TRASH-BOT. (Arduino Auto Open Close Trash Bin)
2,233
27
4
Published
Introduction: TRASH-BOT. (Arduino Auto Open Close Trash Bin)
About: A Computer Science and Engineering student and a Hobbyist. love to make robots,electric devices,diy things and Programming them by Myself. My youtube channel FUSE BATTI https://www.youtube.com/channel/UC-Rb...
Everything's getting smarter right? So why not your Trash Bin? This trash bin Opens and Closes its lid if it sees any Rubbish in front of it. You just need to bring the rubbish to it and it'll open automatically and will wait for you to feed it more then after a certain delay it'll close automatically. Watch the video to see exactly what it can do.
Post on https://www.blogger.com/blogger.g?blogID=731326532...
Let's get started.
Step 1: Parts You'll Need
1.Arduino (any board)
2.Servo motor (i'm using micro servo sg90)
3. HCsr04 ultrasound sensor
4. Servo arms (beside the servo in pic2)
3. Card Board (just slice piece)
4. Trash Bin
Step 2: Build the Circuit
The circuit is so easy. As the servo and sonar only takes less power you can just power them directly from arduino 5v source. Just remember to power the Arduino with more than 7.4 V DC or at least 7v.
Servo data (yellow) to pin 3 of arduino
Servo vcc (red) to 5v of Arduino
Servo ground (black/gray) to Arduino Gnd
Sonar sensor trig to Arduino 6
Sonar sensor echo to Arduino 5
Vcc to Arduino 5v
Gnd to Arduino Gnd
Step 3: Connect the Servo Arm
Just take this servo arm and connect it to a long card board piece with hot glue or other glues. You can also use Ice Cream stick instead of Card Board. Then connect the long servo arm to servo motor.
Step 4: Add Servo & Sonar Sensor to the Trash BIn
Connect he sonar sensor facing up to the Bin like this. And then add the Servo motor like this on pic 2&3, so that the servo can rotate to up .
Step 5: The Code
Code link https://github.com/ashraf-minhaj/Trash-bot
I've programmed the arduino so that if it sees any rubbish (literally anything) in 50 cm range the servo goes to 50 degrees and hits the upper lid of the bin, so that the upper lid gets open and then waits for three seconds then automatically turns to 160 degrees and thus the upper lid gets closed. Thus you see an Auto Open Close TRASH-BOT.
#include<Servo.h>
Servo servo;
int const trigPin = 6;
int const echoPin = 5;
void setup()
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
    servo.attach(3);
void loop()
{       int duration, distance;
digitalWrite(trigPin, HIGH);
delay(1);
digitalWrite(trigPin, LOW);
// Measure the pulse input in echo pin
duration = pulseIn(echoPin, HIGH);
// Distance is half the duration devided by 29.1 (from datasheet)
distance = (duration/2) / 29.1;
// if distance less than 0.5 meter and more than 0 (0 or less means over range)
if (distance <= 50 && distance >= 0) {
	servo.write(50);
    delay(3000);
} else {
	servo.write(160);
// Waiting 60 ms won't hurt any one
delay(60);
Step 6: You Are Done
So now just power the arduino with more than 7v and you have a trash bin robot.
Thank you.
[If you like my Works please support me by Subscribing my YouTube channel]
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    4 Comments
    Sweet! Great way to style up the trash, I like it!
