3D Print Your House!!!!!
3,048
40
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
Using a drone, autodesk recap, and autodesk remake making 3d models of anything is easy! In this tutorial I will show how to make your house into a 3d model!
Supplies:
Step 1: Build and Upload the Flight Plan
Add a waypoint over the building you would like to scan, then change it to structure scanner and change the params to fit your setup. Then upload it to the drone.
Step 2: Takeoff
Arm the drone, then select "Auto" to start the mission. The drone will keep the camera pointed towards the building and circle it for however many times you specified. Just let it do its thing.
Step 3: Start Autodesk Remake
Visit https://remake.autodesk.com/ then select "photos to 3d", upload your photos, then configure the settings by selecting smart cropping to "ON". Now its going to upload the photos and process them into a 3d triangulated mesh.
Step 4: Download the File
This step is easy, just download the rcm file.
Step 5: Crop Out the Object in ReCap
Use Autodesk ReCap to edit the file, select the object area you want then either delete or isolate it.
Step 6: Admire the Detail
I always have to sit back and admire the detail every time i do this the first photo shows the triangulated mesh, notice how close the triangles are. The other images show a x-ray view where you can see the simplest details such as the windows.
Step 7: Export to STL by Select 3d Print
Now we need a stl file that slicer programs can turn into g-code. Make sure to fix the file before exporting or i may glitch the slicer program.
Step 8: 3D Print
Each 3d printer is different so i can't realy help you out here, just do whatever you normally do to 3d print and be AMAZED!
Step 9: Your Done!!!
Make sure to check out my YouTube video, it may help a little bit more! If you have any questions just leave them in the comments.
I hope you liked the project, I have found it to be really useful let me know what you plan to do with it! Also be sure to become part of my social community:)
Facebook: https://goo.gl/bzoDKz
Instagram: https://goo.gl/bzoDKz
Youtube: https://goo.gl/bzoDKz
FunguyPro: https://goo.gl/bzoDKz
See ya next time :)
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    3 Discussions
    Andrews-Design
    1 year ago
    Fantastic! I had thought about this a while back, to make a mesh I could use to plan out a custom patio for my backyard, and this is exactly the procedure I will use.
    Funguypro
    1 year ago
    For those people without drones, you can do the same thing by taking pictures with a camera from a distance, but you may have trouble getting places like the roof.
