Single Cylinder Air Engine Balloon Powered Rolling Chassis
14,114
166
45
Published
Introduction: Single Cylinder Air Engine Balloon Powered Rolling Chassis
About: Formerly the owner of a company that designed software for avionics (EFIS, FMS, etc.) and video games (Tetris, Robocop, Predator, Michael Jordan in Flight, and a number of others), I'm now retired and finall...
Single Cylinder Air Engine Balloon Powered Rolling Chassis is a balloon powered vehicle based on my earlier air engine design (https://www.instructables.com/id/Single-Cylinder-Air-Engine-Smaller-Edition). This vehicle can run over 40 feet on a smooth surface.
My wife laughed so hard when this vehicle chugged through the kitchen and into the family room that, well, now there's six of them (hers is in red).
You will need to purchase 4 "AS568" #219 o-rings (1 5/16" I.D., 1 9/16" O.D, 1/8" section) for the tires and at least 1 "punch balloon" (I found mine at a local party supply store, but they also are available on line).
I probably forgot a file or two or something, so if you have any questions, please feel free to ask.
Designed using Autodesk Fusion 360, sliced using Cura 2.3.1, and printed in PLA on an Ultimaker 2+ Extended and an Ultimaker 3 Extended.
Step 1: Print and Prepare the Parts.
I printed my parts on an Ultimaker 2+ Extended and an Ultimaker 3 Extended using .1mm vertical resolution and 100% infill for "Cylinder.stl" and "Rod Balloon.stl", 50% infill for the remaining parts, and no supports.
Prior to assembly, test fit and trim, file, sand, etc. all parts as necessary for smooth movement of moving surfaces, and tight fit for non moving surfaces. Depending on the colors you chose and your printer settings, more or less trimming, filing and/or sanding may be required. Carefully file all edges that contacted the build plate to make absolutely sure that all build plate "ooze" is removed and that all edges are smooth. I used a flat jewelers file and plenty of patience to perform this step.
Study "Assembly.stl" carefully noting the locations and positions of the various components as assembly proceeds.
Step 2: Assemble the Air Engine.
Slide "Rod Piston.stl" into "Head Cylinder.stl" carefully noting the orientation of both parts.
Next, press "Piston.stl" onto "Rod Piston.stl" until it is exactly 28mm from the end. If the piston is not tight on the piston rod, a small dot of thick cyanoacrylate glue can be used to hold the piston square to the piston rod and in position. This is the cylinder head assembly.
Slide "Valve.stl" into "Cylinder.stl", carefully noting the orientation of "Valve.stl". The valve should easily slide in and out of the cylinder. If not, "surface sand" both sides of the valve until it does. To surface sand, I place an 8 by 10 sheet of 220 grit sandpaper flat on my work table, then using light pressure, rub one side of the valve for 20 strokes, then the other side for 20 strokes. Clean the valve of sanding dust, then try the fit again and repeat as necessary until the valve slides with ease in and out of the cylinder.
Press the cylinder head assembly onto the cylinder aligning the valve slot with the valve. Once attached, check that both the piston rod and valve easily slide in and out with ease. This is a critical step as both the piston and valve must slide with ease.
Attach "Arm Piston.stl" to the piston rod using "Pin Arm Piston.stl". Once attached, "Arm Piston.stl" should swing freely on the piston rod.
Attach "Arm Valve.stl" to the valve arm using "Pin Arm Valve.stl". Once attached, "Arm Valve.stl" should swing freely on the valve arm.
Step 3: Assemble the Crankshaft Journals.
Slide the axle of "Journal Crankshaft 10mm 2.stl" into the hole at the end of "Arm Piston.stl". Once in place, press "Journal Crankshaft 10mm 1.stl" onto the axle of "Journal Crankshaft 10mm 2.stl" carefully noting the orientation of both. Make sure the axle of "Journal Crankshaft 10mm 2.stl" fully inserted into the hole in "Journal Crankshaft 10mm 1.stl". This is the piston journal assembly.
Slide the axle of "Journal Crankshaft 4mm 2.stl" into the hole at the end of "Arm Valve.stl". Once in place, press "Journal Crankshaft 4mm 1.stl" onto the axle of "Journal Crankshaft 4mm 2.stl" carefully noting the orientation of both. Make sure the axle of "Journal Crankshaft 4mm 2.stl" fully inserted into the hole in "Journal Crankshaft 4mm 1.stl". This is the valve journal assembly.
Step 4: Assemble the Chassis.
Press "Chassis Left.stl" onto the left side of the air engine assembly. Slide the axle of "Journal Crankshaft 10mm 1.stl" into the hole in "Chassis Left.stl". Note that if the hole spacing in "Chassis Left.stl" does not match the pin spacing on the air engine assembly, then the cylinder of the air engine assembly is not fully seated in the head.
Press "Chassis Nose.stl" onto "Chassis Left.stl" making sure it is fully seated.
Slide the axle of "Journal Crankshaft 4mm 1.stl" into the hole in "Chassis Nose.stl", then this axle into the hole in "Journal Crankshaft 10mm 2.stl" carefully noting the orientation of both journal assemblies (when the piston journal assembly is pointing straight back towards the cylinder head, the valve journal assembly must be pointing straight up).
Press "Chassis Right.stl" into "Chassis Nose.stl",making sure it is fully seated.
Press "Chassis Right.stl" onto the right side of the air engine assembly. Note that if the hole spacing in "Chassis Right.stl" does not match the pin spacing on the air engine assembly, then the cylinder of the air engine assembly is not fully seated in the head.
At this point the crankshaft should rotate with ease and the piston and valve assemblies should slide with ease. You should feel no binding or catching as the crankshaft is rotated.
Step 5: Assemble the Wheels.
Install the one o-rings onto the wheels.
Press "Wheel Left Front.stl" onto the axle of "Journal Crankshaft 10mm 1.stl" making sure it is fully seated.
Press the axle of "Wheel Right Front.stl" into the hole of "Journal Crankshaft 4mm 2.stl" making sure it is fully seated. With both front wheels installed, the front wheels should rotate freely with no binding or catching.
Slide "Wheel Right Rear.stl" into the rear of the chassis from the right side, then press "Wheel Left Rear.stl" onto the axle of "Wheel Right Rear.stl". With both rear wheels installed, the rear wheels should rotate freely with no binding or catching.
Step 6: Final Assembly and Break In.
Press the 3 "Rod Balloon.stl" rods together using the 2 "Rod Balloon Coupler.stl" rod couplers.
Press "Rod Balloon Coupler Hook.stl" onto one end of the balloon rod assembly.
Press the remaining end of the balloon rod assembly into the small hole in "Chassis Nose.stl".
Attach a punch balloon to "Adapter Balloon.stl", press the adapter into the upper port on the air engine assembly, then hook the punch balloon to the balloon rod hook.
To break the vehicle in, I placed small drops of light machine oil on the moving parts (axles, journals, pins, etc.) then removed "Adapter Balloon.stl" and installed "Adapter Compressor.stl" (with a compressor quick connect) in its place, and ran the vehicle for 30 minutes at around .5psi.
To run the vehicle, I use "Adapter Balloon.stl" as a mouth piece to inflate the punch balloon, after inflating I press my thumb onto the balloon end of the adapter to seal the air, then press the adapter into the air engine upper port and off it goes!
Good luck, and I hope you like it!
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    45 Comments
    I love the idea of this and would like to use a modified version of it for a school project. Would you be willing to send the f360 files to me to use as long as I credit you. My email is mnelson2@my.monroeccc.edu.
    Thank you very much!
    Your vehicle is awesome!
    Greg.
    I would like to use it as a possible class project.
    Finckc,
    If you would like, send me your e-mail address and I will forward a zip file containing the autodesk fusion 360 .f3d files.
    Greg
    Hi Greg,
    Would you mind sending the link again for the fusion files, it did not come through.
    Thanks,
    Chip
    Hi Greg,
    Thanks for your help.
    finckc@newtrier.k12.il.us
    Chip
    It has been sent.
    Greg
    Hey, im currently a student for my final year project and i saw this awesome model. Can i refer to your idea which use the pneumatic engine? Please?
    Hi! It's a great project and our public librairy actually works on a FabLab project and we would love to make that project with kids. Is it possible to use it too?
    NicolasF11
    Thank you very much, I'm glad you enjoyed this design!
    Message me with an email address from your library or FabLab and I will be pleased to forward it.
    Thanks again!
    Greg
    Great. Since I just started on this project and don't have an email, my librarian will contact you with her official email from the Montreal City!
    Love the project. Would you be able to post the Fusion 360 files for downloading?
    Thanks
    Hi FInckc,
    Thanks you very much, I'm glad you liked it!
    May I ask for what purpose would you be interested in the files?
    Greg
    Love It! Quick question. Did you make a square piston because of printing orientation, or some other reason?
    Thank you very much, and I'm very glad you liked it!
    The piston was made square for two reasons. First, given a fixed area, a square cylinder provides more volume than a round one and thus allows a larger volume of air to enter the cylinder. For "normal" pistons, square piston rings are indeed quite a challenge to install so for that (and a few other reasons) "normal" pistons are round. And second, a square piston is easier to file square than than a round piston is to file round. This made removing "build plate ooze" easier.
    Again, thanks much, and thanks for your question! I'm always glad when someone is curious enough to ask why I did what I did, I truly enjoy your interest!
    Thanks for sharing this. I'm making two for my children and wanted to know if you had a recommended source for the o-rings. I can find quite a few sellers for the AS568-219 with options for material (nitrile, neoprene, silicone, etc.) and hardness (70, 75 and 90). Just wondered what you went with.
    You are welcome, I hope you and your children have a wonderful time with it.
    I purchased this kit: https://www.amazon.com/gp/product/B000OMKIDI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1. All of the o-ring tire vehicles I've designed use o-rings out of this kit. There are other suppliers, but this one works well. The o-rings in the kit are BUNA-N BG 715 (nitrile 70 shore).
    Thanks again, and have fun!
    Cool! Thank you so much! This is such a well rounded proof of concept for physics. My kids (ages 11 and 13) will have a good time with these.
    Great mechanism and model, thanks for sharing !!
