3D Printed Bionic Hand Skeleton
25,530
377
64
About: Junior Design Engineer. Thats why I look so frightened in my profile picture... Late nights, Gallons of Coffee and Tons of new ideas is mostly what drives me. Love to create, make and learn something new eve...
So here goes: This is my first personal project, my first 3D printed project, my first Fusion 360 project and my first Instructable ever. (Crowds applauding and cheering and some high school girls whistling in the back). I guess you could say I was a “Virginstructable” before this …
A friend told me to “design something handy!” … so, I did.
I consider this 3D Printable Hand Skeleton as a baseline for a Bionic hand (which I intend to develop into a working Bionic hand with Arduino controllers and actuators). The design was done in such a manner so that all parts can be 3D printed without hassle or supports. I was a bit pressed for time because I really wanted to submit this project for a competition to win a new T-shirt; I really need a new T-shirt …
For THIS instructable the focus will be on how to work the 3D printed parts and how to build the components into something that works.
In this case, it will be a 3D Printed Hand Skeleton that open and close mechanically by means of elastic cords and ribbon.
Supplies:
Step 1: Design
I will very briefly describe the design process.
I designed the hand completely using Fusion 360 and a nice bottle of J&B. I quickly want to thank my girlfriend as well, if it wasn’t for her the design would’ve been done a week earlier. (High school girls in the back get up and leave.)
I found a picture that I used as inspiration to design the skeleton as close to the real human hand as possible. (A GREAT app for viewing the human skeleton and muscles is “3D Atlas of anatomy”! Try it)
I mostly used profile sketches and lofts for the modeling. I experimented with the “Sculpt” tool, but found that for THIS design I had more parametric control using profile sketches.
The rest of the process you can see in the FUSION 360 files. I don’t want to jabber on about all the little design intricacies but note that the main design intent is for 3D printing and motion (A hand without moving fingers is as useful as a wet sock). All components and fits were designed keeping it’s printing orientation and quality in mind. I would like to experiment with snap on ball joints in the future to make the model more accurate. I couldn’t do it in this run due to some limitations (That green paper that makes the world go round, and time!)
The fact that I designed the LEFT hand was completely by accident but if someone asks, “there is a wide range of complicated reasons for choosing the Left hand over the Right hand”.
Step 2: Get What You Need:
For simplicity, I will only include the tools I used. You can use your own discretion to use other tools as you deem them necessary. For instance, if you want to use a motorized chain saw to deburr some of the edges, which I am NOT recommending - be my guest, but please send a video!
3D Printing Service
Most important of all you will need a 3D printing service to print your components. (Kind of obvious, I guess). I am lucky enough to know a guy who knows a guy that owns his own 3D printer, whom I convinced with carefully selected words to give me a hand. Literally.
A Clean workspace
A clean workspace makes building and working much more enjoyable. If you prefer to sit on the floor with your dog licking your face while you grind pieces of plastic you are welcome to do so. I prefer a work table specifically allocated for the project though. It should have good lighting and a power point nearby if you are using any tools which require power.
Necessary Tools
You will most definitely need the following tools:
  • · Small Pointed Tweezers - This is the tool that I will attach to my hand (my real human hand) if I could! I did almost everything with this handy little bugger!
  • · Two-sided Nail File/Sanding paper - You will use this to finish and smooth out your 3D printed parts. It works best with a nail file that has two sides, one smoother than the other for a good finish.
  • · Screw Driver - You will use this to tighten machine screws during assembly. Who could’ve guessed…
  • · Scissors - You will have to cut elastic bands and ribbon.
  • · A Lighter- We will find multiple uses soon. I am sure of it.
  • · Small Hand Saw - Used to cut aluminum tubes into pins.
  • · Punches - Used to flare out the pins’ edges
  • · Small Hammer- Used to punch the punches, yes, really!
  • · Ruler/ Vernier Calipers - to measure things of course.
  • · Marking Pen - To mark things.
Optional Tools
The following tools are optional and might aid to accelerate and simplify the assembly and finishing processes.
  • · Small rotary hand tool (from here on referred to as “Dremmel”). Can be used to open up some holes, drill holes, sand the 3D printed parts, cut screws to needed sizes, etc. I used a friend’s cordless Dremmel 7.2V. During the steps, I will point out what attachment you can use for the specific step.
  • · IF you use the Dremmel, USE SAFETY GLASSES EVERY TIME!
  • · Small heat gun - Can be used to fix the decolored 3D printed parts and to ‘reform’ the hoops through which the elastic and ribbon will be threaded. I used a normal cigarette lighter for this. Told you we will find a need!
  • · A pair of working gloves - Tight fit gardening gloves will do the trick.
  • · Insulation Tape - Can be used to mark your pins and screws for cutting.
3D Printed Parts
Here are the components you will need for this project. I named the 3D printed parts according to their “medical” names mostly because it is fun to say “phalanx”. I also creatively combined some names for my own personal enjoyment. I list them here in their respective sub-assemblies.
  • 1st Digit (Thumb):
    • Distal Phalanx 1 (DP1)
    • Proximal Phalanx 1 (PP1)
  • 2nd Digit (Index Finger):
    • Distal Phalanx 2 (DP2)
    • Middle Phalanx 2 (MP2)
    • Proximal Phalanx 2 (MP2)
  • 3rd Digit (Middle Finger):
    • Distal Phalanx 3 (DP3)
    • Middle Phalanx 3 (MP3)
    • Proximal Phalanx 3 (PP3)
  • 4th Digit (Ring Finger):
    • Distal Phalanx 4 (DP4)
    • Middle Phalanx 4 (MP4)
    • Proximal Phalanx 4 (PP4)
  • 5th Digit (Little/pinky Finger):
    • Distal Phalanx 5 (DP5)
    • Middle Phalanx 5 (MP5)
    • Proximal Phalanx 5 (PP5)
  • Metacarpals:
    • Metacarpal 1 (MC1)
    • Metacarpal 2 (MC2)
    • Metacarpal 3 (MC3)
    • Metacarpal 4 (MC4)
    • Metacarpal 5 (MC5)
  • Carpels:
    • Captrap
    • Hamatum
    • Lunoid.
(FYI: These were named at 3am one morning and done for my own enjoyment. I combined the medical terms for the hand carpels:
- Capitate + Trapezoid = Captrap
- Hamate + Triquetrum = Hamatum
- Scaphoid + Lunate = Lunoid)
That amounts to a total of 22 3D printed parts (Excluding “Sample Parts”). Don’t panic!! They are small and easy to print!!
I furthermore suggest that you print a SAMPLE DIGIT (For e.g. print an extra Pinky – DP5, MP5 & PP5; you can use this digit to test some steps on so that you don’t completely mess up a component in the main assembly!).
You can view and download the parts through the following link: http://a360.co/2qmdVpw
Bought Parts:
You will also need the following fasteners / bought parts:
  • M3 x 16 ‘CSK Machine Screws’ [QTY 12]
  • M3 x 25 ‘CSK Machine Screws’ [QTY 11]
  • M4 x 75 ‘CSK Machine Screws’ [QTY 2]
  • M3 Nuts [QTY 33]
  • M4 Nuts [QTY 2]
  • Elastic Cord +Ø2mm [ + 2.5m]
  • 3mm Ribbon [ + 2.5m]
  • 3mm Aluminum/brass tubes [250 mm]
(*These are all in Metric units - I strongly believe the rest of the world is moving to metric units inch by inch.
*CSK = Counter sunk!)
Step 3: 3D Printing
As mentioned before, this is my first 3D printing project and I am quite the novice (FOR NOW) when it comes to this step. I watched multiple videos with regard to design for 3D printing during the design phase to ensure printable parts. I’m not going into those details too much as it is an Instructable topic of its own.
The friend of a friend was kind enough to give me a few details of the printer and settings he used:
  • -Pruza i3 MK2S 3D printer
  • -0.4mm Nozzle
  • -1 layer raft with 70% infill
  • -0.2mm Layer Height
  • -3 Top Layers, 3 Bottom Layers, 2 Perimeter Shells
  • -Infill +- 15%
  • -Extruder 215deg on Layer 1, 205deg on rest
  • -Heated Bed 55ᴼ Celsius
  • -1.75mm PLA Filament.
Two parts failed that were printed without the raft as they toppled over during the printing.
We concluded that the raft is therefore a
good choice, but not 100% needed, as a lot of parts were successfully printed without any rafts.
Step 4: Part Post Processing
The first thing to do after you have received your parts is to give the bloke who printed your parts (even if that bloke is yourself) a big hug and a bottle of whisky, or ice tea, or cold hard cash. In my case it was cold hard cash.
The parts will need a bit of attention now to ensure good fits. They were all designed with generous (but not TOO generous) tolerances. I fitted the parts directly after printing and removing the rafts, and found that they all fitted well, but the motion was “scratchy” because of the contact surfaces and that the elastic cord was slightly too big to just slip through some of the loops. I decided to smooth out the contact surfaces, open the loops a bit and remove some irregularities.
So, there are two main objectives in this step:
  1. Ensure smooth movement and fits between parts.
  2. Ensure the loops for the elastic cord and ribbon are big enough.
Smoothing Surfaces and Clearance Holes
You will need the following tools for this step:
  • M3 CSK SCREWS AND NUTS
  • Nail File / Dremmel
  • Tweezers
Assemble the respective fingers using the M3 x 16 CSK SCREWS AND NUTS-M3 X 25 CSK for the Thumb pieces. You might have to use the tweezers to remove some strands of PLA in the holes and on the bases. I just fidgeted the screws through in most of the parts and removed the rafts with tweezers.
Push, pull and rotate the different parts (don’t BREAK the parts, you animal!). You will be able to feel and hear which joints need the most attention. Then proceed to gently file and round the heads and bases of the parts. Gently file them as if you are an elderly woman sitting in a salon getting your hair permed. Test them regularly to feel the difference you have made. When you are satisfied with the movement, you can use the Dremmel with a polishing head OR the smooth side of the nail file to finish it off. After that you can gently use the heat gun on your worked surfaces to fix the decolorization. (I didn’t do this because I don’t have a heat gun and stuffing the parts into the oven seemed a bit excessive).
You don’t have to worry about the insides of the bases too much. You can use the tweezers to remove some unwanted strands on the inside, but the smoothed heads will be good enough for smooth motion.
Note: If you used the Dremmel, be careful not to completely destroy your parts!! Use low settings and GENTLY graze the surface with the tool.)
Opening up the Loops
This step needs to be handled with a lot of caution and should only be done if it is absolutely necessary!
PLA is extremely sensitive to heat but you can use it here to your advantage (and certainly at your own risk). Practice this a bit first on your SAMPLE PARTS before applying it to your main parts!
You will need the following:
  • Tweezers
  • Lighter (Or heat gun)
  • Small piece of elastic rubber and ribbon
FIRSTLY, try to fit the elastic band and ribbon through the loops. Identify the loops that will need some opening. I only had to open up the loops on the Distal Phalanges (DP1-5) and MP5.
Gently apply the flame to the loop that needs opening. Not more than 2 seconds! And quickly but GENTLY stretch the loop with the tweezers’ points. The PLA hardens fairly quickly so you need to “Ninja” this step. You will most probably only have to do this to the inside part of the finger.
I stress again: PRACTICE this step on your SAMPLE parts first! In the pictures, you can see I used a failed print to practice with.
Now that our 3D printed parts are all processed and ready to mingle, you can preassemble them. Use the M3 screws to keep your parts in their respective subassemblies. (Build the fingers so that you can see where each part goes! You don’t want to end up with messed up fingers … Nobody does).
We can now move on to the cutting of our pins and screws.
Step 5: Cutting the Pins, Screws, Elastic Cord and Ribbon
The objectives of this step are fairly well described in the title of this section:
  1. Cut the pins to size
  2. Cut the screws to the right sizes
  3. Cut the ribbon and elastic band to usable sizes.
Note: If you use the Dremmel, you need to hold the parts with a piece of cloth or a glove. The parts get quite hot during the cutting process! The specified lengths are ‘more-or-less’ and you don’t have to worry if you have cut it slightly smaller or larger.
Cutting the Pins
  • Hand Saw/ Dremmel with Grinding disk (AND SAFETY GLASSES)
  • Ruler or Vernier Calipers
  • Ø3mm Aluminum/Brass tubes
  • Optional: Insulation tape & Nail File/ Sanding paper
I suggest executing this step in the following manner: Measure-Cut-Measure. Your tool will remove a segment from the tube so rather cut a piece, THEN measure out the next piece. Push the piece you want to cut firmly on the long side with the edge you want to cut hanging over an elevated edge. I used a piece of offcut wood. You want to have your work piece pushed down firmly before you start the cutting. Make a small marking with your cutting tool and gradually work through the work piece. This applies to the cutting of the screws as well.
You will need to cut the following lengths and quantities of aluminum pins from the tubes:
  • +- 15mm, QTY =12
  • +-18mm, QTY = 2
Cutting the Screws
  • M4 x 75 CSK screws [QTY = 2]
  • Marking Pen
You want to cut the two long screws so that they don’t stick out at the bottom of your assembly. You can mark them with a marking pen or use the tape. Stick a piece around the inside of the screw to mark the edge where you want to cut.
You will need to cut two M4 x 75 CSK screws to the following sizes (measured from the head to the tip):
  • 58mm
  • 56mm
You can finish off the cut edges of the pins and screws with a file or sandpaper if you find it necessary.
Cutting the Elastic Band and Ribbon
You will need:
  • Ribbon and Elastic Cord
  • Scissors
  • Lighter
You need to cut the following lengths and quantities. You will find later that you need much shorter lengths but it’s always easier to cut a piece off than it is to sew it back on; that’s why I suggest the following lengths:
  • Ribbon: 350mm; QTY = 5 PIECES
  • Elastic Cord: 300mm; QTY = 5 PIECES
Cut a triangular tip on the one side of each piece of ribbon and tie a triple knot in the other end of it; you can snip off the short end coming out of the knot. Use the lighter to slightly singe the tips of the elastic cord and ribbon. Prepare 5 pieces of each.
Note: The knots in the ribbon will be used as a “Stop” in the assembly. Make sure it doesn’t slip through the hole on the tips of DP1-5 if you pull on it. IF it slips through- just tie another knot over the existing one.
Good. Now we have all the parts to start the assembly. But first I think you should put a band aid on that nasty cut on your finger and remove the piece of grinding disk from your eye because you didn’t wear your safety glasses. (WEAR YOUR SAFETY GLASSES!)
Step 6: Assembly
We will assemble the hand in the following manner:
  1. First the fingers/ Digits and their respective Metacarpals.
  2. Then the Base – With the Thumb digit included
  3. Lastly, we will attach the Digits to The Carpels/Base.
Digit/Finger Assembly
You will need:
  • Punches
  • Hammer
  • Tweezers
  • 3D Printed Parts
  • Cut Pins
  • Cut Ribbon & Cord
I will only demonstrate and guide you through the assembly of one digit. The rest are done in exactly the same manner. The 2nd to 5th Digits use the 15mm pins. The 1st Digit Uses the 18mm Pins. You can choose to keep the fingers assembled with the M3 x 16 screws, but they will cause interference in the assembly and restrict motion of the fingers.
First, we will slide the cord through. If you have opened up the hoops correctly, this step should be fairly easy. Gently push the one end of the cord through the hoops ON THE INSIDE as indicated. You can use the tweezers to assist you. Leave a generous piece sticking out at the tip as we will tie that into a knot soon.
Next you want to slide the piece of ribbon through. Slide the end that you cut through the small hole in DP1-5 from the bottom. The knot you made should not slip through the hole. Pull on the ribbon to ensure the knot does not slip through. You can proceed to slide the ribbon through the remaining hoops.
Now tie the knot in the cord on the end that sticks out the end of the finger - make sure it’s tight and doesn’t fit through the hoop.
For the pin connections, we will punch the punches! Take a pin that you have cut and slide it through the connection point. I kept the fingers assembled with the screws up to this point. Take the screw out and replace it with the pin. Position the work piece so that the pin’s one end rests on a hard surface (I used a small piece of scrap aluminum sheet) and the other end is open for punching. Insert the punch and hold it carefully. Gently tap the top of the punch with a hammer. Do the exact same thing to the other side. Two hits on each side and one on the thumb did the trick for me.
You will have to put in 14 pins like that.
Note: Make sure you attach the correct 3D printed parts to each other in the correct orientation - When the pins are flared out it is extremely hard to remove them without damaging your 3D printed part!
The final step for the digits is to tension the elastic cord on the inside and tie another ‘stop knot’. Hold on to the MC part and pull on the cord - the finger should “close” when you do this. You can slightly tension the chord and tie a knot that is bigger than the loop. Tie one to two knots so that the cord doesn’t slip through the loops.
I played with the tension a lot and found that you don’t want to pre-tension the cord a lot. You basically want to close the finger and tie the knot. The finger should be closed now by default. You can experiment with the tension of the cord. Play with it by holding the base piece (MC2-5) and pull on the ribbon. When you are happy with the tension, cut off the excess cord. Do this with the 2nd to 5th Digits (DO NOT tie the bottom knot in the cord for the Thumb/1st Digit).
Congratulations- you have now made a few AWESOME looking shrimps!! Note that the thumb’s cord does knot have a not at the bottom (see what I did there?).
Base and Thumb assembly
You will need:
  • 3D printed parts
  • Screw driver
  • The cut M4 SCREWS and NUTS
  • M3 x 25 CSK SCREWS [QTY 9]
  • M3 NUTS [QTY 19]
  • Tweezers
  • Insulation tape
  • Scissors
Take the M4 screws and put it through parts as indicated. The Captrap gets the longer one of the two.
Use the tweezers and screw driver to tighten the parts together. Make sure that the “Captrap” part is not tightened too much and that the thumb can freely pivot around the screw. Also ensure that the screw’s head sits flush on the inside so that it doesn’t interfere with the fingers later on (picture).
Pull the thumbs cord through the middle of the Captrap and Hamatum. I slid it through the crease from the top. Now tension the cord so that the thumb moves inward and tie yet another ‘stop knot’ in the cord. Cut off the excess cord if you are happy with the tension.
Now assemble the fingers to the base. Use the M3 x 25 CSK screws and nuts to fasten the fingers to the base. Slide the loose ribbon ends through the hoop at the back of the base.
We are almost done!
We will now make small make-shift handles to operate the fingers with.
Take a M3 x 25 CSK SCREW and 3 nuts. Fasten two nuts to the middle and one on the end as indicated. Cut small pieces of tape and wrap it around the two sides of the screw.
Tie the loose ribbon end to the screw in the middle. Wrap it around a few times at the length you wish to have it and tie a knot. I suggest you have a bit of 'rope' so that you can easily grab the little handles.Do this 5 times.
Step 7: Congratulate Yourself!
Congratulations! You have now officially built the baseline for a Bionic hand (applause and cheers!). You can now proceed to play with your new left hand (a sentence a think no one will ever want to hear again)! Pull on the little handles and make the individual fingers move. Pull on all 5 to open up the palm of the hand. You can see in the video that I attached the Model to a piece of wood. I screwed in some hooks just to keep the ribbons in tension so that I could take photos.
I have mentioned this, but keep in mind that I have done this project with the intent for further development, which I am busy with. This entire project cost me about R450, with the 3D printed parts at about R400. You can play around with the configurations of the ribbon and cord, you can attach servos and actuators, you can make design changes to have ball joints on the fingers - you can do ANYTHING you want - just have fun!
If you do something cool with it- Please feel free to let me know!
I hope you enjoy this project as much as I did!
Step 8: STL's
As requested- STL files! Please post pictures on here when you print the project. Would like to see it!
Woop Woop!
Design Now: In Motion Contest
Second Prize in the
5 People Made This Project!
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
  • Gardening Contest
    Gardening Contest
64 Discussions
Mazvydas
Question 8 months ago
I'm guessing any development is dead for this model? MP1 still missing from the stl list.
My issue is that most of the parts are not aligned to the printing base, I'd like to know how the author and others printed the parts? Tons of rafts? I'm having difficulties trying to properly align everything.
The hand looks amazing, but it seems weird to have the mounting and tensioning solution
just a block of wood. I'll try to create a proper 3D printed base with integrated tensioning, just seems like tensioning the hand was an afterthought.
HendoJMazvydas
Answer 8 months ago
Im concerned that you ask for MP1... Seeing as it is short for "Middle Phalanx (on digit) 1": which is the thumb....and the thumb does not have a middle phalanx.... Any way- your slicer should have some type of "autoplace" feature that aligns the models- to export every item from Fusion 360 in the correct orientation wouldve taken alot of time.NO it wasnt an after thought to tension it- i just had to improvise to test the concept in time for the competision. I have improved on the model and am using arduino to control it- I just havnt posted it here because of personal reasons. If you dont like the model- dont print it ;).
MazvydasHendoJ
Reply 7 months ago
I guess my comment reads offensively - I'm sorry about that, no bad intentions on my part. Yup, figured out S3D has a place surface on bed feature which is amazing, problem solved for orienting the pieces :) However I am curious about the base, would you mind sharing at least a picture of it?
HendoJMazvydas
Reply 7 months ago
Hi M
I do apologize for my previous reply. I will get a picture to send to you as soon I can and I really appreciate your interest in my Design.
Again- I am sorry for my snarkish reply :)
MazvydasHendoJ
Reply 7 months ago
Here's my first attempt at a base with tentioning. A few things to improve here and there, but overall I'm loving the look of this hand, great design.
HendoJMazvydas
Reply 18 days ago
This is AMAAZING!! (7 Months... how life passes us by XD)
You are inspiring me to get this project off the ice.
thank you!
MazvydasHendoJ
Reply 7 months ago
I love this design - I printed each piece one by one to maximize the quality of each part, that took 3 days. Assembled everything with screws, just need the long M4 screws for the base.. forgot about them.. After I have everything assembled properly I'll try to create a base with integrated tensioning and have it the same size as the bottom of the base, not sure I have enough skills for that yet, but hey, I'll give it a shot.
VibolY
3 months ago
Very great model. Thank you!
fischp
Question 11 months ago
Can you please post the MP1 file, it's not on the list of downloadable files. Great job btw!
Thanks
kcahill272
Question 1 year ago on Step 1
Hey, I really want to make your hand but I don't have premium. If by any chance could you send me the link or download of your hand so I can show it to my class. if not I totally understand, but I would really appreciate it. Thanks again.
K.C.
1 answer
HendoJkcahill272
Answer 1 year ago
Hi KC
It will be a pleasure to share this projects. Do you want me to send you the PDF and parts?
thanks for showing a interest and please send pics when you've finished it :)
PavLeMa
1 year ago
I have to tune up my crappy 3d printer. That means print part, change printer parameter, print again same (or similar) part. Stumbled upon this. Along with tuning eventually I'll get nice thing! So far I've printed only pinky. I've drilled 4 mm holes inside joints and 4.5 mm outside, and used 4 mm teflon tube for assembly (just because I have it).
So far I've noticed few imperfections: a) channels for elastic cord and ribbons have different width in different parts. Why? You easily can hide nice big channel inside smaller parts. b) MP5-PP5 joint should have smaller angle of rotation, now it jams ribbon if fully closed. c) MC5 and Hamatum stl files have weird model orientation (as in assembly file?) and inconvenient to print.
But anyway, you did a great job, thank you!
ндогонят
2 years ago
Voted! I love your writing style too, I'd vote a second time just for the LOLs.
When you're 3d printing, a nice clean way of filing and getting your surfaces is a solution of acetone on a rag. it gives a nice polish look immediately (or a melted style if you used pure acetone, did I mention a "solution"?). That works very well when you're working these contact surfaces.
About your design, how would you suggest to alter it so the angle between the phalanges bend to >120º instead of <90º? How would you implement lateral movement of the fingers (open hand) so the pinky can touch the index finger?
Now, to make it Steve Austin's hand, I need motors. What kind of force or torque would you need to animate it with no load (considering all the elastic bands would be attached to pulleys to null the effect of the tension on the motors themselves)?
HendoJндогонят
Reply 2 years ago
Haha Thanks! I heard of that "solution" and will definitely use it as an alternative. Much less of a 'grind' anyway.
The bit of research that I have done so far (I only started this project on the 11th of april) showed that only the PIP joints have a motion of about 110º. I mostly sat and stared at my own hands for hours. I was also a bit skeptic on how the fingers will rotate with the strings/cord and hence I decided to make my angles for THIS BASELINE a bit smaller just to test the concept.
I'm looking to simulate the lateral movement of the MCP joints with a type of ball and socket (with limited range of motion).
I am conducting a "fail" test on this PLA model soon to test the loads the pins can handle (Just to establish a baseline) to spec actuators and converters. (Hope that makes sence???)
In short- As soon as I can acquire a printer of my own (The cost will be to high to outsource print jobs every time)- i can proceed with a collection of improvements and alterations. I am doing all the R&D to make this project as close to the human hand (and arm soon to come) as possible. For fun.
Thanks for the vote (And the metaphorical one! :)
dennzt.HendoJ
Reply 1 year ago
This is great. Funny enough, this is more or less what I was trying to model but I have no design or modeling skills at the moment lol. Can put the idea on paper and try to build mock ups by hand with everyday materials, but hit a wall when I try to bring that into CAD. I'd be glad to print some parts for you for free.
gupperino
1 year ago
I really love the skeletal design you chose. It's quite haunting actually, as it looks like something out of The Terminator. I'm an engineer and would love to turn this design into a prosthesis application for working class amputees who cannot afford expensive robotic hands. I have a few existing designs and I'd love to share them with you and maybe collaborate on a few modifications to the existing design to make it more applicable as a medical tool! Let me know if you would be interested, and if not, am I allowed to use your design for non-profit research purposes?
HendoJgupperino
Reply 1 year ago
Hi G. I guess we have the same interests for this project. I would like to share ideas with you! This design is in my honest opinion "Not done yet" and I definitely intend to improve on it. Currently (In the extremely few free minutes I have) diving into programming servos to control the hand. You are more than welcome to use this design for which ever purpose - as long as you share your progress with me so that i can see "What my baby has become" :).
gupperinoHendoJ
Reply 1 year ago
Sounds good! Thanks for the reply!
NadineS44
2 years ago
This design is pretty handy! I can't wait to see what you do next. Your nicknames for every part that you have designed and printed plus the way you write, makes this instrucable user friendly and fun. I really enjoyed this instructable ?
