How to Make a Green Lantern Power Battery (Hal Jordan's)
109,557
325
71
About: DELETED PROFILE CACHE
Here is how to make a working Green Lantern power battery (Hal Jordan's version) for around US$20.  My son (5) has decided that the Green Lantern (especially Hal Jordan) is the coolest superhero ever, so for Christmas 2009 he will be getting Hal's Green Lantern power battery (the flower pot edition).  The Green Lantern (Hal) comics seem to have a variety of different looking power batteries depending on year and artist, so this is an attempt for the middle ground.
If you would like a more modern power battery, see related instructable - How to Make a Green Lantern Power Battery (2011)
Supplies:
Step 1: Materials
You will need...
4 x Plastic flower pots (for the cones top, bottom and sides)
2 x Plastic flower pot trays (to enclose and lengthen the top and bottom cones)
1 x Christmas decoration/bauble - 8" for full size (the lantern's center)
1 x Camping LED lantern (to make it glow)
2 x Green plastic lids (for the lantern's 'glass/lens') * see below for substitutions
2 x Bike grip plugs (for the handle fixtures) * see below for substitutions
1 x Paint pail handle
1 x Sheet of rubber foam (for the Green Lantern symbol on the top)
2 x Bolts and nuts (for having access to the batteries etc)
Liquid nails (or suitable glue)
Forest Green (Metal Hammer) spray paint
Duct tape (always handy, especially to hold glue while it sets)
Sand paper
Drill (with hole saw bit)
Scissors and craft knife
Substitution ideas
* Green Plastic Lids (for the lantern glass):  If you don't have suitable lids for the lantern lens, look out for cheap drink bottles that you can cut the bottoms off, otherwise any round piece of green plastic should do.
* Bike Grip plastic plugs (for the handle fixtures):  I just replaced my wife's bike handle grips and so used the ends of her old ones, but I thought of using the middle bit of a cd spindle lid or perhaps even soda bottle lids.
Step 2: Forming the Top and Bottom Cones
With a craft knife cut off (and discard) the bottoms of two of the flower pots.  Dimension-wise I would suggest that we want the cone to be approximately twice as high as the flower pot trays (as we will attach these latter to increase the height and enclose the cones.
Step 3: Drilling Out the Center Bauble
Taking your drill with a hole saw bit (the kind you might install a deadlock with) drill out a hole at the base (for the lantern light to shine through), and two side holes for the light to shine from.
Step 4: Attaching the Cones to the Center Bauble
We want to leave the base cone to be able to be opened to access the lantern light (and change batteries etc).  So we first want to glue 2/3 of the bottom cone to the base of the bauble, as this is where the light with the final 1/3 will be attached later.
Disassemble the lantern and glue it to the bottom flower pot tray, making sure that the lantern light is centered and it can fit into the bauble.
The top cone may now be enclosed by gluing the flower pot tray onto one of the cut flower pot cones.  We can now glue this cone to the top of the bauble.
Step 5: Forming the Side Cones
Trim the last two flower pots with scissors so that they retain an outer lip and that their length is approximately 2/3 of the top/bottom cones.  Sand the cut edges with sand paper to help with a clean fit against the bauble's surface.
Step 6: Attaching Side Cones and Handle Fixtures to Bauble
Attach side cones over the bauble's side holes.  Also attach the bike handle grip ends 90 degrees to the cones.  Attach paint pail handle through handle fixtures (I would suggest to drill through the bauble and push the handle wire into the center for strength.  I bent the paint pail handle to be approximately twice the diameter of the ends of the side cones.
Step 7: Cut Out Green Lantern Symbol and Attach Ready for Painting
Cut out a Green Lantern symbol with a craft knife and glue it to the top cone (match orientation with the lantern itself).  I would suggest printing the symbol out and gluing the symbol to the foam as a template guide.
Sand the surface of the lantern, wiping off any dust to prepare for painting.
Step 8: Spray Paint Lantern
Place the lantern on a box or hang it from something before painting.  Spray paint gets everywhere so perhaps do this in your garage or somewhere sheltered outside.  I would suggest wearing a mask and perhaps eye protection.  Keep the spray can about a foot away from the lantern (it is better to do many light coats than one heavy one).  I would recommend using forest green metal hammer effect spray paint.
I placed a couple of tissues in through the side cones to protect the lantern LEDs.
Step 9: Attaching the Green Lenses and Tidying Up
Glue the green lids over each side hole.  I found a slightly lime green color seems to create a fantastic green glow illusion.
You can attach the base by drilling through the bottom of the bauble and bottom cone base and attaching bolts.  Also, you may like to have the switch to turn the lantern on underneath by drilling an additional hole in the base.
Step 10: The Finished Product
Now all you need is a Hal Jordan Green Lantern ring.
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    71 Discussions
    rocketsurgeryErnext
    Reply 4 years ago on Step 10
    Thanks but genius is more like Golden Snitch Earrings or Ragnarok the Crona's Sword! Love your instructables especially the use of cold porcelain.
    isac.duncan.1
    4 years ago
    Thank you so much I was thinking I could do the same thing but for the blue or orange power battery but I will probably skip the light part and I was thinking I could use my old soccer ball and cover it in orange leather or cloth but if that doesn't work I'll come up with something to work with what I have at home.
    Sounds great - although I think I'd lean towards hope more than avarice :) If you do build something post a picture :)
    jguzman17
    4 years ago
    I made one using a Brooklyn lantern thanks for the idea. this is how it looks with the lens removed.
    hysherwood
    7 years ago on Introduction
    thank you so very much for this instructable...Will finish it up sometime this week...May make a bat signal next weekend.
    429071_2623598226016_1137048939_32024897_2062900238_n.jpg395283_2623599706053_1137048939_32024898_1363205610_n.jpg
    FrenchJoker
    Hello ! Following this tutorial, my best friend made a lantern that light up too^^ Great success! I ask him to do an orange one for 2012...
    387480_270996052938319_100000837807330_703353_1094174598_n.jpg71923_160346180672745_156864124354284_306001_2866379_n.jpg
    rayduch
    Found your make and it allowed me to get this done in time for "Trick or Treating" for my last minute Green Lantern kid (6 yr.old). The best part was "my daddy made it for me" every time someone who recognized what it was asked where he got it. Thanks alot!
    rocketsurgeryrayduch
    What a great job! In time for Halloween too!! Thanks so much for sharing your photo - so glad you found the 'ible useful!!
    cvanscott
    Here is my version based on your design. I deviated slightly, using a 6" bauble. For the lenses I used 2 clear acrylic hemispheres, which I painted with transparent glass paint. The paint ended up being TOO transparent, so I hit it with a coat of Frost Glass paint. That worked fairly well. Also, the lantern I used had a bottom battery compartment, so I cut a whole in the base cone bottom so you can access the battery door without taking the base of the lantern off.
    Thanks again for the instructions!
    hcosgrove974
    This is my adaption of your instructable. I just wanted to say thank you for your instructable and that it served me very well as I gave my adaption as a gift :)
    cvanscott
    What size is the Christmas decoration you used? I'm thinking it can't be the standard 3" or 4" colored bulbs? BTW, great job! Thank you for posting this.
