10x5x5 Soccer Goal
16,225
21
10
In this Instructable you will find instructions for a simple fool proof soccer goal that a five year old could make for around $40.
Supplies:
Step 1: Parts and Tools
Parts:
-4x 10 Foot Lengths of 1-1/4 Inch PVC Pipe
-6x 90 Degree CONDUIT Elbows
-6x 1-1/4 PVC Couplings
Tools:
-PVC "Scissors"
-Mallet
Step 2: Cutting
Cut 2 of the 4 pipes in halve (5 feet). Leaving You with 4 pieces.
Step 3: Assembly
Make the pieces in the pictures.
Rough:
-2x 5' pipes with two elbows each
-2x 5' pipes with one elbow each
Base:
Add a 10' pipe in between the pipes with two elbows each
Front:
Add a 10' pipe in between the pipes with one elbow each
Final:
Put it all together
Step 4: Net
This is the link to the net I am going to order I will update the pictures then.
http://www.amazon.com/SSG-Shooter-Replacement-Soccer-Goals/dp/B001FEFOME
Edit:
Do NOT get  this net I sadly learned that the aditional foot and a half added by the elbows throws off dimensions. I am sure there is still a net that will fit out there somewhere.
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    10 Discussions
    FC boisehi111
    Reply 6 years ago on Introduction
    i lost my account so this is L.messi, but my name says FC boise. So do you have any other ideas on nets
    hi111EaglesSoar09
    you would have a major sagging problem it could even snap under the weight i never got a net for this i just use it without and it sags so i dont think it would work good luck
    Cykeltorest
    9 years ago on Introduction
    Lightweight and cheap!!  Can be designed for take-apart/ indoor use.  As far as the net... you have to cut more off the pipes (18" ) to allow for the extra length of the elbows. Piece of cake!
    lemonie
    This looks good. The great thing about soccer is you don't need anything more than something round and some markers for the goal. Good job (and nice lawn) L
