Introduction: Secrets of Diagonal Weaving
Picture of Secrets of Diagonal Weaving
Diagonal weaving is a technique for producing bias-woven fabric on a pin loom. Bias-woven fabric drapes well and is ravel-resistant.
I'm using it here to make The Best Dishcloth In The World. Why the best?
  • Get dishes clean fast.
  • Wring out nearly dry for quick clean-ups.
  • You can bleach the heck out of them.
  • Nearly indestructible -- put them in your will.
  • Natural cotton -- I suppose they're bio-degradable.
  • Use a clean one to wring out the excess liquid from spinach -- it comes out nearly dry.
  • Dishwasher and microwave safe.
  • No enclosed pores to trap bacteria
Step 1: Tools and Supplies
Picture of Tools and Supplies
Very simple:
  • A pin loom of the desired size.
    I've seen them up to shawl size, but for this demo I'm using 12x12 inch. They're easy to make: Pin Loom For Weaving Fabric Squares
  • Worsted weight 100% cotton yarn (one 4 oz. skein will make 3 dishcloths)
    I plan to bleach these dishcloths, so I stick with white or colors that bleach to a pleasant shade. (For this demo, I'm using a natural color green that bleaches to a beautiful gold.)
  • A size 8 or H crochet hook
    I file the handle end to a flat and use it as a beater. Some people use a table fork, but I like to use one tool for everything.
  • A tapestry needle
    It sounds exotic but they're sold at almost all craft stores. It is just a blunt needle with an eye big enough for the worsted weight yarn.
Step 2: Start With a Slip Knot at the Top Corner.
Picture of Start With a Slip Knot at the Top Corner.
Since you are making a diagonal weave, the loom should be oriented with corners to the top, right, left, and bottom. A slip knot is handy because later you'll want to run in the ends, and once it is off the pin, a simple tug takes the knot out of the yarn.
Step 3: First Pass
Picture of First Pass
  1. From your slip knot at the top, run the yarn around the pin at the bottom corner, then up to the first pin to the right of the top corner.
  2. Wrap the yarn around the pin clockwise, and pull it under the strand that is knotted to the top corner. Since it is a loop, this also pulls the yarn under strand attached to the bottom corner.
  3. Then put the yarn over the first pins (top and bottom) on the left side.
  4. Take out the slack, but keep things loose. The strands will tighten up as you weave, and even more when you do the shrinking of the finished article.
Step 4: Second and Remaining Passes
Picture of Second and Remaining Passes
  1. Weave your crochet hook through the existing strands, across the newest strand, and pick up the free yarn.
  2. Pull the yarn through to make a loop. (I find it helps to turn the crochet hook so that the hook opens toward you. If the hook is up or down, it tends to catch on the existing strands instead of sliding by them.
  3. Put the top and bottom of the loop over the next pins on the left.
  4. Tidy up the strands (see next step.)
Step 5: Let Your Tensions Go!
Picture of Let Your Tensions Go!
The goal here is to keep the weaving tidy, but not let it get too tight, especially during the first half of the weaving. As noted above, the article tends to tighten up on the loom as it is woven, and it will tighten even more in the shrinking step.
So, see the sag in the strands? That's about right.
You can maintain a nice. tidy weave while keeping the tension down. Just press down on the vertical strands while you are straightening the horizontal strand you just wove. This straightening is called "beating," but don't take that too literally. I just use the flattened end that I put on the crochet hook to tuck the horizontal strands straight. Some people use a dinner fork, but I don't like to switch tools.
Step 6: Optional: Color Change and Running in Ends
Picture of Optional: Color Change and Running in Ends
You can change colors by running both colors over and under a few (6 or so) strands together, then pulling the free ends down through the article and trimming them off. I don't care for the way it looks, so here's a way to make the transition over at the edge, where it is a bit less visible in the finished article.
Attach the new color over the old on a left-side pin, and then just weave on. That part is simple.
Running in the ends without making a dent in the edge requires a bit of planning, Basically, you have to make sure that the yarns are wrapped around each other before they're run in.
Running in is simple -- just go over/under 6 strands and trim the free end off under the article. I like to leave 3" until after the article is shrunk, then trim to fit.
Step 7: Finishing Touches
Picture of Finishing Touches
For the final pass, or anywhere adjacent strands are going over and under the same cross strands you'll need to run a single strand between them to lock the loop in place.
Note that I've over-beaten the top and bottom strands. It looks sloppy, but it's much easier to run the needle between them with a bit of clearance -- and the shrinking process will straighten everything out.
Actually running the single strand is pretty straightforward. Measure enough yarn off the ball to make a pass, plus 6 inches or so. Using your carpet needle, weave it down the middle of the final loop, over and under the opposite vertical yarns. When you get to the left end, wrap it around the end of the loop, and run in the end.
Double check that all the ends are run in, then trim them off leaving 2 - 3 inches. Wash and dry on high to even out the weave and shrink it tight. I like to add bleach, so that the dishcloth doesn't change color when you clean the sink with chlorine bleach, or wash/sterilize the dishcloth after use.
Finally, if you mess up, it's only a dishcloth, after all. If it comes out exactly as planned, well, it's the Best Dishcloth In The World, so it is worth a bit of extra effort.
underTEGNEde made it! (author)2017-12-12
Thanks for some great inspiration. I have made a special tool for making the weaving easier and faster - see attached pictures. The comb pushes down every second strand making it easy to run a long crochet hook between the strands. As the width of the fabric increases I just add another section of the comb. I use a piece of convex shaped foam to keep tension on the first vertical strands. Halfway through the weaving I lay the foam flat to maintain the effect of the comb pushing down. In addition the comb can be used as a beater to straighten out the horisontal strands.
I allready made quite a few nice dishcloths. With these tools and the practice gained from 5 dishcloths I can make one in 90 minutes - still improving the speed :)
OneBirdieMa (author)underTEGNEde2017-12-17
Hi! I agree with the suggestion/hope stated below (while I'm writing this, unless the next reply goes at the end, in which case it's above) but I have a further request: is there any way to make this without having to tool metal? Maybe -- hardwood? Maybe -- a woodworker might see this and come up with an 'ible? Wishful thinking.
I’m going to keep my eyes out for a sturdy square picture frame at 2nd hand stores then add finishing nails around it.
I think you'd do better to go to a decent art supply store and get four pieces to make a stretcher. That's what a canvas is stretched on, and it's far sturdier than any frame. You can get individual pieces anywhere from 3 or 4 inches up to 24 inches or more, but 10 or 12 is most manageable. Smaller is too crowded unless you have very small hands and larger gets awkward handling the back and forth of the weaving and keeping it even. Good luck with your project!
ronphillips (author)OneBirdieMa2017-12-17
1/8 in (3 mm or so) craft plywood could work, I think. You could use the same trick of making a 70.7% scale copy of the plastic canvas to get the spacing.
OneBirdieMa (author)ronphillips2017-12-17
Thanks for this and the other reply. The scale ratio will be of great value. Now I need a nice big storm to snow me in for several days . . . just kidding!
crazypj (author)underTEGNEde2017-12-15
The 'improvements' you came up with make this even better
ronphillips (author)underTEGNEde2017-12-13
What a well thought-out improvement! I tried to come up with a heddle, but I didn't think about handling the yarns that aren't being pushed down. Clever! 90 minutes is a substantial improvement.
Making the comb modular is another really good idea. It looks like you used a CNC mill, but I may use a laser cutter, since our Makerspace has one.
I won't need the foam since my loom is all edges with no center, so I can just press down, I think. If not, I can always add the foam bridge.
Thank you so much for sharing!
OneBirdieMa (author)2017-12-17
This is great! Question: have you ever worked with/made a triangle loom? A seriously large square held on the diagonal can be very difficult, but a triangle loom size large can be mounted on an easel and worked with on a much wider diagonal; two triangles together make a square -- or there are lots of patterns for using triangular fabrics for things beyond shawls. What I want to know specifically is at what interval to place the brads (or nails) on the diagonal. My brain goes into freeze when I try to figure it out, so I thought I'd ask.. I have all the parts for this so shall grab time (the always scarce commodity) to make myself one. Thanks for such clear, well-described instructions along with good illustrative photographs.
It would seem you would need as many pins on the diagonal as are on both sides total. (So twice as many as are on one side). Space them so that you can fit them all in, closer that on the sides.
Thanks for your suggestion, but no, it shouldn't be double. The diagonal of a square is only ~1.4 times one side, if my fast calculation is correct. The question I was asking was whether the spacing on the diagonal should be the same as on the side, or lengthened or shortened according to some rule unknown to me. Some of the calculation may depend on the thickness of the fiber being woven, especially if it's not the same in both directions (as could be the case in a woven diamond; less likely in woven triangle). I think I may have to hit up the Triangle Loom folks and find out if any of them knows, but I suspect they purchase their looms and don't worry about it more than that. I'll have to literally go back to the drawing board one of these days to figure this out ...
If you want to produce a fabric of the same weight, you'd space the pins on the diagonals at 0.2 inches, and across the top at 0.2 / 1.14 = 0.14 inches. However, I wouldn't calculate and measure.
One simple way would be to make 70.7% scale photocopy of the plastic canvas and then use that spacing across the top.
TYVM
crazypj (author)2017-12-15
I like this Instructable way more than I thought I would. Having 'loom' diagonal makes weave slightly 'tighter' than having 'square' ? Pins are 'closer' when turned?
ronphillips (author)crazypj2017-12-15
Yes, indeed, they are about 0.14 inch spacing in that orientation.
I'm glad the Instructable exceeded expectations! Thank you.
Awert1962 (author)2017-11-09
A good idea and simple manufacture, plus a clear guide. Can be used for various crafts from cords. I'll do myself that such.
ronphillips (author)Awert19622017-11-09
That's intriguing -- I hope you publish some of the things you create. Now you have me thinking about other materials, too!
Thank you!
About This Instructable
2,443views
40favorites
License:
More by ronphillips:Secrets of Diagonal WeavingPin Loom for Weaving Fabric SquaresVideo Stabilizer under $10
Add instructable to:
