Wood and Resin LED Lamp
6,089
113
9
Published
Introduction: Wood and Resin LED Lamp
About: Hi I'm Tyler and I do everything around our home myself. Follow along with me as I make our home a better place!
A decorative build to brighten the mood wherever you are!
Step 1: Cut Lamp Piece
Cut the portion I wanted to use as the lamp from a Cherry slab using a Jig saw.
Step 2: Stabilize Wood
The section of cherry with the most impressive grain patter was slightly rotted so I used Minwax wood hardener to firm it up. This is basically a super diluted CA glue that stabilizes the wood.
Step 3: Flatten Slab
This section of slab was wider than my 6" jounter so I used a flattening bit on the router with a router sled to flatten the piece. I agree this is big time overkill but I wanted to practice the technique for a later more expensive build.
Step 4: Make Form
Used some scrap 3/4" melamine to build a form for hold the epoxy around the lamp wood. I coated the melamine with a thin layer of past wax to aid release when the epoxy had set up.
Step 5: Pour Epoxy
The epoxy needed to be poured in 3 layers to prevent overheating. Mixed the resin and hardner in a solo cup and poured into my form. I used a heat gun to help pop the air bubbles as they floated to the top. I did not want all the bubbles out as I wanted this piece to look like water when you are swimming under it.
Step 6: Remove Form
After a few days of hardening I removed the forms and was SUPER happy with the results so far.
Step 7: Plane
The planer makes quick work of removing any excess epoxy.
Step 8: Power Sand
Sanding from 60 to 220 grit with a random orbit sander.
Step 9: Hand Sand
Then sand by hand using 600 and then 2000 grit wet sandpaper.
Step 10: Polish
And lastly polish using some scratch remover and a polishing wheel on a drill.
Step 11: Make Trim Molding
I dadoed a groove in some cherry trip to hold the LED strip and controller.
Step 12: Add LEDs and Trim
LEDs were wrapped around the corners and held in place with hot glue. The trim mitered and fastened in place with fast setting CA glue.
Step 13: Finish
Used Arm R Seal to finish the wood. Be careful not to go over the epoxy as it will drip and ruin your beautiful polish job.
I put this lamp on my desk at work and have gotten a lot of comments about it, it looks pretty cool! Super fun build and works great as the decoration to brighten the mood in your space.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Questions
    Looks like a fun project and a beautiful lamp, but wondering how you turn it on and off? You mention a controller but not sure where it is and how it works.
    Thanks,
    Jillllee
    There is a small remote for the control that is in the dado made in the trim. Video shows the process.
    9 Comments
    So cool. Well done video. I’ll have to keep my eye out for the perfect piece of wood now. Engineers of the world UNITE!
    it`s so cool, I like it and will make it!
    Really cool project. If you add some flickering LEDs it would make a cool fireplace insert.
    Funny I was thinking about that this morning!
    Very cool! Now I just need a toolshed with all the awesome tools in them to start :)
    The main tool I used was a router....not a very good excuse! :)
    very cool! Awesome your daughter gets to watch you being creative. You need to use this tech 2 make a ring for your Daughter. I have seen a similar method used 2 make rings on instructables. They glued strip of scrap wood together but the key was 2 leave 1 end frayed or splintered of each the strip you glue together. Then they made the mold added epoxy with some different dyes 2 make epoxy like a sunset and some dye went into the splintered wood making them look like a Forrest . Then they bore a hole for the finger and polished like you. Your Daughter will be the hit of the office when she visits you with her matching ring- making sentimental b/c you tell her the lamp reminds you of her while @ work & her ring reminds her of you while she is at school.
