Wooden Carved Bowtie
263
Published
Introduction: Wooden Carved Bowtie
About: Welcome to my page! Here you will find creations done by myself or my friends. What's on the menu : Learn how to make anything ! I'm not a professionnal in every field, but I will show you how to make furnit...
In this Instructable, I will teach you how to make a wooden bow tie, a good way to make an impression at a party. This 'ible is quite easy and the material needed easy to find so it is a perfect project for a beginner.
You can watch the build through the video or simply read the following steps for more details ;).
Step 1: Material and Tools
You will need :
  • Wood (obviously), you can use any kind, in my case it was walnut
  • An old bow tie you don't use anymore for the locking mechanism
  • Sand paper
  • Mineral oil (or varnish)
  • PVA glue
  • A saw : bandsaw, scrollsaw, a regular saw, any will do
  • A Dremel rotary tool
Step 2: Trace the Bow Tie on the Wood
Take a rather slim piece of wood (less than 10 mm thick), and draw a bow tie on the wood. If you're not sure about the dimensions, you can still find a model on the web, print it and draw the outline on the wood.
Step 3: Cut the Wood
This step is straight forward, you drew the bow tie, now you have to cut it. Just like at kindergarten, you try to follow the line. Anyway it is still possible to correct a mistake with the next step.
Step 4: Giving Depth to the Wood
First of all, draw lines on the bow tie to mimic folds in fabric, then follow those lines using a Dremmel and a carving bit. While you're at it, use the Dremmel to soften all the angles and correct the small mistakes made at the previous step. Make sure you have the object the closest from what you want it to be, it will make finishing easier.
Step 5: Finishing the Wood
Take some 80 grit sandpaper and sand all the wood to smooth it out, once it is done you should have a bow tie that looks like a real one. Continue sanding with higher grit (120, 240, 320 and more) to obtain a super smooth surface.
Finally, apply mineral oil or clear varnish on the wood to make the grain pop.
Step 6: Adding the Clip
For this step, get an old bow tie that is not used anymore (you can also find them at thrift shop), and remove the bow knot to keep only the choker. The most resourceful of you may even sew their won clip with a band of fabric.
Now, all you have to do is to glue the fabric on the wood with PVA glue and want for it to be dry. I did not have a small clamp on hand to maintain the fabric, I made made one out of PVC tube, a very handy tip when you lack a clamp.
Step 7: Wear It
Here is the result worn !
If you like my Instructable and want to see more, you can subscribe on my Youtube channel : https://www.youtube.com/channel/UCBTC9EX_tzzbslbxbwbjp8A .
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
