Sun, Earth and Moon Model (Tellurion / Orrery) With 3D Printed Parts
12,653
215
43
Posted in Technology3D-Printing
Introduction: Sun, Earth and Moon Model (Tellurion / Orrery) With 3D Printed Parts
Hi again,
In this instructable I will describe the design and build of a mostly 3D-printable tellurion (a special class of orrery) which shows how the earth and moon revolve about the sun, about each other and how they rotate on their axes. I've always had an interest in these devices, both technical and aesthetic, but never previously had the time to complete one the old fashioned way (using a lathe & mill).
The device presented here stands about 20 cm high and sits on a 20 cm diameter wooden base. It is driven by a hand-crank (one turn per day) and can demonstrate the following phenomena:
  • Daily rotation of the earth about its axis
  • Earth's axial orientation fixed in relation to the celestial sphere, with an axial tilt of 23.4 degrees
  • Revolution of the moon about the earth with 29.5 days (a synodic month) between each new moon
  • Tidal locking / synchronous rotation of the moon with respect to earth (same face always facing earth)
  • Moon's orbital plane inclined at 5.15 degrees to the ecliptic (plane of the earth's orbit round the sun)
  • Precession of the lunar nodes on a 18.6 year cycle
  • Position of the sun in zodiac throughout year (not technically rigorous - more for aesthetics)
It started life when I needed to help with a school project on the solar system. I created a simple 3D-printed kit that a child could assemble, which just modelled the motion of the moon round the earth as the latter revolved around the sun during the year. In the process I discovered that I could reliably 3D-print good quality large gears (known as 'wheels' to horologists). Nevertheless the kit was pretty crude and didn't generate the right number of synodic months in a year, so I set about improving it for my own satisfaction. Unfortunately it turned into a bit of an obsession for three months as I added and tested more and more complications (more horologist jargon). What you see here is the end result. There are still things that require improvement but better is the enemy of good enough...
There are a number of orrery / tellurion designs described on the internet but most seem to be incomplete or involve you paying for plans. On the other hand, attempting a project like this from a blank sheet is not for the faint-hearted. There are probably enough PLA gears etc. in my scrap bin to make another two of these (which won't work properly!). Anyway, I like to give back to the online maker community when I can, so I've attached all the STL files necessary to reproduce the device (except the lovely zodiac dial, which was designed by sully108 - details below). It's only fair to point out that even though most of the moving parts were made on a 3D printer, a considerably amount of fettling was required to get everything to fit together and work properly. If you choose to reproduce this work (note obligatory disclaimer: "at your own risk!"), you'll have a working thing of beauty to put on the mantelpiece and appreciate for years to come. Perhaps you'll make improvements and publish them in your turn...
IMPORTANT NOTE - this is a living document which gets added to as I or others make improvements. If you want to reproduce the tellurion, please read the whole document first (and probably some of the comments).
Step 1: You Will Need...
To build the tellurion you will need the following:
  • A well-adjusted 3D printer and plenty of PLA (allow about 25 m); a very well levelled glass bed is essential, and hairspray might be necessary for the larger wheels
  • Stacking brass tube - this comes in millimeter sizes and each tube will nest neatly into the next size up, so it's really useful for clockmaking where you have multiple rotation rates on a common axis. It's also good for bearings. Albion Alloys in the UK makes the BTxM series, where x is the OD in mm. You will need 3, 4, 5, 6 and 7 mm for this model.
  • Sun, moon and earth orbs. I found some patterned glass marbles on Ebay which look really nice, but you could make and decorate your own from wood or plastic if you wanted
  • Wooden baseplate - I used a beechwood chopping board with a 200 mm OD
  • A nice zodiac or star dial for finishing it all off - I used the beautiful "Astrology Zodiac for Septimus Clock" by sully108, which lives at https://www.thingiverse.com/thing:2476063
  • Rubber feet for baseplate
  • Hotmelt glue
  • Small diameter pipe-cutter
  • Needle-files (for cleaning up the brass tubes)
  • Junior hacksaw (for cutting 3 mm brass tube)
  • Pillar drill and range of bits (for cleaning up 3D-printed bores)
  • Rubber sheet or glove (to help with gripping the thin tube whilst cutting)
  • M3 screw (for the crank handle)
The following items are optional but will make life much easier if available:
  • Lathe with tailstock-mounted Jacob's chuck (for cleaning up roughly-cut brass tube and for clearing out bores)
  • Bench vice (for pressing bearings and gear shafts into 3D printed parts)
Step 2: Planning Out the Gear Ratios
The most important part of tellurion design is working out what all the gear ratios should be to reflect accurately the motions of the heavenly bodies. Superficially this is quite easy, but there is a trap for the unwary (which I fell into twice!). It arises because the axes of the gears modelling the earth and moon motions revolve once around the sun axis in one 'year', thus the attached celestial bodies will experience one rotation with respect to the sun even in the absence of those same gears. It's well worth doing your research thoroughly and not believing the first thing you read.
The majority of the moving parts in this model are mounted on a single curved 'orbit' arm tethered to the sun axis. (this being a throwback to the school project). I decided I wanted a simple hand-crank which would advance the model by one day for each clockwise rotation. The motion of the hand-crank is transmitted to the rest of the tellurion by a pair of bevel gears. In order to simplify the design, I opted to put the hand-crank at the moving end of the orbit arm, so it moves slowly round the baseplate of the tellurion as you operate it. The backplane for the crank helps to support the free end of the orbit arm, which carries all the gears.
The hand-crank turns a pair of bevel gears which drive all the motions of the tellurion via a 10 tooth gear.
Earth's rotation on its axis is one turn per turn of the crank, so the overall gear ratio is 1:1. The gear train is 10:10, 9:9.
The moon revolves round the earth once every 29.54 days, which is achieved with a 10:50, 11:65 gear train. I know this because I used the excellent, no-frills Gear Train Calculator website which works out what the best gear choice for a given ratio is, given user constraints:
http://scientific601.altervista.org/gear/gearcalc....
The earth-moon system revolves round the sun once every 365.25 days. This is easily achieved by extending the moon's orbit train. A ratio of 365.25 / 29.54 =12.36 is required, which is obtained by a small pinion on the moon orbit gear which engages with a much larger gear representing the solar orbit. The train is 11:136, which gives a ratio of 12.36. It is more efficient to extend the moon drive than to create a completely separate train of gears to go direct from the hand-crank to the solar orbit.
As the earth-moon system revolves round the sun during the 'year', a 'Ferguson mechanical paradox' arrangement of gears attached to the orbit arm (39:48:39) causes the earth's axial tilt to remain fixed with respect to the celestial sphere.
A different output gear on the mechanical paradox arrangement is also responsible for rotating the inclined lunar nodes disc. The lunar nodes (where the moon's orbit passes through the ecliptic at two points) move retrograde at a rate of 19.36 degrees per year. Therefore the moon's orbital plane has to rotate once every 18.6 revolutions of the orbit arm. This is achieved using the 39:48:37 gear train. Note that a classical mechanical paradox arrangement has three gears of the same diameter in a straight line. This isn't a strict requirement though and it was easier to put a larger gear offset from the line joining the other two.
The height of the moon is determined by the moon's position relative to the lunar nodes disc, by means of a push-rod on a radial arm which also serves to fix the moon's aspect relative to the earth.
It should be pointed out that the fact that the orientation of the earth's rotation axis is fixed with respect to the celestial sphere means that the earth would rotate once every year with respect to the sun, even if the earth did not rotate about its own axis. Thus the single turn of the hand-crank actually rotates the earth by one sidereal day (23 hours and 56 minutes) with respect to the sun, instead of a solar day (24 hours). This wasn't the first time I fell into this trap for the unwary, but as it corresponds to an error of only about 0.25% I decided it was acceptable for this application. In any case, to correct this would require four additional gears and I didn't think it was worth the effort. The first time I fell into this trap was for the school project, when I calculated the gear ratio of 365.25/27.5 for the moon's rotation (using a sidereal month of 27.5 days), which ignores the fact that the moon/earth system revolves round the sun once in a year. So I ended up with 13.4 lunar months in a year instead of the correct 12.4! Live and learn (slowly!).
The attached figure shows a schematic layout of the tellurion. The gears use the metric system (as do all other parts) and I've used a shorthand e.g. 136m1 to denote a 136-tooth module 1 gear. So for example 37m1054 is a 37-tooth module 1.054 gear; this is the only non-unity module gear in the whole set.
I used FreeCAD to draw the gears and other 3D-printed parts, and Cura to slice them for 3D printing. Even so, it took many attempts to get the right design, because many of the tolerances are critical when you are trying to mesh multiple gear trains on common axes. I frequently changed my mind about the best way to do things, too. The attached picture shows all the PLA parts that didn't make it into the final tellurion!
FreeCAD is a really good tool to use for this kind of work, because the distance between gear centres is always critical (and nothing else really matters). Therefore a constraints-based CAD tool is almost essential.Typically the work-flow would be:
  • Determine the required gear ratio
  • Print the gears (module 1, ideally)
  • Mesh the gears on a depthing tool and determine the optimum centre separation (a simple one is shown here, based on a design in 'Making Clocks' by Stan Bray - once a nice separation is found the scriber points at the ends of the axles can be used to mark out the correct separation, on graph paper in this case)
  • Enter the centre separation as a constraint in FreeCAD when designing the support structures (such as the orbit arm in this case)
  • Print the support structure and test
Even with this procedure, further adjustment of centre separation might be required, particularly as more and more gears are added to the assembly and tolerances build up. That's why there's plenty of scope for generating scrap PLA during the design process. You'll note in the attached picture that there are five scrap orbit arms!
What's nice about this is provided you have all your gear centres correctly positioned on your cad package, the form of the support structure is totally up to you. I discovered by chance that all my centres lay broadly along an arc, which looked much nicer than the original rectilinear orbit arm (which resembled a wild west cactus by the time I'd finished!).
Step 3: Printing the Parts
Here are all the STL files needed to reproduce the moving parts of the Tellurion. The file names are mostly self-explanatory (I hope).
UPDATE - please also see the last page of this instructable, which contains revisions to some of the parts which you may or may not require, depending how your build goes.
It goes without saying that the 3D printer must be very well set up to print decent gears. In particular, it must not generate 'elephant's foot' (where the first layer or two are squished wider than the rest of the part) on any of the gears, as it will ruin the meshing. I used a Wanhao Duplicator i3, at 'normal' quality with 20% infill, but I did use quite expensive filament. Hairspray was used for the largest gears, to prevent the parts peeling off the glass bed. I avoided using support and printed all parts with the largest surface on the bed. This gives most of the gears a lovely mirror surface finish. My printer was set up (on the Z axis zero) to give a very thin brim, which just fell away after printing. The thought of cutting away a thick brim from a 136 tooth module one gear gives me nightmares!
Step 4: Preparing and Installing the Shafts and Bearings
The table above shows the bore sizes for each of the 3D-printed parts (which is also the OD of the brass tube which must be inserted into that bore). It also shows the estimated length of the brass tube for each part which I used.
3D-printed bores aren't typically good enough to use without drilling out to diameter. I used a pillar drill to open up the bores (or a lathe as appropriate). Great care is needed, particularly when drilling small parts, both to avoid damage to parts and injury to hands. I used needle-nose pliers for the smallest parts. Drilling through onto a clean wooden block protects the rear face of the part.
The brass tube is easy to cut with a pipe cutter (except the 3 mm OD, which needs a junior hacksaw). A rubber sheet or glove is almost essential to get a good grip on the narrow tube, for cutting, cleaning and fitting. It will need cleaning up after this process, for which drilling out on a lathe is a good starting point. I did this in a lathe but it can be done by hand. If doing this, de-burr by hand with a larger drill, then use a needle file to ensure that the next size down of brass tube is a nice running fit into the tube being worked. Remember that needle file is sharp!
Typically the corresponding brass tube is a press fit into the bore once drilled. This is quite handy as it saved me needing to glue gears to shafts. A bench vice makes it very easy to press bearings into place, but it is possible to use a piece of hardwood to press them in by hand (make sure the tube is square to the bore!).
Step 5: Assembly
You will need to refer frequently to the schematic presented earlier to make sense of this next bit. The order of assembly is just a suggestion, but should ensure that you don't have to disassemble parts because you forgot something. It's quite handy to have a big block of wood with a 6.5 mm hole drilled in it to support the whole thing as the build progresses.
The trickiest part to assemble is the earth-moon sub-assembly, which has four nested tubes. Start with the 65m1/11m1 moon orbit gear (with 6 mm bearing fitted) and assemble the 37m1.054 / lunar nodes plate through it (on a 5 mm shaft) as per the diagram presented earlier. Using a simultaneous pushing and twisting motion seems to work, but don't overdo it or the gears could slip. Next fit the 3 mm tube which supports the moon into the 65m1/11m1 gear through the hole on the periphery. Then fit the 39m1 to the 4 mm shaft and insert that under the 37m1.054 gear into the 5 mm bore.
Press-fit the spindles to the tops of earth axis, moon axis and sun tubes. Fit the moon orbit arm onto the 4 mm moon tube. This last part can now be dropped onto the 3 mm moon support shaft, with the 5 mm hole dropping over the 4 mm vertical earth shaft about which most of the gears rotate. The small push-rod on the bottom of the moon orbit arm will contact the slanted lunar nodes plate. Make sure that the moon axis tube can move freely up and down and that it drops down under gravity onto the lunar nodes plate.
Now fit the axial tilt bracket to the top of the 4 mm vertical earth shaft. Fit a 10m1 gear to the 3 mm earth drive shaft (leaving about 6 mm projecting to fit into the orbit arm bearing below). Then insert the earth drive shaft through the 4mm vertical earth shaft. Secure this at the other end with a 9m1 gear. The earth axis tube has the other 9m1 gear pressed onto it, leaving about 6 mm projecting to fit into the bearing on the axial tilt bracket. This whole sub-assembly is now mechanically complete, but you may need to shift the positions of the gears and the relative overhangs of the tubes to get it to mesh nicely with the other gears.
Push the 136m1 and 39m1 mechanical paradox centre gears together (they clip together) then work them up the 6 mm brass tube which will hold the sun. The rubber glove is essential here. Then attach the 6 mm spacer under the 39m1 gear.
Slide the orbit arm up the sun tube. Then drop the 48m1 and 50m1/11m1 gears into place. The 10m1 gear with its 4 mm drive shaft should also be installed at this point. Fit the small spacer and the 12m1 bevel gear to hold this one in place.
Fit the earth-moon sub-assembly into the orbit arm. Make sure all the gears mesh neatly and are spaced nicely, as in the diagram. This will take some fiddling around but isn't too taxing, provided you can move the orbit arm up and down on the sun tube in the process.
Use hot-melt glue to attach the orbs to the spindles. This even works quite well for the glass marbles that I used. You might find it easier to remove the earth axis tube to do this, as it's tilted when installed.
Click the sun pointer into place at the centre of rotation of the orbit arm - shiny side up, so that there's clearance when it moves round the baseplate.
You should now be able to make the whole mechanism move easily by rotating the bevel gear anticlockwise (viewed from above). This will cause the moon to move anticlockwise round the earth and all the other motions to take place. Check that nothing is sticking or slipping.
Step 6: Finishing Off
Press a 4 mm bearing into the small end of the crank handle.
Press the second 12m1 bevel gear onto an appropriate length of 4 mm tube and install into the crank housing, which has previously been fitted with a 5 mm diameter bearing. Press the crank handle on the other side of the 4 mm tube. Note that the bevel gear is fitted on the side of the crank housing with the large rectangular cut-out.
Clear out the support from the crank knob bore with a pair of needle-nose pliers. Then use a short M3 screw to attach the crank knob to the crank handle through the 4 mm bearing.
Offer up the crank housing assembly to the square projection on the orbit arm (that's what the rectangular cut-out is for). Check that the two bevel gears mesh nicely. When it looks good, use hot melt glue to attach the crank housing assembly to the orbit arm.
Take the wooden disc and use a square to find the centre. I used the corner of a piece of perspex. Mark the centre and drill to 6 mm. Apply woodstain to the top and sides of the disc if you don't like the original colour. When this is dry, self adhesive feet can be applied to the underside. Polish the finished base if desired.
This is the point at which any zodiac or star plate should be fitted. I used hot-melt glue at three or four points round the periphery. It's surprisingly hard to judge concentricity, I found, and the sun pointer may foul on the inner diameter at some point in the 'year' if the positioning is wrong. At least with hot-melt glue you can try again if you make a mess of it. Oh, and make sure that it's oriented correctly so the sun moves through the right constellations in the right order during a 'year'.
Now put the rubber glove back on and fit the clear end of the sun tube into the 6 mm hole in the baseplate. It will be a tight fit, but that's what's needed. A screwing and pressing motion helps.
That's it. All that remains is to check that the operation is smooth around the entire 'year'.
Step 7: Conclusions
Well, overall I am pleased with the result and the tellurion now lives on my mantelpiece. Considering it started life as a kit I designed for a school project (see photo), it's come a long way. It's been a valuable exercise and will set me up well for making solid progress on an earth-centric astronomical clock project which has been gathering dust in my shed for ages (that happens a lot - you can see if you look hard enough!). I made most of the gears for that project the hard way, but discovering that the 3D printer can do a better job in less time has been a revelation.
I think there are a couple of areas for improvement in the current tellurion design, which I might address if I get chance:
  • Increase the clearance in the mechanical paradox gear train. The 48m1 gear is a fraction of a millimeter too close to the other gears and the mechanism occasionally stiffens up at certain points in the 'year', which can cause the crank to slip. If this works I will update the attached orbit arm STL file. DONE - see next step.
  • Incorporate optional modifications to prevent slipping of shafts. DONE - see next step.
  • Replace the crank with a knob - the gear assembly is very light so a delicate touch is needed when working the crank, particularly when going from the 5 o'clock to the 11 o'clock position, as the tendency is to pull the orbit arm up and away from its intended direction of travel. Having a large thumbwheel isn't quite as nice but would probably fix this problem as the forces would balance out to a large extent. DONE - see comment with attached STL file by scottmil. An alternative would be to move the crank axis so it was more tangential to the earth's orbit.
  • Get the Earth rotating at the solar day rate rather than the sidereal rate - no, just kidding...
Thanks for reading and good luck if you decide to make one. Please post a picture as these devices seem to be popping up all over the place!
Step 8: Improvements to Original Design
On this page I have included the STL files for the orbit arm with a slightly looser tolerance for the 48m1 mechanical paradox gear, which helps with smooth running. The axis for this wheel has been moved 0.5 mm away from both the axes of the two 39m1 wheels that it engages with. I wouldn't bother printing this though, unless you know that the baseline version is binding up in this area.
Also included are new bevel gears, a crank and a 10m1 (4 mm bore) which have dogs added to prevent slipping of the gear on the shaft. The drive train transmits a fair bit of torque compared to the other parts and will slip occasionally if you've frequently dismantled it during assembly. I suspect most of the slipping has arisen on mine because various key assemblies have been made then dismantled many times during development. Still, now the mitigations are available here if you need them in future.
I only installed a new 12m1 bevel : 10m1 assembly as this was known to be slipping. The parts can be printed in the usual way but you will need to be careful when opening out the bore to the nominal dimension so as not to damage the dog. I did this by hand, by holding a drill in a piece of rubber and twisting it into the part.
These gears will only fit onto specially prepared shafts. This is where a bench vice comes in very handy. I held the shaft obliquely in the vice (wrapped in some rubber to prevent damage) and used a medium file to remove half the circumference of the shaft to a depth of about 1 mm (the height of the dog on the gears). By positioning the shaft correctly in the vice, you can use it to support the file, plain edge down to avoid damage to the vice jaws. Once the cut is started flip the file round and cut with face and edge simultaneously to get a nice right angle.
The first gear can be fitted to the prepared shaft using the bench vice. Once the shaft is installed in the orbit arm or crank housing (whichever one you are doing), waterpump pliers can be used to press-fit the second gear. In each case, ensure before pressing that the dogs on the shaft and the gear are correctly aligned relative to one another.
For the crank part, I have also increased the axial length by a few mm, to improve clearance on the wooden baseplate during operation. This is helpful if your baseplate isn't perfectly round or you can't find the centre of a circle!
Finally, I have included a baseclamp part. I haven't used this on mine but it can be fitted to the underside of the wooden base, where the sun shaft emerges. If a dog is filed onto the base of this shaft, it will engage with the baseclamp and prevent slipping. Three countersunk screws can be used to fit the baseclamp, but you will definitely need feet on the baseplate after fitting it, so that the whole thing doesn't rock.
Space Challenge
First Prize in the
Space Challenge
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    3 Questions
    Hi from Aus, great instructable. I started printing 3 days ago , all printed now except for the 5 improvements i found towards the bottom of the article.
    The 136 tooth wheel turned out easy enough to print . As a precaution i raised the bed temperature by 5 deg in the hope of keeping the outer sections warm enough. In any case it printed well.
    I have ordered the tubing , but i cant find a readymade 20.cm dia platter anywhere. So it might be i have to make it . Another thought about a base i had was to use 3 x 3d printed elephants and print a set of beams to form the base then set it up on the elephants backs . ( elephants holding up the world as we know it sort of theme) . More thought needed here though. my question is the schematic drawing shows on the sun axis where the orbit arm meets the spacer there seems to be a rounded section of brass?
    does this exist and if so is it a ball of some sort or something else ?
    thanks
    Brian
    Hi Brian and thanks. I'm delighted to see you are making your own. Sorry to hear you can't find a baseplate; try looking at bread/chopping boards on ebay. Your alternative sounds good though. I considered some sort of ornate 3D printed base but my imagination failed me. Ultimately I just wanted to finish the job quickly and didn't want the base to distract from the mechanism. You will need to ensure that the base is fairly substantial, otherwise working the crank will just make the whole tellurion shift around which would be very annoying.
    I think that 'rounded section' of brass you refer to is the bearing assembly for the orbit arm. It actually shows (on my original) a piece of 7 mm tube x ~10 mm long surrounding the sun axis of 6 mm OD. In practice there should be no gap between the orbit arm axis and the spacer above it, but then this detail would be lost from the schematic.
    Good luck with the build and please post an 'I made it!' when you are done.
    Hi, Brilliant work, well laid out ane plenty of good views and I was hoping an easy build. So far so good but there seems to be a problem with the bevel gears they print too large! they also look completwely different than yours do? sSo I've got a great static display :o(
    Any chance of the correct file or a guide to the scale?
    Wow! I never thought it would start reproducing so quickly! Great work and thanks for your kind comments. I have checked out the files that I uploaded and I put the wrong version of the bevel gear on the page, so I'm going to correct that now. It should be 12bevel.stl. Sorry about that and well spotted. If you want to check operation just wind the 54/11 gear clockwise with your fingers. You will get plenty of torque this way. I am experimenting with a modified drive arrangement that will get rid of the occasional slippage of the bevel gears on their shafts and will post when I have it, along with a slightly looser-toleranced orbit arm.
    Beautiful job, again....
    Nice job! Do you have any videos of the operation? I'm considering making one and donating to our local school.
    Hi and thank you. I don't have any videos at present but will look at making a short one. I think donating a tellurion to your local school is really laudable. This version is quite a delicate machine though, so you'd need to consider what the likely usage might be (or be prepared to make plenty of spares!).
    UPDATE - I made a video but can't seem to upload it through the website like other file types; apparently I can only go via Youtube or Vimeo. Life's too short - sorry. Anyway, it definitely works...
    43 Comments
    Attached is a photo of the project that I recently built. The only change was to substitute the crank with a knob (STL attached). Works great! Thanks for modifying the original designs on some of the parts too.
    Hi - really nice job! I like the transparent sun orb. It's good to see how people vary the design based on their tastes and component/PLA availability. Thanks for the positive report on the knob and for sharing the file, which I've now referred to in the main text. I'm still determined to get the crank working but when I've fixed the burned-out wires in my printer (a rite of passage, apparently) I'll probably make and fit the knob. This will make the tellurion easier to use for not-so-delicate fingers.
    I'm an amateur astronomer, so I right away wanted to duplicate your amazing project on my 3D printer.
    Questions/Comments:
    1. Can you check the STL file for the bevel gears? After slicing, my gears turned out to be too large for the tellurian.
    2. I agree with your conclusion that the 48m1 gear is too close to the other gears. On my print, this caused binding and tightness. I removed the 48m1 gear bearing and used a round file to carve the hole so I could "move" the bearing/gear to a sweet spot where no binding occurred. I filled the resulting gap with pieces of wire brads to hold the bearing in the place. (I'll glue it all up eventually). What a difference in how easy the gears meshed after moving the 48m1 gear!
    3. I haven't glued on the sun, moon, and earth yet. I'm concerned that the moon and earth spindles may be too small for the marbles I'm using, but we'll see.
    3. I agree that a knob would be better than a crank.
    Thanks again for creating such a precision project on a 3D printer.
    Hi and thank you.
    1. The first bevel gear STL I uploaded was incorrect, as pointed out by Styxman53. I corrected this error the day it was pointed out, so just download the bevel file again (it's got a different name, slightly).
    2. I also included a revised orbit arm with increased 48m1 clearance on the final page, along with some improved drive-train gears with dogs to prevent slipping on machines that have been dismantled several times.
    3. Have you used bigger marbles than me? I think the spindles are okay - any larger and they will detract from the appearance IMO. Hot melt glue worked really well for me and there's plenty of contact area for a reasonable bond.
    4. I agree but IMO a crank is aesthetically preferable. I think the crank will work really well if some weight (not much) could be added to the end of the orbit arm. I'm wondering if some washers could be embedded in the crank housing or something. Try gently pressing down on the crank housing as you work the crank and you will see what I mean.
    I'm delighted you are building one of these. Please post an 'I made it' photo when you are done.
    Hi Dr_phil,
    If you ever come to The Netherlands, don't forget to visit a city named Franeker.
    Check out this website:
    https://www.planetarium-friesland.nl/
    Same as your project, but build a "little"bigger between 1774 and 1781
    Thanks for sharing your project,
    Arie
    Arie - that place looks great. I will add it to my list! I love this sort of stuff...
    Thanks loads for updating the files so quickly! The build is quite a good one and I managed to locate the Lunar Eclipse set to give it that Zing, plus printing the gears in Gold filament adds that touch of class(Not that it's lacking!)
    Let me know when you finish the new drive system, as you are correct with the slippage problem I had similar with the Solar System Orrery I'm still fetteling. As a suggestion, try Epoxy on the shaft? it's strong grip may help?
    No problem - it was the least I could do after you went to the trouble of making it all! When you've finished please would you post an 'I made it!'?
    I have added dogs to some of the gears and shafts in the drive chain which has eliminated the occasional slippage. I didn't want to use adhesive as it's effectively irreversible, whereas these gears can still be removed in principle (with a screwdriver blade). I will add an extra page to this instructable with the revised parts and also a new orbit arm with extra clearance for the 48m1 wheel.
    Very well done! That is a great project to do over a while with all the printing time. Thanks!
    Thank you. I am a bit limited on free time so my typical working pattern was to design a new or modified part every Friday late afternoon and set it running on the printer during the evening. Then I'd have the rest of the weekend to incorporate it into the tellurion. Even so, the most complex part probably only takes a hour and a half (at the speed I print). Take it slow and enjoy it. You can build a simple version (just showing how the months work) with a subset of the parts, to keep you motivated...
    Amazingly well done. Have you considered making a motorized version? That would definitely be something I would like to make.
    Thanks! I think these devices are more for casual demonstration of phenomena than for making predictions, so I didn't really consider a motor to be necessary. I also didn't want to mess around with power supplies, switches, wiring etc. which would detract from the overall appearance of the device. I'd also need to shift the drive from the circumference to the sun axis. This job was effectively a feasibility study for an astronomical clock build that stagnated a few years ago. My plan for that device is to have an earth-centric depiction of the heavens that will be motorised and will reflect the current state of the sky. Watch this space...
    This is a beautiful project! Such craftsmanship! It really looks like something you would see in a catalog, its so well done! Kudos!!!
    Thanks for your kind comments. I should probably have varnished the baseplate before I published but I was worn out by that stage!
    awesome, thanks for sharing. the Earth rotating is uncommon feature, so thank you.
    Thanks. I think it's a pain to have to rotate the earth because a day is 1/365th of a year and the gears involved can get onerous. Nevertheless, when you see it going with the earth whizzing round it's definitely worth the effort...
    Thanks Yoruk.
    This is fantastic! I've always wanted to make one of these. I assume that if you converted the STL files to run in a CNC machine you could cut them out of wood or aluminum, right? Or is there something in the design that makes them optimized for plastic?
