3-in-1 Desktop Organizer
14,446
242
14
About: Making things for the thrill of it.
This piece of desktop accessory was designed to serve 3 different functions.
  1. Laptop Stand: props the laptop up by 18cm from the surface of the desktop. This is the ideal ergonomic height making the top of the screen aligned to eye level.
  2. Organizer Tray: the built-in drawer at the front provides easy access for all your desktop stationaries.
  3. Docking Station: when the laptop is in docking position, things like power adaptors and hard drives can easily be plugged in but remain out of sight.
test
Step 1: Materials
test
This project was made entirely with plexiglass and held together by metal fasteners. Here's a list of materials I used for the build.
  • 5mm acrylic sheet (55cm x 60cm)
  • 3mm acrylic sheet (40cm x 40cm)
  • M5 x 20mm brass machine screw and nuts (x8)
  • M3 x 15mm stainless steel machine screw and nuts (x6)
  • white spray paint
Dimensions are tailer made for a 15" MacBook Pro. But will also work for all laptops 13" and above.
Step 2: Cut File and Assembly
test
test
All pieces were cut with a laser cutter. (cutting file attached)
I used transparent acrylic and spray painted the casing white, all the interior partitions were left transparent.
There were three pieces labeled 1 and 2 that were laminated using acrylic solvent cement. All the other pieces are assembled glue free using the machine screws.
test
Step 3: Footnotes
Connection Detail
The detail of the machine screws was a result of the decision to make the assembly process glue free. I quite liked this detail and I felt like the brass finish complements the white paint nicely. You can of course avoid this complication by simply gluing the pieces together. For gluing acrylic, I think a solvent-type bonding agent work best. I apply it with a brush and the bond forms almost instantly.
Dimensions
The height of the laptop stand at 18cm was designed according to the height of my desk and chair and my height. This is a dimension you might want to adjust according to the setup of your person workspace.
The dimension of the docking station is in fact the leftover space from propping up the laptop, which naturally forms a triangular shaped space underneath. This space was enough for me to store things like power adaptors, chargers, and hard drives. but if you need more accessories to be plugged into your laptop you should adjust this space accordingly.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    14 Discussions
    dextraise
    Question 13 days ago on Step 2
    Hi ! It's really clever ! Could you provide the SVG files ? :D
    frclasso
    16 days ago
    Awesome! Congratulations.
    I like the idea of the underneath storage compartment. It would fit all the bits and pieces that are just impossible to locate after a hard day's of work on the laptop.
    marcospo
    5 weeks ago
    Great idea, superb execution!
    shiv2132
    6 weeks ago
    This looks great! Where can I find the cutting file?
    Thanks, Shiv
    Gusgonnet
    6 weeks ago
    beautiful and useful.
    Well done!!!
    chronocide67
    Tip 6 weeks ago
    Just a thought but this would make an interesting floating stand to put the screen at head height. I made a rough wood version of this to lift my laptop up so I would not have to look down for so long which cause neck pain. Even if you kept it table top and made it higher with more drawers the effect would be the same.
    chronocide67
    6 weeks ago
    Nice, although you may want to use some kind of screw cover for the exposed screws.
    ErikRuud
    Question 6 weeks ago
    This looks awesome but I seem to be missing something. I don't see the attached design file.
    0jack
    6 weeks ago
    This looks very nice and also versatile. The brass screws make this version look really classy and add a little aesthetic substance to it. I've never used a laser cutter before but apparently they have one downtown and I found some hot pink acrylic so I may be obliged to try it out for my kid.
    harryMake0jack
    Reply 6 weeks ago
    Thanks 0jack, let me know how it turns out. Im curious to see how it'll look in hot pink!
