3 Things You Can Make From PVC Pipes (Part 2)
32,185
141
9
About: Innovative Projects, Diy's, Life Hacks
This is the second part of the Instructable "3 Things You Can Make From PVC Pipes"
We will make PVC tongs, improved screwdriver's handle and a key-chain utility knife.
When heating the PVC, make sure to do it outside or wear a respirator.
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Supplies:
Step 1: PVC Tongs
I marked one side of the PVC with a masking tape and then heated that side with a heat-gun.
I flattened the heated side with a piece of wood.
Then I did the same thing with the other side of PVC.
I later learned that it's easier if you heat up all the pipe and then flatten it, instead of doing one side and then the other.
Step 2: PVC Tongs
I heated the middle and bent it around another PVC pipe
Step 3: PVC Tongs
Then I heated the sides and made a groove
Step 4: PVC Tongs
I heated up the ends to the point the pastic started to melt and squeezed the pipe with a clamp.
And then I did some sanding.
Step 5: PVC Tongs
We have made plastic tongs.
I will use it to serve ice cubes.
It's plastic, so don't use it for hot foods.
Step 6: Screwdriver's Handle Improvement
Have you ever had that experience?
You use a screwdriver for so long that you get a blister in the middle of your hand....
There are a few ways to improve your old screwdrivers with PVC.
Screwdriver Nr-1
I heated a short PVC pipe and slid it onto the screwdriver's handle.
Then I heated the other end of the pipe and put on the cap.
The reason for heating is to make the end smaller so the cap can spin freely.
The pipe is removable, so when needed you can slide on the PVC and have an extended handle (if that's what you want).
The cap will spin and save your hand from getting blisters.
Step 7: Screwdriver's Handle Improvement
Screwdriver Nr-2
I heated the "T" connector and slid it onto the handle.
When needed, you can attach the "T" connector to have a better grip.
Step 8: Key-Chain Utility Knife
I heated a short PVC pipe and squeezed it with a clamp.
Then I inserted a blade and squeezed the clamp even more.
Step 9: Key-Chain Utility Knife
I cut two pieces from beads peg-board and glued them to the clamp.
Step 10: Key-Chain Utility Knife
I used the clamp to make a dotted pattern.
Step 11: Key-Chain Utility Knife
When you reheat the PVC pipe, it will take it's original shape.
That's why I switched to the candle as it's easier to control where the heat is applied.
I heated both ends of the pipe and closed them with a clamp.
One of the ends was closed with a blade inside.
Step 12: Key-Chain Utility Knife
I snapped off the blade and made a cap from a bigger PVC pipe.
Step 13: Key-Chain Utility Knife
I drilled a hole in the cap and did a final sanding.
Step 14: Key-Chain Utility Knife
Our key-chain utility knife is ready.
The blade will hold in place by the pressure of your fingers.
Great for opening parcels and other tasks.
Because the knife is sharp, it's great for emergencies.
If you ever get into an accident and your seat belt has jammed, use the knife to free yourself.
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    9 Discussions
    DarrenO2
    2 years ago
    AWESOME!!!!!!!!!!!!!!!!
    Thank you for sharing your creativity and your concern for others.
    Mihsin
    3 years ago
    All of your projects are appreciated.
    Ledz Workshop
    3 years ago
    be careful burning pvc, I heard it exudes really toxic fumes. PVC uses and releases highly hazardous chemicals including vinyl chloride, dioxins, mercury, phthalates, and other chemicals that have been linked to deterioration of the central nervous system, liver damage, reproductive harm, and certain cancers.
    ShakeTheFutureLedz Workshop
    Reply 3 years ago
    Yes, I was wearing a respirator and I also mentioned it at the beggining of Instructable.
    Cheers!
    dacarlsShakeTheFuture
    Reply 3 years ago
    Most dust respirators or dust masks will let toxic gases right through.
    Carbon/charcoal adsorbent removes toxic gases from what goes into your lungs. What did you use?
    ShakeTheFuturedacarls
    Reply 3 years ago
    I used a proper respirator not just a dust mask.
    But I am looking into getting another one as there are times when I am not too convinced about its efficiency.
    Thanks for the info.
    Cheers!
