2x4 End Grain Cutting Board / Butcher Block
56,194
621
79
This is my first Instructable ever.
I want this post to be informative and simple.
Let's do this! ^_^
Supplies:
Step 1: Materials
Materials
  • 2 - 2x4 UNTREATED: $1.95
  • TiteBond III Glue "Waterproof": $8.00
  • Mineral Oil: $3.99 "Food Safe Finish"
  • Gulf Wax: $3.99 "Food Safe Finish"
  • 1" Anti-Skid Pads w/screws: $2.95
  • Sand Paper (not shown)
Machines and Tools
  • Bar Clamps
  • Quick hand clamps
  • Glue Scraper
  • Power Miter Saw
  • Table Saw
  • Surfacer/Planer
  • Radial Arm Saw
  • Random Orbit Sander
  • Router
Step 2: Power Miter Saw
  • Cut two 2x4 in half. Right at 48"
Step 3: Table Saw
1st Cut
  • Rip all 2x4's in half at 1-3/4", USE A PUSH STICK!!!
2nd Cut
  • Set the rip fence to 1-1/2"
  • Cut off all the curved edges.
Step 4: Clamps
Clamping - 5 total clamps
  1. Lay cardboard on the table.
  2. Lay 3 bar clamps on the cardboard. (1 clamp in the middle, 2 for the outsides)
  3. Lay 2x4 material on clamps.
  4. Spread glue on the "smooth" edge of every joint, (do not glue your boards to your metal clamps) ^_^
  5. Put the last 2 clamps on top.
  6. Apply pressure. ALSO use a rubber mallet to hit boards that warp up.
  7. Allow the glue to cure for minimum of 1 hour (longer is better). Do not stress joints for 24 hours.
Step 5: Surface
Glue Scraping
  1. Use 2 hand clamps to hold material.
  2. Use a glue scraper.
  3. Scrape the BIG beads of glue. (don't sweat the small stuff) ^_^
Surfacer Machine
  1. Measure your material thickness. Mine comes out to be around 1-7/16".
  2. Set surfacer to above measurement.
  3. Make 1/16" cut every pass until the glue beads are completely gone.
  4. Do the same on the other side of the board until the beads of glue are gone.
FYI: I feel that any and every cutting board project practically requires the use of a surfacer somewhere in the process. Otherwise, it is nearly impossible to create a perfectly smooth, even surface...quickly. If you do not have a surfacer, then perhaps call a local lumber company.
Random Orbit Sander (Optional)
  • I used 120 grit on both sides
Step 6: Crosscut
Radial Arm Saw
  • Cut the board in half.
If you have a table saw "sled", then use that.
I didn't have a table saw sled so I improvised and used a radial arm saw for the wide crosscuts.
Crosscut in fourths if that's what you need.
Table Saw Crosscutting
  • YOU MUST USE A PUSH STICK!
  • Set the rip fence to 2-1/8"
    • 2-1/8" will be how tall my cutting boards will be.
    • By crosscutting at 2-1/8", I will have 1 rectangle cutting board (15"x12") and 1 square cutting board (12"x12").
    • IF you want 2 cutting boards that are rectangle (15"x12"), then crosscut at 1-5/8", give or take.
Step 7: Alternate Tree Rings
Flip Up and Rotate
  1. Align all of the crosscut pieces so they look like the original board.
  2. Flip all of the pieces up on END in the same direction (so you can see the tree rings on top)
  3. Next, rotate every "even number" 180 degrees. 2,4,6,8,10 etc.
  4. Next step is gluing.
Step 8: Clamps
Clamping - 3 total clamps
  • This step is almost identical to the first gluing process.
    • The only difference is to not glue the 2 cutting boards together near the middle.
  • I prefer NOT to wipe the glue on this step. If you wipe the glue, it will push the glue into the end grain and then cause you to have to sand more in the next step.
Boards on the sides
  • I used 3 quick grip clamps to clamp two boards on the sides so the cutting boards would stay straight.
  • Once the metal bar clamps are tightened, then uninstall the two boards on the side.
  • Do not let them cure on the sides.
Step 9: Surface and Edges
Glue Scraping
  • Scrape just the BIG beads of glue.
FYI I did not use the surfacer for the end grain surface. I think it is too tough on the blades to make a cut on the end grain. If you have a surfacer and you want to use it, then that is up to you.
Random Orbit Sanding
Sand both cutting boards, top and bottom.
Time: took me 20mins to thoroughly do the job.
Sand evenly on the surface. Otherwise, you will have low spots like mine. oops ^_^
  • I used 3 different grit levels: (it's what I had at the time)
    1. 40 grit
    2. 100 grit
    3. 150 grit
Table Saw - Cut to Dimensions
1 - 12x12
1 - 15x12
  1. Shave a little on any given side.
  2. Rotate 90 degrees clockwise and shave a little on that side.
  3. Rotate 90 degrees again and cut to dimension.
  4. Rotate 90 degrees one last time and cut to dimension.
  5. Repeat for the other cutting board at the given dimensions.
Router Edges - 1/2" Round Over
  • Router all 4 corners first. To prevent "chip out" on the edges.
  • Then, router all of the edges, top and bottom.
Sand Edges
  • I used a sanding block with grit levels of:
    1. 120 grit
    2. 150 grit
    3. 220 grit
Step 10: Finish
Paste wax finish - Food Safe!
Most people just use pure mineral oil to finish their cutting boards.
I wanted to make a finish that was more water resistant. So I came up with an 8:1 mixture that uses a food safe wax, paraffin wax!
8:1 Ratio
  • 1 cup mineral oil = 8 ounces
  • Half block of Gulf Wax (paraffin wax) = 1 ounce
  1. Melt the paraffin wax and the mineral oil together. I used a mug in simmering hot water.
Apply the paste wax finish
  1. I heated the paste wax a little before applying. (I feel it spreads better that way)
  2. I applied the paste wax with my hands. My clean hands of course!^_^
  3. Allow the first layer of finish to soak for 20 mins.
  4. Apply three more layers before using!
DO NOT HEAT UP THE CUTTING BOARD. If the cutting board gets hot, it will dry the wood and begin to crack. We do not want cracks in our cutting board.
Step 11: Anti-Skid Pads
Anti-Skit Pads
  • Install pads 1" away or more from the corners.
Modifications
My rectangle cutting board was a little warped, so I used a small washer to give the pad a boost.
Step 12: Care and Maintenence
Surface
  • Apply a layer of mineral oil and wax once a month or when cutting board feels dry.
    • Allow the mineral oil time to soak.
  • DO NOT allow liquids and water to stand on the cutting board for long periods of time.
  • Be careful when cutting raw meat (beef, poultry and fish). Your cutting board must be thoroughly waxed.
    • I personally will NOT cut raw meat on my cutting board. I sometimes will for cooked meats.
  • Sanitize your cutting board with mild soap and water. Dry thoroughly.
    • You could also use a fresh cut lemon to sanitize and freshen the smell.
Sanding - Last result
If you feel your cutting board is beyond worn, then sanding may be your best option.
  1. Use Random Orbit Sander with grit levels of:
    1. 150 grit
    2. 220 grit (optional)
Step 13: ENJOY!!!
This was a fun and inexpensive project! Materials cost me approximately $15.
I hope my post was informative and simple like I said.
Thanks for reading!
Please vote and help me in the 2x4 Contest ^_^
Whatever you do, work at it with all your heart, as working for the Lord, not for men.
-Colossians 3:23
2x4 Contest
Second Prize in the
2x4 Contest
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    79 Discussions
    mrkoolio
    6 months ago
    OK...I just had to offer some corrections. First, the author was nice enough to post all this info., so how about a nice "thank you" before critiquing him. I do lots of wood working and yes hardwoods are traditionally used. however, there is no rule against douglas fir, most people arent using a cleaver on meat in their kitchens anymore, and it is great practice before spending good money to buy the wood for hardwood boards. also, if you look up the wood density charts, douglas fir actually has a surprising high density rating, which comes in at the lower ranges for maple and mahogany, two woods used all the time for boards. So, just because you wouldn't do it, or it might only last a few years, it will save knife edges and it looks great. on to the mineral oil issue. for you folks claiming mineral oil is dangerous, i can assure you that is we said "put warm water on to seal it"...some people would say that was dangerous. Mineral oil is sold over the counter and while a small percentage of people might have some minor adverse impact, almost nothing in life is completely safe. If you breathe too fast, you can hyperventiate. If you drink too much water, you can die. So, mineral oil is say for 99% of the population and it will not rot on your board as will olive oil or coconut oil. For those folks who claim I am mistaken, go coat your board with either of those two oils....I will do mine in mineral oil. NOW, WE can put them in a nice hot box out in the sun for a week. in a week, you wont even be able to get near your board. it will stink and be putrid. mine will not. hope this helps
    mrkoolio
    Reply 6 months ago
    SIR....WHEN YOU TOSS OUT A COMMENT LIKE "DONT USE MINERAL OIL....WHICH EVERY PRO WOODWORKER OR CUTTING BOARD MANUFACTURER USES....EXCEPT YOU I GUESS, THE LEAST YOU CAN DO IS IDENTIFY THIS "NATURAL OIL" THAT YOU SAY WE SHOULD USE. I WENT TO THE STORE AND SAID...."ONE NATURAL OIL PLEASE" AND THEY TOLD ME...OH YOU MUST KNOW THOMASK19....HE SAYS THE SAME THING, BUT WE HAVE NO IDEA WHAT HE IS TALKING ABOUT. SO, WHAT IS THE MYSTERY "NATURAL OIL" YOU USE? THANK YOU VERY MUCH
    ghostgeek
    Reply 2 years ago
    That article addresses ingestion of large quantities of mineral oil as a dietary supplement - not as a wood treating agent on a cutting surface. Apples to oranges.
    apmoritz2
    Reply 3 years ago
    Thank you for sharing!
    I never knew mineral oil was potentially harmful to my health.
    I used the mineral oil to hydrate the wood on the cutting board. I figure as long as I am not consuming the mineral oil in mass quantities I should be good. Besides, most of the mineral oil is absorbed into the wood, not much in getting into my digestive system.
    ghostgeekapmoritz2
    Reply 2 years ago
    With all due respect, I think that Robert is simply misinformed. Not only is mineral oil safe to use, but they actually sell butcher block mineral oil specifically for this purpose. Yes - there are different grades of mineral oil. You wouldn't want to use industrial lubricant obviously. But food or pharmaceutical grade mineral oil is PERFECTLY SAFE, hence the reason it is labeled for said purposes. The paranoia is totally unfounded.
    ghostgeek
    Reply 2 years ago
    So use food grade mineral oil, and it will be perfectly safe.
    Alywolf
    3 years ago
    that was an awesome first instructable, cant wait to see more.
    warriorethos2
    3 years ago
    apmoritz2, great job on the cutting board. Your instructions and pictures will make it easy for anyone to build a cutting board. Good tips on maintenance of the cutting board as well. Good luck in the contest.
    Roddy Scott
    3 years ago
    I agree with you on the raw meat!
    A good sterilising agent is to use a cut lime and rub it on the surface after cleaning.
    Nice work!
    TimB2
    3 years ago
    I just finished making an end grain cutting board from red oak. I did it pretty much the same as you did here in your project. However, my assembled board is still pulling itself apart and warping. The wood had been sitting out in the back of my shop for well over a year before I cut it up. I guess it takes a bit of luck sometimes.
    CharlieS39TimB2
    Reply 3 years ago
    I did, and wrote about, woodworking for many years for print magazines and books: kiln dried is one thing for construction lumber, usually making sure moisture content is under 20% , while kiln dried for furniture making--classify cutting boards here--is another thing entirely, often as low as 6%. I'd suggest investing in a low cost moisture meter. Such a little tool can save more than a little heartbreak, especially after a labor intensive project like end grain cutting boards. I have had three favorite woods for a long time when making cutting boards, but generally avoid end grain work (because it's too much work and hardwoods are harder to work than pine and fir): check out hard maple; walnut and cherry.
    Oh, yeah. Moisture content is a variable, changing with the environmental humidity, but the change is slow. Try to make certain wood used for any project is close in moisture content from piece to piece so any changes are close.
    Enjoy. Woodworking of any type is one of the world's great hobbies.
    apmoritz2TimB2
    Reply 3 years ago
    I will be honest, my cutting board was a little warped on one corner.
    I wonder if my sanding caused the warp or if it was because of the way I glued it in the clamps.
    I'm not the luckiest either.^_^
    TimB2apmoritz2
    Reply 3 years ago
    I would think the clamping affected the "flatness" of the project. I have read where the pro's use special clamping devices to keep their boards flat while the glue is drying. But if you have a contrary board in there somewhere it's gonna do something... particularly if a knot was close to a cut edge.
    ILykMakin
    3 years ago
    Thanks for that. Very cool!
    I did a lot of reading before making some wood items for the kitchen. Mineral oil, especially in the initial quantities and in the upkeep frequency you listed: Not recommended.
    Olive oil, cold pressed, virgin, olive oil is actually best. As long as you don't saturate the wood on initial application or too often after, it soaks into the grain and does not become rancid-the major complaint against it.
    I'd also not use such softwoods either.
    apmoritz2ILykMakin
    Reply 3 years ago
    Thank you for your input!
    I always wondered if olive oil was a better than mineral oil. I guess, I have heard both opinions, but never knew what was true. Thank you for sharing.
    I agree, that softwoods are not desired more than hard woods (maple, walnut). However, after using the 2x4 material as a cutting board, I would say that it holds up nice so far. As long as I keep a smooth polished and waxed surface, it works for me. ^_^
    ILykMakinapmoritz2
    Reply 3 years ago
    Surely. The key, as MarkL failed to catch, is not soaking the wood in it. Apply the type I indicated lightly to the surface and give it time to soak in. Any build up on surface will go rancid. If it's in the wood fibre: It will not.
    And besides, removing rancid oil from over saturation is still preferable, IMO, to toxic mineral oil! lolerz
    antennasILykMakin
    Reply 3 years ago
    Mineral oil is food safe and Olive oil will spoil. Professionals use mineral oil.
    MarkL90ILykMakin
    Reply 3 years ago
    Olive oil is a perishable food and will eventually go rancid. There is nothing wrong with mineral oil especially in these minimal amounts.
