2n3055 Flyback Transformer Driver for Beginners
274,544
252
217
About: Me on YouTube youtube.com/Alex1M6
Intro:
This instructable will show you how to make a cheap and simple driver circuit in order to get high voltage arcs out of a component called a flyback transformer.
A flyback transformer, sometimes called a line output transformer are used in older CRT TV's and computer monitors to produce the high voltage needed to power the CRT and electron gun. They also have other auxiliary windings built into them that the TV manufacturers use to power other parts of the TV, so they are usually customised by the manufacturers.
For the high voltage experimenter they are used to make high voltage arcs, which is what this instructable will show you how to do with just a few simple electronic components.
You can get flyback transformers out of older CRT monitors and TV's. They are the ones that have a big heavy chassis. There are also other instructables on this website showing how to remove them from the chassis and circuit board.
Disclaimer
I am in no way responsible if you mess up with this circuit. If you mess up you have no one to blame but yourself.
What you will need:
1x Flyback transformer
1x 2n3055 transistor + heatsink
1x 220 ohm 5 watt resistor
1x 22 ohm 5 watt resistor
(Note: The resistor values do not have to be exact. Say if you had a 33 ohm and a 200 ohm resistor they would still work fine for this circuit).
Some enamelled magnet wire, single core bell wire also works well too for the primary and feedback coils.
A fast diode. Although this is not needed for the circuit to work, it protects the transistor from back emf spikes and can help prolong the life of the circuit. I just used the one I found on the TV board but the UF4007 is an easy one to get hold of in electronic stores if you need to buy one.
+Some way of connecting the components
such as alligator clipped cables or wire and solder.
You may not, except with our express written permission, distribute or commercially exploit the content. Nor may you transmit it or store it in any other website or other form of electronic retrieval system.
Step 1: Mount the Transistor Onto the Heat Sink
Mount the transistor onto the heat sink. The heatsink is important as the transistor gets hot. I just bought the cheapest heatsink maplin sell. The 2n3055 is a TO-3 case style.
You can use an insulator pad if you want but I just used a small amount of old thermal grease I had lying around. To mount the transistor to the heatsink I just used some spare screws and nuts I had in the garage.
Make sure that the transistor pins do not physically touch the heatsink and it is screwed in securely.
Q: Can I use a different transistor?
A: Yes you can, as long as the transistor has similar specs to the 2n3055 or better.
Q: Can I use a PNP transistor?
A: Yes, but you will have to reverse the collector and emitter connections in order for it to work. It will also need to have similar or higher specs as the 2n3055 transistor.
Q: Is the heatsink really needed?
A: Yes, if you are wanting to use this circuit for more than a few seconds the heatsink is vital as the transistor will get hot fast.
Q: Can I use a MOSFET?
A: No, a MOSFET will not work for this circuit.
Step 2: Preparing the Flyback
Using some enamelled magnet wire wind two coils around the core of the transformer in the SAME DIRECTION.
11 turns primary and 7 turns feedback is a good starting point but you can try more or less windings to see what gives the best results.
Using a sharp knife carefully scrape away the enamel coating from the very ends of the magent wire.
Once you have wound the coils and removed the enamel at the ends of the wire check for continuity using a multimeter, doing this can save you lots of bother later on!
You do not need to worry about finding the HV return pin yet.
Step 3: Putting the Circuit Together
Connect all of the components together as shown in the images above.
In the graphical diagram, the red coil is the primary coil with one end connecting to the positive "+" of the power supply/battery, the other end connects to the transistors collector which is actually the metal casing of the transistor itself.
The green coil is the feedback coil with one end connecting to the middle point of the two resistors, and the other to the transistors base (looking at the transistors underside this is the pin on the left).
If you have some alligator clipped wires then you can use these for temporary connections whilst you familiarise yourself with the circuit.
Step 4: Check Everything
Check to make sure that your circuit is connected up correctly.
You can use a multimeter set to measure continuity or resistance to make sure that everything is making good electrical contact.
Step 5: Safety First!
When drawing arcs...
I strongly urge you to make a "chicken stick", which is a 1 foot long minimum insulating stick of some sort. PVC pipe is very good for this. Wood is fine too but when damp it becomes a good conductor at high voltages.
Secure an electrode of some sort onto the end of it, sharp pointed nails work well and will give slightly larger arcs than rounded electrodes. You can then attach a wire of some sort to the chicken stick electrode the other end will be attached to the HV return pin on the flyback transformer.
Other safety concerns
Including the obvious risk of electric shock another thing to take note of is that the arc is VERY hot and can easily set to fire to anything that it touches. Even the cable insulation will burn if you draw the arc onto it.
So if you insist on burning pieces of paper or other objects take that into account and have some way of putting the fire out.
  • You should never touch the high voltage wire or any of the flyback base pins when the circuit is turned on.
  • Make sure that you can easily disconnect the power to the circuit.
  • Do not use this circuit on an unsuitable surface such as a metal table or flammable surface.
  • The transistor heat-sink can get hot so watch out not to burn your hand on it.
  • Keep any high voltage cables away from other parts of the circuit and low voltage cables.
  • Use common sense.
  • Keep pets away. As well as the risk of shocking your pet from the sparks many household pets like to chew things such as wires.
Following those basic safety steps you will be fine.
Disclaimer
I am no way responsible if you mess up with this circuit.
Step 6: Powering the Circuit
To power the circuit you can use any 12V source that can supply a minimum of 2 amps, as a rule.
AA battery's in series can be used but they will not last long and the arc length will get smaller and smaller as they drain.
x2 6v lantern battery's can be used and will power this circuit nicely for a decent amount of time before the arcs start getting smaller.
A 12v lead acid battery is a very good way of powering this circuit and what I personally use.
A 12V power supply can also be used providing that it can deliver 2 or more amps.
I do NOT recommended 9v /PP3 battery's as they will not last long at all and even when new are unable to provide the current needed for a decent sized arc.
Step 7: Finding the High Voltage Return
To find the high voltage return first attach your chicken stick to the high voltage out (the big thick red wire) and turn the circuit on. You should hear a high pitch noise. If you don't here this noise then go to the trouble shooting page at the end.
Bring the chicken stick close to the base pins on the flyback and go past each one individually. Some of them may give a slight spark but one of them should give a solid constant HV arc, this will be your HV return pin. You should now disconnect your chicken stick from the HV out and connect it to the HV return pin instead.
In the image's above are some arcs produced by my 2n3055 driver and some different flyback transformers, most flybacks will only give around a 1-2cm arc on 12V input and upping the input voltage only increases heating on the transistor in my experience.
Have fun and remember not to run this circuit for periods longer than 1 minute as the transistor gets hot fast.
Step 8: Going Further
Now that you have your driver made and working you are probably thinking "what now?".
Well some things you can do include soldering your driver components onto a single piece of strip-board or making a high voltage capacitor and getting loud sparks.
You can also make a small Jacobs ladder by placing two vertical pieces of bare wire close to each other with a small gap at the bottom that gets wider at the top.
Step 9: So How Does It Operate?
Note: this is what I think is happening with this circuit, if someone with more knowledge could correct me in the comments I would be more than grateful to know!
When you first apply power to the circuit a small amount of current starts flowing through the voltage divider resistors and feedback coil and into the transistor base, as part of this current path is wound around the ferrite core (feedback coil) it stores some inductive energy in the core.
As current is now flowing through the base the transistor is now forward bias which turns it on.
Current then starts flowing through the primary coil and into the transistors collector and out of the emitter (conventional current flow BTW). Current will keep building up in the primary coil until core saturation occurs. This takes the voltage of the feedback coil down to almost zero and the transistor falls back into its linear region.
As the transistor turns off, the magnetic field in the feedback coil collapses which creates both a high voltage pulse in the secondary coil and a small voltage boost in the primary coil (this is why the transistor has to be a high voltage transistor).
As the induced current is in the opposite direction to the supply current i am thinking this serves a current limiting action to the circuit, which might explain why it only seems to draw 2 amps max. If this was a non-inductive load then the transistor turning on would effectively be shorting the power supply right now.
As the transistor turns off the magnetic energy stored in the core from the primary coil rapidly collapses giving an even higher voltage pulse on the high voltage secondary coil.
The process repeats its self thousands of times per second.
Please correct me in the comments if I got any of this wrong!
Step 10: Troubleshooting
Problem?
Ok so you have made the circuit and it either does not work or it does not work very well.
  • If nothing happens and you cannot hear any high pitched noise from the flyback transformer then try reversing the connections to the primary and feedback coils, if you still get nothing try just changing the connections on one of the coils. Usually this resolves that issue.
  • If you have tried that and still nothing then you should check the circuit and make sure all connections are secure and nothing is shorting out. Sometimes people will forget to remove enough enamel on the magnet wire primary and feedback coils and there will be no electrical connection being made.
  • If it works but the arc is small try reversing both the primary and feedback coil connections. Remember that around 2cm is the maximum arc length you are going to get out of this driver, and 1cm may also be the maximum on some flybacks.
5 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
217 Discussions
Yoshuga1
8 weeks ago
I was wondering what the output voltage was, I need around 120 volts at 60 amps, I was gonna use this for a project please respond asap
mad_bYoshuga1
Reply 7 weeks ago
I think probably you did not grasp the values here. Usually in open air, each mm of space needs 1000 Volts to make a spark jump. So if you see a 2cm spark, it means around 20,000 volts. Voltage increase as current decreases. So if you provides 12V @ 2A, probably you are getting 20KV @ 1,2 milli Ampère.
If you need 120V 60A, you need to get wires directly from the electricity meter of your house (Where I live, the average capacity to a whole house is 127V @ 40 or 50 Amps...
Do your homework and figure it out what exactly do you need.
Ohm's law, current x volts x power...
By your question sorry but it seems you don't have an idea what you want or are dealing with. So be safe and research a bit more. :)
AdleeJ
Question 1 year ago on Introduction
Sir i have used a 220 ohm 10 watt resistor
Instead of a 220ohm 5 watt resistor .
I'm not getting the output .Is that the problem
1 answer
mad_bAdleeJ
Answer 3 months ago
probably is not the problem. The important value here (other than obviously not burning using a small power capacity resistor) is the resistance (220 ohms) - you could use any resistor of 220 ohms with 5 to 500 watts or even more. Nor less.. Problem is somewhere else for sure - if the referred resistor is not shorted or opened of course;
LukaL17
3 months ago
Coils should be made in oppposite directions.
ann.bragonje
4 years ago on Introduction
I am trying to help my son with his science project which includes making the arc and then comparing different shaped electrodes. We are having a problem finding the flyback transformer. Is there another transformer that would work?
StabstheShookann.bragonje
Reply 5 months ago
They are easily found in CRT tvs, yes i'm aware that this is a 4 year old post...
StabstheShookDarpanD
Answer 5 months ago
No, read the instuctable, it clearly states that it will not work
SilverL2
5 months ago
If this were a normal transformer you would be right in saying that more primary turns would give fewer secondary volts but this is like a car's ignition coil and like that coil it operates on the principle of stored energy, that energy is defined as 1/2 Li^2, where L is the inductance of the primary winding and i is the current through it. As you increase the number of turns the inductance also increases resulting in more energy being stored and subsequently released into the secondary winding = bigger spark. I hope that helps in understanding the apparent paradox.
gagant58
9 months ago
is it dc voltage or ac plz someone let me know
can i use voltage multiplier with this ,will it work??
bennyj121DarpanD
Answer 1 year ago
No a MOSFET won’t work, as stated in the Instructable
L DushanF
1 year ago
i tried using a some of flyback.but doent work can u tell me what type of flyback is suitable
Chinmaya Shyamaraj
2 years ago
can i use the primary that is in the transformer?
Mehulk20
4 years ago on Step 3
what happen if i use 2 or more transistor or greater then 2n3055 and more resistors of same value that you suggested us and a more powerful diodes.is it sufficient to drive out 30kv. if not then can you please suggest us what to do for driving 30kv output from a fly back transformer of a monitor.
one more question ???
can i use transistors ,diodes ,capacitors ,resistors etc from my monitors circuit board.
GyurikaKMehulk20
Reply 3 years ago
I didn't try more transistors but a dude said that he hooked up 3 in parallel and they worked but didn't make the spark longer by much...it I said in the instructable that you can use the things from your TVs board :)
yogesh15889GyurikaK
Reply 2 years ago
Can you please suggest me what to do for driving 80kv output from a fly back transformer.
