Introduction: Simple Bots: Wobbler
Picture of Simple Bots: Wobbler
Typically, you learn how to wobble before you learn how to walk. But in the world of bots, anything is possible! That is why a day after showing you how to walk and two after showing you how I roll, I am back to show you how to do a little wobble wobble. That's right! In almost no time, you can be out wobbling around with the best of 'em. All of the parts in this project are simple to find and even less-than-experienced bot builders should be able to make this one pretty easily. And, more experienced bot builders should be able to have some fun modding this one, as the casing leaves a lot of room for experimentation.
Want to watch me build this project from start to finish? Check out this webinar I led on June 13th 2017 to see me complete the whole build!
Step 1: Go Get Stuff
Picture of Go Get Stuff
You will need:
(x2) continuous rotation servo motors with the controller removed**
(x2) self-adhesive oval coat hooks
(x1) small plastic container
(x4) zip ties
(x1) 4 x AA battery holder
(x4) AA batteries
**To learn how to remove a servo controller, visit this page.
Step 2: Remove the Horns
Picture of Remove the Horns
Remove the servo horns from the motors.
(The servo horns are the gear-like objects attached to the motor shafts.)
Step 3: Insert
Picture of Insert
Place the servos inside the plastic container such that they are mirrored back to back. The servo shafts should be located near the bottom of the plastic container and off-center.
Step 4: Mark
Picture of Mark
Mark the plastic container with a dry erase marker to indicate the position of the motor shafts and the servo mounting holes.
Step 5: Drill
Picture of Drill
Drill holes in the plastic container where you have just made the dry eraser marks in the previous step.
For the smaller mounting holes, an 1/8" drill bit should be suitable. For the motor shaft, I recommend using either a 3/8" or 1/2" drill bit.
Step 6: Mount the Motors
Picture of Mount the Motors
Position the motors inside the case and zip tie them securely in place.
Step 7: Wire It Up
Picture of Wire It Up
Twist together a red wire from one of the motors with a black wire from the other motor, and either wire from the battery holder.
Next, twist together the remaining three wires to form another pair.
You can solder them for a more permanent bond, if you wish.
Step 8: Close It Up
Picture of Close It Up
Place the battery holder inside the case.
Close the case and reattach the servo horns.
Step 9: Wheels
Picture of Wheels
Take the coat hooks and trim off the hook part with diagonal cutting pliers or a small saw.
You should now be left with self-adhesive oval wheels.
Step 10: Attach Wheels
Picture of Attach Wheels
Peel off the adhesive backing and secure the wheels to the servo horn such that the horn is completely hidden behind the wheel and the wheel is very off-centered from the axis of rotation.
Step 11: Power It Up
Picture of Power It Up
Remove the lid, insert batteries, replace the lid and let it go.
Experiment with putting the bot on different sides to observe all of the ways it moves.
M.C. Langer made it! (author)2017-01-04
Great project as always! By the way, I made it. Well, kind of. You will not recognize it after several changes I did:
https://www.instructables.com/id/Roboto-the-Wobbling-Toy-Robot-evolution-of-Randofo/
randofo (author)M.C. Langer2017-01-04
Your additions make it something else entirely! Great idea :)
M.C. Langer (author)randofo2017-01-06
Thanks Randy!! :-)
COOL IDEA
UncleEd (author)2017-06-11
Thank you for putting the video first. Several times I have been interested by a title, but had to look for a while to see what the project was actually going to do. Your way is more efficient.
grhabyt (author)2011-07-02
Where do you get the self-adhesive oval coat hooks? I can't find anywhere in the US that sells them (Google shows them only in the UK). Any suggestions?
EdensGrandma (author)grhabyt2017-06-11
Wal-Mart, Target, Amazon
randofo (author)grhabyt2011-07-03
I got them at Ace Hardware. You can probably also get them at any Walgreens.
grhabyt (author)randofo2011-07-03
Found them at Ace.
Thanks.
coolpandaturtle (author)2013-06-02
Awesome project neat if i change the wheels to something that makes noise and hook up to a timer i will be awake on time
ur awesome
mraghib (author)2012-04-03
Nice & innovative idea!Can you please tell me can we use toy motors instead of servos as they are expensive and wheels instead of coat hooks? Thank You!
yes because the servos already have their *stuff* removed and act like normal motors that you would find in RC cars
rajat j (author)2011-09-22
hey can we use normal wheels in place of those self adhesive oval coat hooks as they r not available in india ??
dude they are avalable in india even in small towns like mine
aravindskumar10 (author)2012-01-26
hey, randofo. can you please suggest a very easy yet innovative robot that a 13 year old like me, could build in 3 hours? since i really liked your projects, thought i could ask you to help me... i need to make it on the spot, so can't use anything like soldering,chips,servo motors,etc
Thanks a ton
rajat j (author)2011-09-25
hey can u please tell wether v can use normal wheels???
thelastonekills (author)2011-05-24
cool 5/5
would this still work if the leg things lined up? (apart from losing the wobble)
randofo (author)thelastonekills2011-05-24
Yes, it moves faster. It kind of throws itself forwards.
BuhBomb (author)2011-05-22
Interesting..........................
thepelton (author)2010-07-28
Amusing! I had to laugh, even though I'm reading this from a Library. You need to figure out how to make it go in a relatively straight line. 8>)
brunoip (author)2010-07-28
It seems to have some trouble staying in a straight line.
Anyway it looks great.
randofo (author)brunoip2010-07-28
It has to do with the wheel positioning, one is slightly higher than the other one. I have re-adjusted them a few times and I could never seem to get it perfect, as it always drifted to one direction over the other. I figured that, perhaps, that is just what it wants to do.
About This Instructable
30,146views
95favorites
License:
Bio: My name is Randy and I am a Community Manager in these here parts. In a previously life I had founded and run the Instructables ... More »
More by randofo:Large Motor ProjectsRemove a Wheelchair Motor BrakeBuild a Robot
Add instructable to:
