3D Printed 1911
142,333
646
84
First off, I'd like to thank Rio Benson for making the absolutely amazing drawings of the 1911 which can be found here.
DISCLAIMER: I will not be held responsible for any damage done with this model.
When I started this project, it was really just one of those things to see if it could be done. I did not use Rio's personal models; Instead I used his drawings and made my own. Internally, the gun doesn't function. The trigger doesn't even move. Externally, the model is completely accurate with the exception of the slide stop. The only moving parts are the safety lock, hammer, slide and barrel. I also had to change a few dimensions due to the 3D printer tolerance so if CNC'd; it may not work together as well. If you plan to 3D print it, then you will most likely have to use your own. I know that some companies that function like Shapeways are cracking down on the dangers of printing functioning firearms and may not allow you to print this file. If you do have the ability to print this, I Highly recommend using bright colors for the barrel or even the entire gun. While no laws in the US prohibit having this model on your persons, there are multiple instances of people (especially children) being shot by police for waving around fake realistic weapons. For those of you who think they cannot handle the responsibility or plan on giving this to someone who cannot handle it or just have no need for a complicated replica, I have supplied a slide without a moving barrel.
For reference, this was printed on a Dimension BST 1200es. I edited the dimensions specific for this type of modeling. No sanding is required on any of the pieces. I will be unable to complete the model the way I would like so the files I have completed are now available.
Step 1: Safer Slide
Other than the fact there is no barrel altogether for this piece, it is exactly the same.
Step 2: Grips
Insert the "grip pegs" into each grip.  I recommend pushing the grip against a hard surface instead of pushing the peg into the grip.  This helps alleviate and disperse the stress on the plastic.  To attach the grips to the frame push the frame onto the grips.
Step 3: Closed Slide
If using the closed slide option, assembly is as easy as sliding the slide on to the frame.
Step 4: Open Slide
For the open slide option; you should attach the barrel link before inserting the barrel into the slide.  Remember to use the "barrel link to barrel" piece [For this assembly step I used an earlier model to take pictures.  The barrel has been reinforced so it should no longer break in the barrel link area]  When inserting the barrel into the slide, the barrel will not go smoothly.  You will have to tap it in with a mallet.  [Don't fret though because the slide has been designed to take a lot of pressure in the front while the barrel has been thickened to prevent snapping.  I have taken multiple barrels in and out of one specific slide and have yet to break either one]   Attach the slide just like the closed version, except now you need to position the barrel link so it lines up with the hole on the frame.  Once they are aligned, press the frame onto the "barrel link to frame" peg.
On this particular piece, I made the grooves in the barrel and slide so this model could be used to help someone understand how they interact with each other.  Moving the slide forward will engage the lugs and prevent it from continuing off of the frame, same in reverse.  I personally did not know how this worked until I was half way done with the model
Step 5: Hammer/Safety Lock
By now the assembly is quite self explanatory.  I recommend doing the hammer first but the holes allow any order.  I designed the safety lock to be a tight fit so it springs back up when pushed into the safe mode.  For this to work properly, you will need to insert it in the locked position.
Step 6: Conclusion/Future Steps
That's it.  Don't do anything stupid with this.
I currently have a .stl file of the magazine but its just a solid block and it has no real locking function.  Until i figure out what exactly I want to do with it I'm  going to keep it off.
Once I have the magazine figured out, I plan to make it so pulling back the slide will eject a plastic shell casing.  I already have some ideas of how to go about it but it's not really the top of my priority list.
Stay tuned
3 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
84 Discussions
RyanS62
1 year ago
i started printing it, and i noticed a few things
the barrel is 15ish mm longer so you can have an orange tip
i had issues where pins and such are extremely tight fit, also my printer is not calibrated 100% but a lot of sanding and everything fits snug and magazine drops nicely and is baby bottom smooth.
mag catch hits the side grip had to carve a small groove.
and magazine spring pops out when out of rounds i might print a stop for that. but it functions.
MarcelloG12RyanS62
Reply 4 months ago
In which orientation did you print the frame? I can't figure it out which one would be best, did you use rafts and supports?
fightingcrows
6 months ago
Does anyone know where I could buy a made one from anyone?
DigitalR3
1 year ago
unprintable on any cheap 3d printer!
you need one of those big expensive ones:( BUT you did an amazing job on the making these models! can't wait for the bullet eject system or until the good 3d printers get under 700dollars so I can finally print this!!! :)
eimoroDigitalR3
Reply 7 months ago
I don't have a 3d printer at all, but i'm using Pepakura and it works just fine
docman100sdjfops1
Answer 6 months ago
He said it was fake and that the trigger doesn't even move.
eimoro
Question 7 months ago
How can I get the magazine? what is the scale?!
I actually have a plastic replica so I can just measure it... if you want it i will try to post it soon
GuilhermeB62
Question 8 months ago
Hello, can you post the solid block magazine? I started printing it as a gift for my brother and I really wanted it to be complete. Thanks
LauranceD2
1 year ago
its missing the parts that make the closed grip. its an assembly file and without the individual parts, im unable to access the ipt version of the gun
please update that if possible
RAWICE511
2 years ago
Please help all of the parts are really really small how do i fix this?
DigitalR3
1 year ago
what a shame..i think this project is dead :(
... its cool but its a bad idea, its not traceable,cant be detected by metal detectors, plus its easy to dispose of after killing some one... so yeah don't do anything stupid with this
Jarrod EllisRhetorical_Save
Reply 3 years ago
There is already 3D printed guns that can fire 22, all the way to 5.56, this would explode first shot....
No they haven't. If they did, it would require modifying the CAD files extensively, and adding a metal firing pin, and probably metal metal supports to hold the frame together.
