3 Things You Can Make From PVC Pipes (Part 1)
140,497
638
84
About: Innovative Projects, Diy's, Life Hacks
It's always a good idea to keep some PVC pipes at home, because they can be very handy.
PVC pipes are like Lego's for adults.
In this Instructable, we will have a look at 3 Things that you can make from PVC pipes.
We'll make a foam cutter, hacksaw and a selfie stick.
You will need:
For the Foam Cutter:
For the HackSaw:
  • PVC Pipe
  • Hacksaw blade
  • Steel wire
  • Split washers
For the Selfie Stick:
  • 2 different size PVC pipes (smaller should perfectly fit inside of the big one)
  • Steel wire
  • PVC cap
  • Twist - Hose clamp
  • A screw that fits your camera
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1: Handheld PVC Foam Cutter
Make sure to wear a respirator or heat the PVC outside!
I took a pipe bender spring and put it inside of the PVC.
I heated up the PVC in the place I was going to bend it.
Then I carefully bent it.
The procedure was repeated until the pipe took the desired shape.
Step 2: Handheld PVC Foam Cutter
The I trimmed it shorter and drilled a hole for the cables.
Step 3: Handheld PVC Foam Cutter
I drilled a hole in a PVC cap to insert an eye bolt.
After crimping terminals to the cables, I attached them to the bolts.
Then I put the caps onto the PVC ends.
Step 4: Handheld PVC Foam Cutter
I used an universal power adapter as my power source.
I soldered it to the cables coming out from the PVC (polarity does not matter)
I used a heat-shrink tubing to isolate the connection and make it look neater.
Then I glued it to the PVC with a black glue.
Step 5: Handheld PVC Foam Cutter
To make sure the handle does not move sideways when I hold it, I glued it together.
Step 6: Handheld PVC Foam Cutter
I stretched a nichrome wire across the bolts.
Because our PVC pipe is flexible, the wire will stay tight even when it heats up or cools down.
Step 7: Handheld PVC Foam Cutter
You can regulate the heat by changing the voltage.
Foam can be cut just like the butter.
Step 8: PVC HackSaw
After inserting the spring into the PVC, I heated up the pipe.
Then I kept shaping the PVC, until it looked like a letter "C".
Step 9: PVC HackSaw
I put a smaller spring inside of the pipe to make sure I could get it out later.
I wrapped the pipe with a steel wire that was attached to the table.
Step 10: PVC HackSaw
To make sure the pipe does not unfold when heated, I tied it together with an electrical tape.
I heated up a small part of PVC and then pulled it UP to create a pattern.
When the pipe was cold again, I changed the position of the wire and repeated the same procedure.
I also did it on the other side of the pipe.
Step 11: PVC HackSaw
Then I cut the pipe shorter and made a few cuts to insert the blade.
Step 12: PVC HackSaw
And last, I put in the blade.
Just like with the foam cutter, the PVC will keep the blade tight.
Step 13: PVC Selfie Stick
I made a "swirl" pattern in a PVC pipe
Step 14: PVC Selfie Stick
I made 4 cuts in the pipe
Step 15: PVC Selfie Stick
I took a smaller pipe and drilled a hole in it.
Then I heated it up and made it flat-ish.
Step 16: PVC Selfie Stick
I squeezed a screw in the vice and put a small PVC ring on top of it.
After heating it up with a heat gun, I used 2 pliers to make a "T" grip/handle.
Step 17: PVC Selfie Stick
"T" grip screw will serve to hold the camera.
I decided to bend the pipe to make sure the camera is at the right angle.
Step 18: PVC Selfie Stick
I took a hose clamp and painted it black.
Then I put it on top of the big pipe to hold the smaller one.
Now you can adjust the length of the small pipe.
Step 19: PVC Selfie Stick
And last, I glued a white cap on the bottom of the stick.
3 People Made This Project!
  • Tape Contest
    Tape Contest
  • Paper Contest
    Paper Contest
  • Weaving Challenge
    Weaving Challenge
84 Discussions
El.Dan.05
2 years ago
Or maybe a simple truck bed tent? :D Made this from pictures I found online. Don't have a link - I'm too lazy to duckduckgo and search, sorry. But just add an air mattress and BAM! instant (festival, in this case) getaway.
iristana
3 years ago
love they way you make the foam cutter will make this for my daughter who does a lot of crating for her neices
TeleDexiristana
Reply 3 years ago
I coach Junior High sports and while there are many children I would like to "crate" I believe it might be illegal. Oh . . . you probably meant "crafting, not "crating." B^)
connieliang
3 years ago
Neat! Really admire ur work! Don't cut your finger nail to short it supposed to protect your fingers ....love your sharing, keep doing it!
ShakeTheFutureconnieliang
Reply 3 years ago
It's a bad habit I have :(
I am biting my nails.
I don't know how to stop doing it.
I should try one of those anti-nail biting nail polishes.
Cheers!
anayjoshee
3 years ago
Very neat and impressive foam cutter, grip and wing nut idea
very handy, Thanks
Dawsie
3 years ago
I loved how you made the t-nut I have been looking at making some with wood but now I think I will use your idea :-) it's fast and easy and looks cool too :-)
I could not make up my mind which one I liked the most as they are all great ideas:-)
The styrofome cutter is one that I will be making as this will come in handy for my hobbies :-) and will save me hours of cleaning up small balls from every nock and granny :-) now I just have to see if that plug can be bought here in Australia for our power points :-) have not seen one of those in years :-) not since I was in England at least :-)
I am not one for selfies but it was a very good build I know of someone who will love it so I will be making one for them for their birthday :-) thanks for a great idea :-)
They are all great ideas :-) thanks for sharing them with us :-)
ShakeTheFutureDawsie
Reply 3 years ago
I hope you'll find the power adapter :)
Thank You!
tcollo
3 years ago
The PVC Foam Cutter is great. Wish I had one last year but I'll make one now.
Wileaux
3 years ago
I love the selfie stick but am unsure how to release the shutter other than using the timer on the camera itself? Am I missing something?
ShakeTheFutureWileaux
Reply 3 years ago
Since I am not sure with what camera I am going to use it, there was no point to make a shutter release button as different cameras have different ways to do release it.
If you make the selfie stick for a mobile phone, then this is an option:
In the Instructable "Make a Super Selfie Stick", the selfie stick had a bluetooth shutter release button, but I never used it as most of mobile phones these days can take a picture with a voice command. I am not sure if that remote works with cameras.
Mostly I will use the selfie stick for videos so I don't need the button.
I guess the easiest option (for the camera) is to buy a mini shutter release remote and tie it to the stick.
Cheers!
KROKKENOSTER
3 years ago
Very good info here but just a tip on hacksaws ALWAYS RELEASE THE TENTION on the blade this prevent future having to discard a good frame. Junior hacksaw that is made out of a bent wire and this instructable too, fit the blade "Back to front" and do your cutting when you DRAW the blade backwards! Give a more controlled cut and the frame tension stay the same especially when you saw thin material.
azizkres
3 years ago
Awesome... I like the selfie stick because of its adjustability.
