$1.50 Heavy Duty Extension Cord
2,330
16
A heavy duty 6 foot 120 Volt extension cord is expensive, so make your own for about $1.50 each.
Remove the heavy duty cord from an old appliance you are recycling.
Pass the end through one of the holes in a $0.39 blue single gang workbox.
Then tie a knot for strain relief.
Strip the ends and attach to a $0.59 15 Amp outlet - green wire to green screw, white to silver screw, black to gold.
Screw the outlet in place and add a two outlet nylon "unbreakable" cover plate for $0.47 and you are done.
Plug and play. Remember extension cords are for temporary use only in dry areas.
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    3 Discussions
    iApple guy
    6 years ago on Introduction
    Use a metal box, a metal cover, and a hospital grade outlet and plug thing for added durability.
    webman3802
    With some additional wiring, you could put it in a double gang box and add a switch to control the outlet. Using a dimmer switch also opens up possibilities to control lighting, motor speed, etc.
    iectyx3cwebman3802
    Reply 6 years ago on Introduction
    Using a double gang box is an excellent suggestion and allows for all kinds of add-ons. Timer could be used to control Halloween lighting or other decorations.
