Two Sided PCB Using Toner Method
210,323
431
123
Posted in TechnologyTools
Introduction: Two Sided PCB Using Toner Method
This describes an easy method to make professional looking two-sided printed circuit boards at home.
Step 1: Get Ready
This instructable assumes that you know how to generate a layout file using Eagle PCB or similar layout program. I use the toner transfer method of making PCB's (printed circuit boards) much like many others. The basic idea is to use a glossy paper, print the PCB design on the paper using a laser printer, and to use a hot iron to transfer the toner to the copper. I use the glossy paper that they have behind the counter at Kinko's. Go to Kinko's and ask for some sheets of their glossy laser paper, which is really cheap (about 5 cents a sheet). Some people advocate using glossy inkjet photo paper, but I think this is a waste and the cheap glossy laser paper comes off easier.
Anyway, once you have your design and paper, you will need to print the design. The key here is to mirror the top layer so that it will come out correct once transferred to the copper board. It can also help to include alignment marks (the T shaped things in the pic) beyond the edge of your PCB to help you align the two layers. See below.
Step 2: Align Layers
The next step is to cut out the top layer and bottom layers, and to place a small loop of scotch tape on one corner of the top layer to allow you to tape the top and bottom layers together once they are aligned. You want to cut the top piece smaller than the bottom so that you can stick the top to the bottom. Leave some room around the edge of the design so that no copper will be visible. See pic.
Now, take the two paper pieces with the top and bottom layers printed on them and go to a window or patio door. It needs to be daytime since you will be using the backlight from outside to see through the paper. Place the bottom layer on the glass, and then taking care not to stick the top piece down yet, align the two paper sheets using the alignment marks, your vias, features or other method. When aligned, stick the top to the bottom. Carefully lift another corner of the top piece and add another roll of tape to keep the layers aligned. The key is to make sure the tape will not interfere with the copper board being placed between the sheets. See pic.
Step 3: Iron It On
With the two paper sheets taped together, turn on your iron to the highest setting. Also make sure there is no water in it if you have a steam type iron. Now, take your sheet of copper board and slide it carefully between the two sheets. See pic below. Position the copper clad board as desired, and once the iron is hot, place the iron on the paper and press hard. It takes some practice to get the hang of ironing on the toner, but just press hard and wiggle the iron over the whole board while taking care not to move the paper relative to the board. Once one side is ironed to your satisfaction, then carefully flip the whole thing over and iron the bottom layer. One thing to remember is to clean the board carefully with a cotton ball or old sock soaked in isopropanol (rubbing alcohol) before ironing to remove any finger prints or grease.
Once you are done ironing, cut the paper around the board if desired, and drop the paper and board into a container of water to soak the paper. Let this soak for about 10 minutes. With the cheap glossy laser paper from Kinko's the time is much shorter than the high quality inkjet photo paper. Once the paper is soaked, peel the paper off both sides. This should leave the toner and a thin layer of the paper along with the glossy stuff on the copper board. Using your thumbs or an old toothbrush, carefully rub off the extra paper pulp and junk on the board. See pic, below showing a board with half of the pulp rubbed off.
Once the paper pulp is rubbed off, carefully inspect the traces and features on the board for small imperfections and stuff that will cause problems later. Key areas to pay attention to are closely spaced traces and pads where it is easy for paper or glossy coating to bridge and keep the copper from etching. Also, you can achieve very fine pads for doing TSSOP, QFP, and other fine pitch packages using the toner method if you carefully scrape between pads using an Xacto knife or similar prior to etching. During ironing, the toner tends to smear slightly, so very fine pitch pads tend to mush together. Using the knife, you can scrape between the pads or traces to make sure the copper will etch between. If you are careful, there is no reason you can't get 800 micron or even 500 micron pitch pads.
Step 4: Etch and Clean
When you are satisfied that the critical small features are ready, then put your board in a plastic or glass container and pour enough PCB etchant over it to cover it. I use the Ferric Chloride etchant sold at Radio Shack. Gently swirl the dish with the board and etchant until it is finished. Careful not to spill on anything metal and chromed since the etchant will mess up the finish with a quickness. In most cases, where the bottom layer has a few traces and a ground plane, it is not necessary to flip the PCB during etch. Just make sure to get the board moving around the container so that the bottom etches too. If you have detailed delicate features on the back, you may want to lift the board repeatedly during etching with a plastic fork in order to help the back etch without scratching it. See pic.
When the board is done etching, you need to get the board out and rinse it with lots of water. Dump the used etchant in your toilet and flush it as recommended by the manufacturer on the bottle. As you can see from the pic, you should be able to hold the board up to a light and see through the board at this point to verify the alignment of the top and bottom layers.
Cleaning off the toner is a pain in the butt. The easiest way is to use an aggressive solvent such as brake cleaner or acetone (nail polish remover) and a rag to rub the toner off. Using your preferred method, scrub the toner off the copper and get out your multimeter to test if any of the traces are shorted together. I find that long parallel traces often have small shorts between them if you don't get all the paper off prior to etching. A toothbrush helps. If you find that some traces or pads are shorted, then using an Xacto knife or similar, scrape or cut the copper until the circuit is open. Once all the circuit is verified in this manner, you can start soldering down the parts. I find that putting the fine pitch components down first is key, so that you can verify each pad as you go. Since the toner smooshes the pads of QFPs and TSSOPs and the like together, it is easy to form a solder bridge between pins. Take your time and have your solder wick handy.
Happy building!
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    123 Comments
    See the images.
    You can get good result easy.
    Just use FAIRY (dishes cleaner) and a kitchen sponge with a abrazive green part
    to clean well the copper board. after that just dry well with paper towels and
    put your pice of paper from the printer. use the iron, mine is PHILIPS AZURE 2400W(cheap one, normal one).Press with iron for 5 to 10 minutes(moving and pressing), after that pull the paper, soak in water for 10 min or so.
    start rubbing with your finger and with toothbrush until traces clean withouth paper.
    then use feric cloride to etch.
    that's it.
    sory my bad english.
    want to know more just send private message.
    or also leave here a message.
    bye.
    samsung clp-365w doesn't work, toner doesn't stick to the coper. Also don't use inkjet photopaper because you will not get it of the pcb
    Wow, those look beautiful! I just purchased a high resolution laser printer. I will have to try to find the same paper you used. It came out so nice!
    Hi Bowtie41,
    Print your schematics, go to Photocopy Shop / Copy and Printing Services Shop nearest and you bring your own Inkjet Printer or clean used Calender Paper... Give it to them... Cheap ±$0.05 USD services...
    *Print your schematics to standard / blank / white or colored paper...
    I have a inkjet but want to make my own PCBs so I've been looking at used laserjets.I need some info before I buy one please?Are there any known brands of printers and/or toners that WON"T work?Also,does the toner image have to be black ink?I found a nice used Dell 3000cn that was low on black and yellow,but comes with 5 new cyan cartridges!Thank You for any input you can provide!
    My understanding is that it is the "fusing" of the toner to the PCB that is important to the PCB etching. So color should not impact performance and cyan should work. I have not had any experience with a laser printer or toner that did not work, nor have I kept track of ones that did work, they all did, but YMMV. Good luck.
    May I suggest that you take a hole puncher and punch a few holes in the un-printed perimeter of the "top" sheet (in the non-image area). Align over the other print as described over a window or lightbox, and when things are aligned, apply tape over the holes, which will hold the sheets together sufficiently for you to then tape a more durable seam (which can be made by setting both pieces of paper on a paper cutter, preferably a rotary type
    An alternative is to just print the two masks alongside one another with alignment marks on the "outboard" sides of each and a centreline between them -- then gently fold while over a lightbox/window, get the alignments right and smooth out and flatten the loop of paper to fold, which should crease right along your centreline. Look ma, no tape.
    I print my transfers on small pieces of transfer paper taped down to a carrier sheet, which is passed through the printer once as plain paper, then I tape working size pieces of transfer paper down and print it a second time. This conserves the (slightly) more expensive transfer paper.
    Owing to slight variations in the paper feed, the transfer sheets may not precisely align to the original prints -- it's easy enough to then fold the original paper as above, and re-position the transfers over the sheet using the lightbox.
    Great ideas. Thanks!
    How did you add the alignment marks in Eagle?
    I made a dummy part with the desired shape, but since it is also nice to have the alignment marks outside the PCB area so you can verify the layers are still aligned after inserting I've had to add marks manually to the PDF. This is due to the size limits placed on the free version of Eagle. If your PCB is small you can add marks in Eagle directly. In the pictured PCB I am fairly sure I had to do it manually. So I'd export the PS/PDF and open it in a drawing program (such as inkscape or illustrator) and add the marks manually.
    Don't flush ferric chloride down the toilet. You can easily save it in a jar for later reuse! I use glass baking style pans for etching, and just snap a cover on, and I'm ready for the next etch later.
    A) Unless you have all-plastic pipes, it's not good for them, B) it's a strong acid, and even if you neutralize it with baking soda or lye, C) it contains copper after you're done, and copper is difficult to remove at the treatment plant, and toxic to marine life, and D) it's illegal in many places in the U.S. As someone else mentioned, if you have a septic system instead of a public wastewater system, you might create a multi-thousand dollar problem for yourself.
    I don't know a good thing to do with used up ferric chloride, but mine lasts a really long time, partly because I fill my designs with big areas of ground/power plane so I don't need to etch away much copper. For the couple of batches I've eventually disposed of, I neutralize it with baking soda, evaporate it, and take the residue to our local hazardous waste disposal along with batteries, paint and fluorescent lights.
    Nice of you to do that. Why not use HCL and H2O2, its really effective and fast.
    Just a tip...
    I have successfully used an ultra fine point Sharpie to draw traces that were scrubbed off or didn't stick.
    I don't recall, but i may have applied more than one layer of sharpie ink.
    (my etchant was was muriatic acid)
    J:\Électronique Marc\PIC\A faire
    I made a board for STM32F103C8T6 ARM CORTEX-M3
    48 pins, TQFP.
    Just post comment if you want to know what paper and iron to use.
    I get good boards like this in half hour.
    Just check the fingerprint for that microcontroler, to see how small shoult be.
    Always get good result.
    I can't let the mail here because I will receive a lot spam in it.
    So just leave message here.
    I don't need money or anything!
    See the photos for what I use.
    The iron is PHILIPS AZURE 2400 WATT( normal one).
    also get the board for the STM(NOT THE ONE I USE, AN OLD DESIGN ONE BUT GOOD), just for testing.
    OK. Now you have it all!
    but the most important is cleaning the surface of the board.
    with FAIRY(yes dishes cleaning for kitchen and a sponge with a green abrasive face. use the green abrasive face)
    I use the Paint from windows to draw!
    OK. if some of you think I should put a tutorial just send me messages.
    Thanks.
    Consider using a laminator instead of a hot iron. I've used hot iron before and it's a pain. As soon as I tried laminator, I never want to use a hot iron again. For example, a GBC pouch laminator from amazon works just fine.
    Good tip. Thanks.
