap jute or hemp around the rim of the planter. Starting at a handle, wrap the handle and continue once around. Go and wrap a second time. Wrap a third time, but this time, create two handles with the jute so that you will have four points to hang the planter.
Step 6: Strainer Hanging Planter - Continued
Cut out a circle of landscaping fabric that will fit in your strainer. Line the bottom and fill with soil. Plant your plants normally. Add handles with jute (a braid or weave will do).
Step 7: Hanging Pot Herb Planter
This is what you will need for a hanging pot herb planter:
- a pot with a handle
- herbs
- spray paint (optional)
- soil
-hemp or jute
-coco planter material
Step 8: Hanging Pot Herb Planter - Continued
Just like the strainer planter, this optional step is to spray paint the planter if you want to encourage birds in your yard. Shiny metallic objects will scare away birds.
Step 9: Hanging Pot Herb Planter - Continued
Put in the coco liner. If it's too big trim it down. Essentially you want half a circle. Fit the liner in the pot, you'll want a substantial amount hanging out the bottom. At each end, cut a hole and stick a long piece of hemp in. Tie each end to the handle.
Step 10: Hanging Pot Herb Planter - Continued
Cut another two holes along the center. Put in a long piece of hemp. Do not tie this one yet, we need to plant the herbs first.
Step 11: Hanging Pot Herb Planter - Continued
Start by putting in some soil. Add the herb and put soil around the roots. Press hard around. Add a little more soil in the front. Make sure that most of the root system is near the bottom of the pan. Most of the herb will grow along the coco liner.
Step 12: Hanging Pot Herb Planter - Continued
Tie the front hemp strings to the handle. Now you're done! Hang by the grill for quick access to herbs.
Step 13: Baking Pan Planter
For this planter you will need:
-rocks
-baking pan
-soil
-succulent plugs
-air plants
Step 14: Baking Pans Planter - Continued
Most pans are thick, so it's tricky drilling holes for drainage. To get around this, fill the bottom of the pan with rocks.
Step 15: Baking Pan Planter - Continued
Add soil on top the rocks but make the soil raised in the center. Pans typically are shallow so you need to raise up the center a bit. You will need succulent plugs (small succulents) which is fine for how shallow the pan is. Plant the plugs in the raised center.
Step 16: Baking Pan Planter - Continued
Place rocks along the edge of the baking pan. Put some air plants on top. Air plants do not need to be buried in the soil. When watering, use a spray bottle.
Planter Challenge
This is an entry in the
Planter Challenge
    • Make it Move Contest
    • Stick It! Contest
      Stick It! Contest
