100 Ton Steel Press Without Hydraulics for Bending, Crushing, Punching and Forming
You'll enjoy wielding the awesome power of the inclined plane in order to make this simple, cheap and very effective press.
In the vid you'll see me test it by punching 17mm holes in 8mm solid steel plate.
Supplies:
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    16 Discussions
    Take the clamping force of 1"-8 x 4 = 100 tons
    I took it up to it's practical limit punching big 36mm holes in 1/2" plate steel.
    Required force to do that is 80 tons. Close enough for the girls I go out with.
    LOL, I was just wondering if it was the limit of your muscle strength, multiplied by something clever to do with the length of your wrench and the angle of the thread...
    458WM
    2 years ago
    It would be really nice to see a video describing the operation of this press and showing the real time speed of it to determine if it could be used as a forging press as billets cool down pretty fast so you only have a limited amount of time to use a press.
    Pkranger88
    5 years ago on Introduction
    I'm really not trolling....
    Something I learned in my last job was pneumatic impact impact hammers for tapping.
    I was the Engineering manager for a for a aircraft parts manufacturer. We used impact hammers for all our tooling threads.
    Hi PK,
    Sure you're not trolling ;). (still waiting for you to reply to my 100 clam bet.)
    I've shattered a few taps (shocking, I know) and when it messes up it takes more time to fix than just doing it by hand in the first place.
    What materials and thicknesses is impact tapping suitable for?
    Thanks!
    We've done impact tapping in mild steel and all grades of aluminum.
    At home I use my Ridgid X4 drill. It works pretty good. In my opinion, you can never have too much oil for tapping.
    I'm actually getting ready to run some 1-8 threads through some 1" plate for the leveling feet for the mobile base I'm making for my BP.
    I usually use the drill for smaller diameter taps.
    I haven't decided yet if I'll try the impact for the 1-8. I'll try to get vids. If I do, you'll see an instructable. I've been bad about actually getting projects loaded.
    kdavis47
    5 years ago
    Really cool, always wanted to purchase a hydraulic press for forming silver jewellery. Good thinking and superlative alternative. Ty my man of steel. Lol
    Kelli
    great project, I like you shared the grade of steel used. Your tips are great.
    aloomis1
    5 years ago
    Fun video and narration! What about putting a gear in the middle of the top plate and gears on the ends of each screw so it can be tightened and loosened uniformally from the center. Just a thought.
    The torque required to turn the screws at rated load is 650 lbs ft. x 4 = waay to much for a human powered device.
    I enjoyed making this incredibly dangerous and ill advised project. It took about 6 hours with a material cost of about $100, less if you've got steel scrap. In the vid I test it by punching 17mm holes in 8mm thick steel.
