TerraDome : Mini Tropical Greenhouse With Arduino
10,629
132
12
Published
Introduction: TerraDome : Mini Tropical Greenhouse With Arduino
About: Passionate of DIY of any kind, I am not of the trade (I am developer in computing) but I am self-taught and I like to learn new things. I decided to share my creations with you through photos and videos. I ...
TerraDome is an indoor greenhouse for plants and tropical flowers shaped octagonal dome.
It is driven by an Arduino Mega that regulates temperature and lighting through different sensors and an LCD display. It also has doors to the Jurassic Park (or Jurassic World) that opens when the temperature is too high in the greenhouse.
Video:
Dimensions:50 x 50 x 45 cms
Time spent:35H (out of study)
Tools: Circular saw, ripper, drill press, miter saw, jigsaw, Dremel, hand tools ...
Electronic Material :
Other:
Plan of the greenhouse, electronic diagram and Arduino code to download in ZIP:
Step 1: Tinkercad 3D Model
I drew the Terradome in 3D using Tinkercad
For the octagon I used an 8-sided polygon, I added a smaller one in piercing mode and I merged the 2 to keep only the edges. Windows are "boxes" in transparent color.
Step 2: Woodworking
I used 19mm MDF for the base and 10mm for the rest.
To have an octagon with 8 equal sides, I used a website where I just entered the radius of the circle (25 cms). Which gives me sides of 20.71 cms.
I cut out the contours with the circular saw, and the internal cuts with the jigsaw.
I also made a hole of a diameter of 8 cms with a hole saw for the fan.
Step 3: Grooves for Windows
I created grooves on half the thickness of the wood to fit the windows. For that I used a Dremel with its router accessory (335).
For the roof, the windows being sloping, I used a triangle cutter with my router.
I finish with the rounding of all the edges with my router fixed under the workbench.
Step 4: Paint
I applied one layer of wood primer and 2 coats of gray paint spay.
Step 5: Cutting Windows
For the windows I used transparent polystyrene 2.5 mm thick. More resistant than glass and easy to work, it offers a beautiful transparency.
I cut it with my Dremel DSM20 which makes a clean cut without shards.
I measured the distance between the blade and the edge of the sole, I draw 2 lines on the wooden board, and I use it as a guide to cut all windows.
Step 6: Base
The windows are glued with transparent silicone, which seals at the same time.
Step 7: Roof
For the roof of the dome, I started by gluing the bottom of the windows, I held them between them with tape, and I added the top.
I then grouted all the edges and smoothed the joints with water and soap.
Step 8: Ventilation
I recovered the fan on an out of service computer power supply.
I tested it under 5V instead of 12V, the speed is low but sufficient for this use.
I soldered fine white wires that will be hidden in the window seals. The fan is then screwed onto the dome with its protective grille.
Step 9: Miscellaneous
To facilitate the opening (when watering plants for example), I installed 2 hinges at the back.
I drilled 4 holes on 10 mm deep and I cut 4 plastic tubes that will serve as feet.
Step 10: Doors
The doors are inspired by Jurassic World (or Parc).
I created a base that contains the 2 servomotors and 2 LEDs with wood chips and cleats.
The doors are made of 5 mm plywood glued to wood glue. They are operated by their axes from 0 to 90 degrees.
The orange and blue Indicators mimic those of the Jurassic Parc fence.
Step 11: Electronic: Main Unit
For the main unit I used a recovery box that I cut out to fit the display.
Of course an Arduino Mega is oversized for this project but I used what I had on hand. An Arduino Uno is enough.
The Arduino is directly powered by 5V so be sure of your power because we do not go through the regulator in this case!
For the display is easy because as it is a shield, it connects directly to the Arduino without any wiring.
Step 12: Electronic: Tic Tac Unit
For the Tic Tac module I used a test platinum drop where I welded the components (the temperature / humidity sensor, the light sensor and the 2 RGB LEDs). The power supplies are thus grouped together and this limits the number of wires.
Everything takes place in a box of candy TicTac, pierced below at the temperature sensor. It is connected to the main unit by a ply of wires with pins for the Arduino.
Step 13: Electronic: Power Section
The power section (under the greenhouse) includes:
  • A 230V -> 5V DC 3A power supply that supplies all low voltage components
  • 700mA constant current power supply for special LED plant lighting (as required in the doc).
  • A 2 relays board to control heating and light (220 V)
Step 14: Arduino Code
I used 4 libraries (in ZIP):
  • LiquidCrystal.h: to manage the LCD display
  • RGBLED.h: for the 2 RGB LEDs
  • Servo.h: for the 2 servomotors
  • PID_v1.h: for PID temperature control
The display shows continuously the temperature, the humidity level and the light level (1 to 10)
The + and - buttons (up and down) adjust the temperature
The < and > buttons (left and right) adjust the brightness threshold to trigger lighting
The lights can only be turned on / off every 60 seconds to prevent nuisance tripping.
The heating / ventilation and doors group is controlled by the same code part:
If the temperature exceeds the set point + 2 ° C (ex 30/27° C):
  • LEDs turn blue
  • The heating goes out
  • Doors open (indicated by orange / blue LEDs)
  • The fan turns
If the temperature falls below the setpoint - 2 ° C (ex 24/27° C):
  • LEDs light up red
  • The heating starts
  • Doors close (indicated by orange / blue LEDs)
  • The fan stops
In other cases (ex 28/27° C):
  • LEDs light green
  • Heating stays on standby
  • The doors remain closed
  • The fan remains stopped
Step 15: Electronic: Heating and Lighting
The LED headband accelerates the growth of plants. Thanks to the high proportion of red and blue lights needed for photosynthesis, the entire light spectrum is covered, which promotes plant growth.
For heating I used a special reptile 7W heating mat that radiates gentle heat. As I'm going to regulate the temperature through electronics, I remove the rheostat.
To shut down the system at night, I used a simple time programmer.
Step 16: Plants and Decorations
I ordered 4 tropical plants on the Internet:
  1. Cryptanthus Bivittatus - The earth star
  2. Fittonia verschaffeltii - Pink and green
  3. Hoya Kerrii - Heart plant
  4. Begonia bowerae Tiger
For the moment they are small, there is more than to wait that it grow!
I added white gravel and pine bark for decoration. And of course, a dinosaur and Jurassic Park Jeep to stay in the theme!
Step 17: The End
Done! Tell me what you think and ask me your questions, I will answer with pleasure!
Step 18: Just for Fun ;)
The first dinosaur incubator with Arduino! ;)
Planter Challenge
This is an entry in the
Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    12 Comments
    Thanks a very nice project! My French is rusty... but I enjoyed watching the process of building it. Your video was very well done -- good job!
    Thank you ! I still have to add English subtitles on the videos, it will help understanding ;)
    Thanks, that's nice :)
    very cool and also useful! But don't tropical plants need a high humidity? I would have expected a small humidifier from a piezo cell, or bought design, to raise humidity with the help of an underneath water tank to raise humidity if needed.
    I am very tempted to reuse all of this design for a larger size design and put some larger plants in my living room!
    Merci beaucoup!
    Thank you ! Yes I thought at the beginning to add a system that increases the humidity but for that it would have to review everything and isolate all the electronic part. For example by putting the control panel under the greenhouse.
    If you're inspired by TerraDome I'd like to see the result;)
    They hide a big danger! lol
