18 Shot Nerf Maverick
144,187
582
109
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
In this instructable, I'm going to show you how to make a Nerf Maverick, with a rotating barrel mechanism to shoot 16 Darts. I made this gun for my brother, admittedly he is 22 years old, but can you ever be to old for Nerf guns?
Thanks to this mechanism, you can not only load more darts, but also reload them faster.
To get a better idea, watch the video:
Thanks to Instructables member ballisticjoe I found out, that I'm not the first one, to attempt this mod. You can find an other version, of this gun here.
Supplies:
Step 1: What You Need
Materials
    • three NERF Mavericks (e.g. on amazon.com)
    • fine grid sanding paper
    • two M4 screws, 4 nuts (two locknuts are even better) and two washers
    • self tapping screw
    • strong glue
    • 6 mm acrylic, or plywood and a way to cut them to the shape shown in step three (e.g. laser cutter,
      scroll saw, fretsaw...)
    • optional: email paint, paint brushes, epoxy putty
Tools
    • hack saw
    • cross slot screwdriver
    • claw hammer (if you don't have one, don't worry a slotted screwdriver will work as well)
    • drill
    • drill bits: 2 mm, 4.2 mm
Step 2: Take Them Apart
We will start by disassembling the gun. Make sure, that when you take the pull back mechanism apart, that you don't loose the spring and small orange part (see the second picture). Underneath it is an other screw.
Carefully pull the two big yellow plastic pieces apart. Take the barrel out and carefully use a claw hammer to pry out the metal rod. Be careful, not to loose the spring. Remove the three screws in the back (black part) of the barrel and gently slide the top of the barrel of.
Take the air restrictors out and remove the inside and the springs, you wont need them anymore. I've seen people cutting of the spikes off, tried it myself and didn't really notice a difference (so you are free to do it, but don't expect any wonders).
Remove the two screws in the middle, to get rid of the grey piece in the back. Do this for all three guns.
Step 3: Cut the Connectors
In the first picture you can see the measurement you need, to build the connector pieces. The final shape is up to you. I was in the lucky position of being able to use a laser cutter. If you don't have one, you should be able to use a scroll saw, or even a fret saw.
I cut the pieces out of clear acrylic (5.8 mm), but plywood should work as well.
UPDATE: I've been asked by quite a few people, to send them the vector files, that's why I've uploaded them here.
Step 4: Make Room for the Barrels
To fit the barrels, you will have to remove the parts, that I've coloured blue in the pictures. I started by using a Dremel, but noticed, that a hacksaw actually works better. Don't forget to round the corners in the front (with either a file or sand paper).
The fourth picture shows, where you will have to carefully cut the grey pieces, that hold the front barrel in place. Make very sure, not to remove all of the inside, as shown in the fifth picture.
Step 5: Stabilizing
I decided to enforce the front of the gun with an extra screw, by filling the already existing tube with Milliput and drilling a hole into it, once it was dried.
To give the gun a smooth finish, I used the Milliput to fill the holes, as shown in the pictures.
Mark the middle holes of the connector pieces, by holding them in place with one barrel attached to them. Due to the lack of an angle drill, I drilled the holes, with an 4.2 mm drill by hand (after drilling a smaller hole at an angle).
Step 6: Assembling
If you would like to paint the gun you should do so, before assembling it. I used Revell email paints and dry brushed them later.
To stabilize the plastic, glue one washer to the back of each hole, as shown in the first picture. Then secure the connector pieces with a screw and two nuts each.
Reassemble the gun, if you are having trouble on finding the correct spot for every piece, check out the picture in step 2. If you would like to make your gun stronger, add two or three washers at the back of the spring.
Once, you are done, you will have to reassemble the barrel. Instead of using the small grey front piece, use the front connector piece, as shown in the third picture. Don't forget the spring and hammer the metal rod back into the barrel. Once you finished one barrel, turn the mechanism and attach the next one.
Toy Challenge 2
Second Prize in the
Toy Challenge 2
  • IoT Challenge
    IoT Challenge
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
109 Discussions
Flopbassador
7 months ago
Is there a way to make a PDF file that 3D prints the part for just two maverick cylinder to be added?
element off
3 years ago
i made a four barrel version of it
and did not need to break four guns in the process.they sell the barrels for this.online.
for rather cheap as well.not as much cost as the full gun itself.not to mention that i added to the design.its a four verion of this with a long barrel and easy reload with double power.although.if not for seeing this id never had made it at all.so thanks
xXSavageXxelement off
Reply 1 year ago
For real. So it's like a square barrel because of the four barrels, or what shape is it.
DareTheDudeelement off
Reply 2 years ago
element off, what website did you find the barrels on????
BrittLivelement off
Reply 3 years ago
Congrats! That's awesome. Did you take a picture? I would love to see it.
erana_reborn
1 year ago
Can spare Maverick cylinders still be bought anywhere? I've searched for them to no avail. Same for 3d-printable models.
DX I don't want to attempt this for running the risk on ruining my gun for I have lost several guns to messing up one little thing that I could not figure out and those mistakes basically killed the gun but I think it looks really cool and I don't have all the materials needed
JediS
3 years ago
i want to make the peice that connects the 3 barrels out of 1/8" sheet metal, think it would work? it definitley would be stronger...
ihasdonut
4 years ago
The Internet tried its power and it went to far
hyounghoskingr
Reply 4 years ago on Introduction
would you be selling the 2 parts needed to hold the cylinders?if cheap, i would love 2 sets.
hoskingrJacobC5
its just the .stl files but i designed them in Autodesk Inventor so i dont see why not.
