18 Shot Nerf Strongarm
205,747
721
108
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
After building my 18 shot Nerf Maverick I have been asked countless times, whether it is possible to build an 18 shot Nerf Strongarm. So I decided to give it a shot (no pun intended :-)).
In comparison a few more alterations are needed and the pieces that connect the barrels are a bit more challenging, but other than that it wasn't overly complicated to build. I still urge you only to attempt this mod, should you be convinced that you are able to execute it. Otherwise you might damage your blaster.
Even if you are not planning on building an 18 shot version of the blaster and are just generally interested in modifying a Strongarm, I think this instructable is worth a read (especially the first step).
Take a look at the video:
Btw. I am completely aware of the irony of taking a blue-orange-white blaster apart in order to sand and prime it and afterwards painting it blue-orange-white again... but as some of you already noticed in the comments, I wanted it to look like something straight out of Borderlands.
Supplies:
Step 1: Common Misconceptions + How to Increase the Speed
I have read multiple times that people suggested to remove the what they call "air-restrictor" from the plunger and to fill the small hole that is on the top (as shown in the third picture).
DON'T DO IT!!!!
Even though they might tell you that this improves the strength of you blaster, it doesn't! In fact, this actually damages your blaster, because it is not an air-restrictor, but an ingenious method to prevent dry firing. Since after building this 18 shot blaster I had some plungers left over I tried to do the mod and to compare the results by measuring the dart speed with a chronometer.
I also removed the barrel posts from one barrel, to measure the effect. Unless you are planning on using Stefans (If you don't know what I am talking about, here is an instructable) I wouldn't suggest you to do so either, because it also decreases the strength of the elite darts.
The only effective way to improve the dart speed that I found was to change the spring! The second picture shows the improvement after adding the Orange Mod Works (OMW) kit (from here).
Step 2: Stuff You Need
  • 3 Nerf Strongarms (e.g. from amazon.com ), or one and two 3D printed barrels
  • 2x15mm M4 screws, M4 washers and M4 cap nut
  • Jb-weld, plastic weld (e.g. from amazon.com) or some other type of modelling clay.
  • 3D printed parts (you can probably make the pieces from wood, too, but 3D printing will save you a lot of time)
  • Silicone Grease (not necessary, should you get the "Unleashed Solid Final Stage Kit")
  • Saw
  • Strong glue
  • Sanding Paper
Optional:
Step 3: Open the Blaster
Start by taking all the screws out of the outer shell. Afterwards take the barrel out. The grey part in the front is loose and can just be pulled off. The one the back is screwed in place, in order to get it off you will first have to pry the two orange shells apart. Start by removing the two screws that are holding them together. You will have to move the grey piece around to reach them. Pulling the pieces apart might take some effort, since they are pressure fitted.
After you have pried the pieces apart, unscrew the small screw in the bottom, to remove the part in the back.
Step 4: Modify the Shell
In order to being able to rotate the barrels use a saw, or a Dremel to remove the rail on the bottom as shown in the pictures. The next thing you will have to do, is to remove some of the plastic from orange front piece, as shown in the second picture. Do so until both sides have the same height.
To make my life easier I decided to design two small plastic pieces, that hold the screw in place. In order for them to fit you will have to remove the small blue rail that is in the way, as shown in the third picture.
As you can see in the fourth picture, I decided to add an extra screw hole, by drilling through an existing hole and filling the end with jb weld. Feel free to do so, too, but it is not really necessary.
Step 5: Filling the Holes
One of the pieces is designed to hold the screw that goes into the front. Glue it in place, as shown in the first picture. Afterwards glue it to the orange piece that goes in the front. It should fit perfectly into the hole.
Glue the pieces that hold the screw in the back in place (as shown in the second picture).
I used jb-weld to fill all the holes, but even though it is extremely stable I would suggest using something with a higher viscosity. The best way I found to prevent the filler from connecting the two shells, is to use tape, as shown in the second picture. Also wrap it around the screw, in order to being able to take the shells apart later.
Once you are done, sand the pieces.
An other thing you will have to do is to shorten the pins that go into the barrels. So that they don't infer with the front of the blaster.
Step 6: Painting
To get the paint to stick perfectly to the blaster, you should sand it. Afterwards prime it and paint it.
Make sure not to paint the bottom of the inside barrel or the inside of the outside piece (click on the second picture to see, what I mean).
Step 7: Assembly
As you can see in the first picture, I added a LED to the side of the blaster, but that is of course completely optional.
Shorten the screws to the correct length. It is easier if you screw the cap nut on, before assembling the barrel. Glue the washer to the connector, as shown in the picture.
Place the connector that goes in the back on top of the barrels, as shown in the picture and add some lube, to reduce the friction. Afterwards reassemble the barrels. Screw the connector that goes in the front in place, as shown in the fourth picture and add some lube to the cylinders.
Step 8: Assembly
The assembly is easier, if you place a book under the blaster, as shown in the last picture. Don't forget to reattach the small spring.
The last picture shows, how the final assembly looks like (click on it to see a bigger image). The main spring can be attached by screwing the old one off and the new one on. Make sure that the plunger is positioned right.
Congratulations, you are done.
Game.Life 4 Contest
Runner Up in the
Game.Life 4 Contest
Makerlympics Contest
Runner Up in the
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
108 Discussions
nbkaye
Question 6 weeks ago on Introduction
Hi, Can anyone tell me what scale unit the 3d parts were created in; inches, cm mm etc.
Thanks
Frealdubz
Question 3 months ago on Step 2
Do you have a design model for the barrels?
DEMHAX666420
1 year ago
Warning, this may be addicting, and fun at the same time.
This is the best of the best don't under estimate.
shreddherring
1 year ago
Really interesting concept, and well designed.
I know this is an old post and you probably get asked these things a lot, but do you think you might ever try doing something similar with the mega cycloneshock?
JohnB859
2 years ago
Would it be possible to do this using three 3d printed 9 shot cylinders? Just curious. Thanks!
erana_rebornJohnB859
Reply 1 year ago
Could you post a link to the file for those 3d cylinders you mention? I'm having some trouble finding them online
JTronixJohnB859
Reply 2 years ago
Yes, But it is not reccommended because 3d prints are not nearly as clean, durable and precise.
erana_reborn
1 year ago
Incredible mods, both this and the Maverick one.
I'm curious about a few Nerf mod things that maybe you could answer:
- Would it be possible to do similar multi-cylinder modifications to newer revolver nerfs like the Disruptor or the Hammershot? I gess not, because those aren't swing-out cilinders, but this must be asked.
- Are the cylinders of the different Nerf revolvers interchangeable (other than cosmetic differences) for multiple-cylinder mods (that is, do they have similar rear "working parts" and dimensions), or do they have differences that prevent you from using, say, Hammershit cylinders in a Strongarm mod?
and, lastly, but not least,
- Have you given any thought to making an EIGHT-cylinder + shield mod like this famous gun, the Enouy revolver? ;-)
(image source: http://firearmshistory.blogspot.com.es/2014/03/the-enouy-revolver.html)
Spaceman166
2 years ago
Can you make a four drum mod
MarcM88
2 years ago
OK... you've made a 18 shot maverick and a 18 shot strongarm... do you think you can make instructions on how to make a 18 shot cycloneshock???
EphraimH1
2 years ago
why cant i open the .stl
Andy isr
2 years ago
is there a .stl for the barrel?
Moodle2
3 years ago
I won a strongarm as a door prize and was frustrated at the constant reloading. Thanks for making this instructable!
Jyra Sapphire
3 years ago
You can remove the air restrictor as long as you do it through the hole in the front (NOT EASY!!). This leaves the buffer at the back which the plunger strikes.
colinN6Jyra Sapphire
Reply 3 years ago
actually I saw a post of a guy who chrono'd his darts before and after removing the "air restrictors" which are actually just dry fire prevention mechanisms, and he found a large decrease in dart velocity and accuracy, and stated that the only way to get more power is a stronger spring.
severdhed
3 years ago
This is fantastic. Great job
