1:1 Scale Replica BB-8 Prop
107,877
719
77
Just prior to the release of Star Wars, The Force Awakens, I created a full scale replica of the lovable little BB-8. Working with a small budget, I relied on materials lying around my studio, and purchased only what I needed to. My replica was designed many for display, as it's non functioning, however, I did create a wheeled base that was allowed BB-8 to be pulled around.
Step 1: Building the Body
I was able to confirm that BB-8's spherical body is 20" in diameter. Using that info, I started by creating a line drawing using reference pics. I then scaled the drawing of the body to 20". Doing so gave me the proportionate head dimensions.
To create the body, I constructed the 20" sphere using EVA foam. 8 wedges were made to create each half of the sphere. The wedges are heated using a heat gun and slightly curved to achieve the proper shape.
Next contact cement was used to glue each formed wedge together, gluing 2 at a time. Each half on the sphere was then glued together using contact cement.
Step 2: Creating Circular Patterns
I gathered as many reference photos of BB-8 that depicted each side of the droid in order to achieve as much detail pertaining to his design as possible. This step took a lot of probing, guessing and filling in the blanks. For the most part, BB-8's circular tool-bay discs are symmetrical so establishing 1 panel dictated the rest. The layout is also symmetrical making positioning of the surface design straightforward. The stainless steel patterns are all unique and were a bit tricky to confirm.
Once the drawings were established, I printed each in full scale. (All drawing were created in Adobe Illustrator on a Mac)
Tracing a circle onto a sphere doesn't quite work. The circle becomes distorted and you will lose some of it's circumference. Instead, I created each circle using a measuring tape and a sharpie. Staring from the center, and marking 1/2 the diameter as I rotate the measuring tape.
The silver patterns were cut and traced onto each tool-bay disc (orange panels).
I then cut into the EVA foam, tracing all of the line work and then applying some heat to the foam. Doing so expands the foam and creates the illusion that each panel is it's own piece while adding depth. This process also made masking the droid for paint a little easier.
Step 3: Preping the Body for Paint
Once the build was complete, I sealed the foam using wood glue. I usually like to use flexbond but had none on hand. I applied 3 layers of wood glue, smoothing the 3rd with a little water and my fingers.
Spot putty was used to fill any noticeable seams - except the intended ones. Sandable primer was applied and the body was given a wet sand.
Step 4: Building the Head
Using the same technique as the construction of the body, I created a 2D full scaled drawing and starting building a dome. The dome was created using 8 wedges, headed and shape before being glued together. I constructed the head out of 0.5" plastazote foam. Once the dome was completed, I added 3 layers of 0.5" foam to the bottom in order to created the tapered underside of the head. I carved the beveled edge in accordance to the linear drawing I created.
I then transferred the the pattern details to the finished build. Unlike the EVA foam, plastazote doesn't expand when you cut into it. Therefore, I had to manually cut a groove throughout the entire design.
Step 5: Giving BB-8 a Personality
I started by cutting out the facial openings in BB-8's head. His primary photoreceptor (the large black domed eye) was created using half of a clear plastic ornament ball found at Michael's. It happened to be very close in size and worked well. I painted it on the inside using transparent black spray paint. The casing around the photoreceptor was hand-built using sintra (PVC Foamboard)
The Articulated holoprojector was created by spray painting a large marble gloss black. The housing for it was carved out of plastazote. (SIDE NOTE: I only know the technical names of these parts because Santa brought The new Force Awakens Visual Dictionary)
The small circular light was made by painting a piece of blue acetate with transparent white and gluing it to the inside of the opening.
Not seen here are the antennas. BB-8's rubber duck Antenna was salvaged from a junck shop and painted white. The larger antenna was handmade using some steel rod and foam.
Step 6: Painting
Painting BB-8 was a long and tedious process. After the initial flat white base, I masked off each orange disc using automotive masking tape. The rest of the droid was covered to protect the base white.
Next The metal parts were masked and a combination of chrome and grey spray paint was used.
Weathering BB-8 was the most enjoyable part of the painting process. Making stuff dirty makes me happy.
To give BB-8 that "just been on Jakku" look, I simply used a few acrylic paints diluted with water. The paint is layered by rubbing on and then rubbing off.
Step 7: This and That
I added some LEDs to my BB-8 to give it a bit more life. I wired a single red LED behind the domed eye and used a dollar store pen light to provide light for the smaller circular opening. The head was attached to the body using magnets. Doing so allowed me to access the LEDs inside the head and gave the option of head positioning. The head can be attached so that it faces the other side of the body for a fresh look.
Sci-Fi Contest
Third Prize in the
Sci-Fi Contest
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Jewelry Challenge
    Jewelry Challenge
77 Discussions
Vinayk154
1 year ago
where should i get that foam??
1truedrumschristopher3
Reply 2 years ago
Hi there, this type of EVA foam is fairly easy to locate. It comes in a 4 pack of interlocking floor mats. I bought it at Walmart. I believe it was approx. $13-$14 a pack. I used one pack to make BB-8s body. I used a different foam for the head which I bought from a foam supplier.
JacobP1181truedrum
Reply 1 year ago
woud it be the floral foam that holds fake flowers?
1truedrumJacobP118
Reply 1 year ago
hello. No it's EVA floor mats. You can purchase them in packs from places like Walmart. They're the interlocking kind
1truedrumVamsi17
Reply 1 year ago
Hey there, do you mean the patterns for the rings silver parts etc?
joweeks
2 years ago
woah that is cool
rnchang
3 years ago
How are the wedges shaped? Are they straight edged triangles or are they curved? Trying to figure out how to shape each piece to fit together neatly
1truedrumrnchang
Reply 3 years ago
There is a slight curve to the bottom edge and the sides are slightly convex.
JannickVJonathanD72
Reply 3 years ago
I think an arduino can do this job too. Actually there is another post on on instructables of a 17 year old tinkerer that did it with an arduino and a lot of creativity. If you are interested: here you go:
https://www.instructables.com/id/DIY-Life-Size-Phon...
I definitely will bookmark that post and when I got some time, I'll build one myself :)
1truedrumJannickV
Reply 3 years ago
Thanks for sharing. I believe the components to make it functional add up to quite a bit.
DavidL1381truedrum
Reply 3 years ago
Not a huge cost. Inside would be a floating cage with a gyroscope in the middle. Gyroscope will usually point north. Having that, you can build a system that detects and steers the sphere. Similar to the navigational gyros on an aircraft and ship. On the outer rings of the cage is the drive motors. It rotates independently of the sphere. This cage will always keep the same vertical orientation to the horizon. Setting powerful earth magnets at the north pole of the spherical cage, that will keep the dome, which has magnets in the center of the flat side, on the top of the base sphere. Align the magnets closer/farther to allow the dome to have some slop. Use counter pole magnets in the sphere and dome to "levitate" the dome off the sphere. Control which what the dome faces by rotating L/R the magnet group in the sphere. Control the pitch and yaw of the sphere by moving the gyroscope on the X and Y axis. For a counter-weight, place the batteries opposite of the magnets. Move them along the Y axis to find weight balance between the Gyro and the magnets. The batteries will provide operational power.
DavidL138
3 years ago
Excellent job. I've been thinking of building one from the first trailer that showed BB-8. In my version, I would make it fully mobile in the same way seen in the motion picture. It wouldn't be that difficult at all. No wheels needed. It would be radio-controlled.
1truedrumDavidL138
Reply 3 years ago
I wouldn't mind seeing how you approach it. Thanks for sharing.
DavidL1381truedrum
Reply 3 years ago
1truedrumDavidL138
Reply 3 years ago
Keep my posted of your system. I may build another in the future, making it operational would be cool.
DavidL1381truedrum
Reply 3 years ago
I'm not building one currently. I have far too many other important projects I am working on. My background is electronic, mechanical, design and quality engineering. When I see a problem, I like to solve it, pass on the info for other's to implement if they care. I did notice an ad yesterday for a fully functional BB8. I do not know of any specifics, size, capabilities, cost, where to buy, etc. I moved right on. Can't afford distractions right now; writing three books, two inventions and tons of research keep me quite busy.
