Induction Heater 12 KW
329,992
1,062
62
This is an amazing induction heater and now you can build your own for fun or as a powerful tool. I have put together an extensive tutorial at http://inductionheatertutorial.com with schematics for building a 3 and 12kw unit. You'll be able to instantly melt steel aluminum and copper. You can use this for brazing, melting and forging metals. You can use this for casting, too. The tutorial covers theory, components and assembly of some of critical components. The tutorial is large. I will go over the main steps here to give you an idea of what goes into a project like this and how to design it so you don't blow any mosfets or IGBTs.
If you wish, you can refer to the link above. This Instructable presumes you have a good understanding of electronics and induction heaters. Let's begin.
As an aside, I have put together a very accurate low-cost cryogenic digital thermometer. Watch me put it up against a standard name-brand using liquid nitrogen for the test.
Step 1: Components
The basic components are the inverter, driver, coupling transformer and RLC tank circuit. I'll show you the schematics in a little bit. Let's start with the inverter. This is an electrical device that changes the direction of DC current to AC current. For a high-power unit this must be robust. Above you can see the shielding that is used to protect the mosfet gate drive from any stray EMF. Stray EMF causes noise, which results in high-frequency switching. This leads to overheating and failure of the mosfet.
The high-current traces on the circuit board are underneath. Many layers of copper are used to allow them to carry over 50A of current. You do not want them overheating. Also note the large aluminum water-cooled heat sinks on each side. This is needed to remove the heat generated by the mosfets. I originally used fan-cooling, but to deal with this power I have small pond pumps moving plain water through the aluminum heat sinks. As long as the water is clean there should be no conduction. I also have thin mica pads underneath the mosfets to ensure there is no conduction through the sinks.
Step 2: Inverter Schematic
This is the schematic for the inverter. The circuit is really not that complicated. An inverted and non-inverted driver moves a 15v voltage high and low to set up an alternating signal in a gate-drive transformer (GDT). This transformer isolated the chips from the mofsets. The diode on the mosfet gate acts to limit spikes and the gate-drive resistor minimizes oscillations. Capacitor C1 removes any DC component. Ideally, you want the fastest rise and fall times on the gate, reducing heat. The resistor slows this down, which seems wrong. However, if the signal is not dampened you get overshoot and oscillations, which will destroy the mosfet. If you look up "snubber circuit" you will get more information.
Diodes D3 and D4 help protect the mosfets from reverse currents. C1 and C2 provide non-shorted pathways for the current to flow during the switching process. T2 is a current transformer so the driver, which we will talk about next, can get feedback about the current going to the tank.
Step 3: Driver
Wow. That is one big schematic. Well, you can read about a simple, low-power inverter. If you want the big power you need a competent driver. This driver will lock onto the resonant frequency all by itself. As your metal melts it will stay locked onto the correct frequency without the need for any adjustment.
If you have ever built a simple induction heater with a PLL chip you probably recall tuning the frequency as your metal heats. You would watch the waveform move on the oscilloscope. You would keep changing the clocking frequency to maintain that perfect point. No need to do that anymore.
This circuit uses an Arduino microprocessor (uP) to follow the phase difference between the inverter voltage and the tank capacitor. Using this phase it calculates the the correct frequency using a C algorithm.
I will walk you through the circuit:
The tank capacitor signal comes in on the left to LM6172. This is a high-speed inverter that converts the signal to a nice, clean square-wave. Got to be clean. This signal is then isolated using the optical isolator, FOD3180. These isolators are key! This signal goes to the PLL through the PCAin input. This is compared to the inverter signal on PCBin, which drives the inverter from VCOout. The Arduino finely controls the PLL clock using a 1024-bit pulse-width modulated signal. The two-stage RC filter converts the PWM signal into a simple analog voltage that goes in at VCOin.
How does the Arduino know what to do? Magic? A good guess? No. It gets the phase-difference information about PCA and PCB from PC1out. R10 and R11 limit the voltage within 5 voltage for the Arduino, and the two-stage RC filter cleans the signal from any noise. We want spanking clean signals because we don't want to pay more money for expensive mosfets after they blow up from noisy inputs.
Step 4: Take a Breath
That was a lot of information. You may be asking yourself do you need such a fancy circuit? The answer is "it depends". If you want a self-tuning circuit then the answer is yes. If you want to manually tune the frequency then the answer is no. You can build a very simple driver with just a 555 timer and use an oscilloscope. You can get a little more sophisticated and add a PLL (phase-lock-loop) chip.
Anyway. Let's continue.
Step 5: Tank Circuit
There are a few approaches for this part. If you want a high-power heater you will need to have a capacitor array to handle the current and voltage.
First, you need to determine what operating frequency you will use. Higher frequencies have greater skin effect (less penetration) and are good for smaller objects. Lower frequencies are better for larger objects and have greater penetration. Higher frequencies have greater switching losses, but there is less current going through the tank. I choose a frequency near 70khz and wound up with about 66khz. My capacitor bank is 4.4uf and can handle over 300A. My coil is near 1uH. The capacitors are from Illinois Capacitors. They are pulse film capacitors. They are axial lead, self healing metallized polypropylene, high voltage, high current, and high frequency. Mine are 0.22uf/3000vdc. The model number is 224PPA302KS.
I used two copper bus bars and drilled matching holes on each side. I used plumber's solder and fixed the capacitors to the bars. I then ran copper tubing on each side to carry cold water to the coil.
Do not get cheap capacitors. They will self-destruct and you will pay more money than if you did the right thing the first time. Here is another thought. You can buy a Celem capacitor. Although they are expensive, the cost is not that far off from the cost of building a good capacitor array. Trust me, I've been there already.
I've posted a picture of a Celem capacitor for your viewing pleasure.
Please note that the Celem is water-cooled. Whether you use the Celem or make your own you need to water-cool these units. I use the same pump to cool the capacitor as I use to cool the work-coil.
Step 6: Coupling Transformer
If you have been paying close attention you should be asking how does one drive the RLC tank? I jumped earlier from the invert to the tank without mention how they are connected.
The connection is through the coupling transformer. I got mine from Magnetics, Inc. The part number is ZP48613TC. Adams Magnetics is also a good choice for buying these ferrite toroids.
The one on the left uses 12g wire. This is good if your input current is under 20A. The wire will overheat and burn up if it is more. For the real high power you need to buy or make Litz wire. I made mine by braiding 64 strands of 23g magnet wire. This stuff could withstand 50A current with no problem.
The inverter, which I showed you earlier, takes high-voltage DC and chops it into alternating high/low values. This alternating square-wave goes through this coupling transformer via the mosfet switches and the DC coupling capacitors on the inverter. The copper tubing from the tank capacitor runs through this making it the single-turn secondary of a transformer. This, in turn, allows the stepped-down voltage to flow through the tank capacitor and work coil (the LC tank).
Step 7: Making the Work Coil
One question I've gotten is how do you make such a nicely curved work coil? The answer is sand. The sand will prevent the tubing from collapsing on itself during the bending process.
Take 3/8" copper refrigerator tubing and fill it with clean play sand. Cap one end with some tape before doing this and cap the other after filling with the sand. Plant a study pole of the proper diameter into the ground. Fix a sufficient length of tubing for your connection and slowly bend the tubing around the pole. Once you get one turn around the rest is easy. Continue to wrap the tubing until you get the number of desired turns (4-6 is usually good). Bend the second free end so it is lined up with the first. This will make your connections to the capacitor easy.
Now, remove the caps and take an air compressor to blow out the sand. Did I mention to do this outside?
Please not that the copper tubing also serves the function of carrying water for cooling. This water circulates through the capacitor tank (or Celem) and through the work coil. The work coil generates a lot of heat from the current. Even if you use ceramic insulation on inside of the coil (to trap the heat from escaping) you will still have extremely high temperatures on the workpiece heating the coil. I would start out with a large bucket of ice-water and reduce this to hot water in a short time. Point: have plenty of ice to keep this cool.
Step 8:
Above is an overview of the 3kw unit. It has a simple PLL driver, an inverter, coupling transformer and tank. The video demonstrates the 12kw unit at work. The main difference is that it has a microprocessor controlled driver and larger mosfets and heat sinks. The 3kw unit runs off of 120vac; the 12kw unit uses 240vac.
Again, you can get more theory and instructions at http://inductionheatertutorial.com
Good luck. Be safe. Have fun.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    62 Discussions
    imsmoothE Hefer
    Reply 5 months ago
    I have a 50amp industrial variac. However, your rating depends on how high you want to go. If your building a 3kw heater than 10-20A is fine.
    abdullahrasp
    6 months ago
    KULLANDIĞINIZ İŞLEMCİYİ ÖĞRENEMEDİM YARDIM EDERMİSİNİZ
    jakeB82
    1 year ago
    why do you need a regulator when you could just straight up use a standard 120v 15a line straight to the transformer?
    dangerUXOjakeB82
    Reply 7 months ago
    I was wondering this as well as I started reading the 'ible, if you ever get an answer please pm me as well haha maybe the wall outlets aren't as steady/consistent in their power output as is required by the induction heater circuits? If that's the case then it makes sense long term I think as it's cheaper to invest in a reliable design than it is to purchase and replace blown parts every so often but I don't know if that's the reason or not.
    jakeB82jakeB82
    Reply 8 months ago
    Still confused as to why you cant do this...
    DonaldL53
    Question 1 year ago
    Do you think a home induction stove with 4 burners, could be converted into a forge or use the components. I have found working units for around 100 dollars.
    WayneL78
    Question 1 year ago on Step 5
    Is it possible to get your code for the processor also does it try and tune to the largest current flow ie resonant of the capacitors and coil. I am going to build this but I am a cancer patient and I don't know how long I have to work on it so I would appreciate any help.
    IbrahimA205
    1 year ago
    do you know C cods ? thankss
    jfpayeur
    1 year ago
    First Thanks so mutch for sharing .I plan do to pretty simillar settup with many different component
    I actualy only have one Question, What are the purpose of the 2 diodes just above the mosfets. I've never seen a setup like this for half a H-bridge, Furtermore the diode are rated for a good amperage , but very low reverse voltage (15v for the 65pq015) This must be some sort of protection , but for what ? Would these be needed if I use IGBT ?
    I will shurly document my tale beside my stick welder project
    https://sites.google.com/site/jfpayeur/main/welder
    imsmoothjfpayeur
    Reply 1 year ago
    Go to my website tutorial which goes into much greater detail and explains the purpose of most of the components along with schematics and picked oriole diagrams
    I give the name of the website at the top of this instructable
    jfpayeurimsmooth
    Reply 1 year ago
    Yes I've read it all already thanks
    The only looking alike info was this :
    "Diodes D5 and D6 offer some delay so both mosfets are not on at the same time. These series diodes have nothing to do with reverse currents, like the one's you are used to seeing across the DS juntion. Again, they are for timing."
    Make sense , sorry I didnt got It because they are named D3 on shematic
    Thanks !
    CYC8
    1 year ago
    thanks for ur share
    Markllar
    2 years ago
    Any chance you would provide the Arduino code?
    vsurducan
    2 years ago
    Congratulations for your work!
    However, looking at your PLL
    schematic, all grounds have the same symbol (meaning there are connected
    together). In that situation, using two 2A output optocouplers hasn't
    too much sense. You've connected pins 3 and 5 to the same ground. In
    this configuration the optocoupler does not reject any noise, it's just a
    redundant device. Eventually, to keep clean the signal, it has to be separated
    ground between PLL and inverter... Do I miss something?
    cdevans
    2 years ago
    Trying to build this for my FRC Robotics Team. Including the Levitation posting there are 3 versions for the sensor! The Lev. says hook to probes or Microprocessor, which is what I was looking for. Is this in place of, from tank capacitor or what? As I am a coder, I can muddle through that, but electrical engineering is not my strong suit. Thanks
    imsmoothcdevans
    Reply 2 years ago
    The sensor gives a reading of the AC current waveform that drives the coupling transformer connected to the RLC tank (the part with the Celem capacitor and work coil). This is not necessary to get the circuit to work: it provides information on the proper function of the system. Knowing this, I attached a diode and smoothing capacitor to a DC ammeter to get a constant analogue reading of the current. This is important, because if the current gets too high I know I will overheat the mosfet switches. For the smaller circuit this was about 20A; for the 10kw units this was about 50-60A for short periods. I used a voltage divider to feed the current value into the uProcessor and wrote a subroutine that constantly monitored the current. If it got too high I detuned the circuit to reduce the current. This is useful if the workpiece falls out of the coil. When this happens the current shoots up without anything to quench the tank. Having this feedback I could quickly reduce the current and protect the mosfets. I was thinking of producing a second generation board that would also get input from a thermocouple connected to the mosfets and would shut the system down if the temperature got too high. I never did it as I sold my project to a blacksmith.
    I hope this helps. You can go to my site http://inductionheatetutorial.com for a little more information.
    cdevans
    2 years ago
    Really confused? This page shows a current sense transformer connected to nothing, while the tutorial shows a pulse transformer connected to a meter at the same place. What does the sensing transformer do here? So, same question as before. Oh yeah, Happy New Year,Thanks
    cdevans
    2 years ago
    Missed that as I'm designing around 2 HB IGBT, and didn't look closely. Was hoping a current sensor might be useful in a self regulating ppl circuit. Thanks
    cdevans
    2 years ago
    Been struggling with your driver design. The schematics and photos don't match, ie: a sensing transformer that's nowhere in the schematics? Real schematics of your current design would be really useful to all of us. Thanks
