.223 Survival Whistle
133,453
875
116
About: Awesome Gear I've designed myself.
Because yelling will make you lose your voice, it’s important to carry a whistle just incase you get in a jam. For example: When I went mountain biking with a group of friends I crashed plenty of times. Luckily, none were serious. However, if I had a bad crash, I would of had to wait until someone pedaled back to me. Unless that is, I could signal them somehow.
To signal for help with a whistle you sound three blasts. Do this in a consistent interval until help comes. The plus side to this whistle is you’ll have a conversation starter when help finally comes.
Step 1: File Out a Notch
Before you start, clean out the brass with dish soap and cotton swabs. Clean inside and out until the swabs come out completely white.
Grip the shell in a clamp. Make sure to clamp the primer side of the shell or it will collapse. Also if you don’t have a wooded clamp you can improvise to protect from scratching up the brass with something like an old leather belt.
Using a ¼” triangle file, file a notch ¼” down from the taper line on the shell. Make sure to keep the leading edge of the file at 90 degrees. See the pictures. Keep filing until the trail edge of the file is flush with the shell wall.
Remove any burs.
Step 2: Prep the .22 Shell
Use a pair of diagonal cutting pliers to remove the primer side of the .22 shell. Next take a scrap piece of brass from another shell and solder it halfway onto the business side of shell. See the pictures.
Use metal shears to cut off the excess. Smooth out any rough edges with a hobby file.
Step 3: Place the Prepped .22 Shell
Insert the half covered side of the .22 shell into the opening of the .223 shell. For best results you have to make two things sure.
One: the end of the .22 shell lines up with the notch cut in the shell.
Two: the opening of the .22 shell is parallel to the notch cut out in the .223 shell.
Solder the .22 shell in place. Be careful not to over do the heat or you might melt the solder away from the half cover.
File the blowing end flush with a hobby file. Next use a polishing wheel with polishing compound to buff the whistle to a shine.
Step 4: Tie It Off
Take a section of nylon cord and melt the ends together side by side. Place the melted end against the shell and secure it with a constrictor knot. Another option is to drill small holes at at the primer end and fit a paper clip to make a keychain. Sort of like I did on my keep sake pendant instructable.
Thanks for reading.
Survival Skills Challenge
Runner Up in the
  • Faux-Real Contest
    Faux-Real Contest
  • Paper Contest
    Paper Contest
  • Build a Tool Contest
116 Discussions
SurenO1
2 years ago
Would a 30-06 Springfield with a 9mm inserted inside the 30-06 work?
NoahPlayzSurenO1
Reply 4 months ago
a 9mm brass would be too large to fir in the neck of a 30-06 casing. maybe a .45 caliber rifle brass and a 45 acp
TECHYman3
2 years ago
I need on of these! We shoot guns, and we always have extra bullet shells. This is a good use for them!
Yonatan24
3 years ago
Nice, They look so easy to make!
GrowleyMonster
3 years ago
I bet you could use a .50 BMG case with a .45 Colt case for a really big whistle. Or maybe something like a 20mm
bob8898
3 years ago on Step 4
Is it possible to build one without the .22 shell? I happen to be an 11 year old (with knowledge and tools) and i don't exactly keep my .22 shells. more the centerfire rounds... like .204...
soul_eater
7 years ago on Introduction
Very cool whistle, i hope i can find a shell off that size in my country any bullet over 9mm its illegal so its dificult to find even a emty shell
bennettcrewsoul_eater
www.etsy.com
There are some folks, on there, who sell empty brass for people to make craft projects with. I have some various types... but they're all bigger than .223
The good thing is that, on the website, you can get quite a few for just a few US Dollars. Pay through paypal, or other method, and have them shipped right to you.
socklessbennettcrew
In New Zealand at least, it's illegal to have shell casings without a firearms license, I imagine that it'd be similar elsewhere.
SIRJAMES09sockless
not in America.
In America, if you want to own empty shell casings, it's not illegal...now if you have a few hundred thousand casings, that might cause a bobby to ask Questions, but it's still not illegal.
dc0deSIRJAMES09
I have a few hundred thousand casings, and the government nor anyone else asks any questions.
As far as empty v/ loaded brass, I'll leave that for the thieves to guess which ones are loaded...
SIRJAMES09dc0de
I like your way of thinking.. :D
Just make sure you have some very hungry hogs near by....makes it easier to hide the bodies. j/k
slamonellaSIRJAMES09
Reply 4 years ago on Introduction
If only that were true. In Massachusetts, you need a permit to own possess any ammunition components. I would not be shocked to hear that other states/cities had similar stupid laws.
cmanningxsockless
Not so.
In NZ you can buy/own shell casings, projectiles (bullets) and even gunpowder and primers WITHOUT a license. You can even buy/own reloading equipment.
You do however have to have a license to possess whole ammuniton, so it would be illegal to assemble loaded ammunition without a license.
Shell casings, straight up or made into whistles... no problems at all.
Hazara_nzsockless
Nah mate - in NZ I can send the missus in to buy all I need to reload, Cases, powder, projectile & primers without a license. She cant however buy preloaded (live ammunition).
