3D Printed Fishing Pole Holder
328
About: GRiP designs and manufactures 3D printed assistive devices for children and adults with upper limb differences all throughout the nation.
Follow these instructions well to make a 3-D Printed Fishing Pole Holder.
Step 1: Take Measurements
Measure the diameter of the base of the fishing pole.
Measure the length of the persons forearm (for the cuff).
Step 2: Open Parts File
Change dimensions as needed.
Save the new file as an STL.
Step 3: Print the Two Pieces
Using a 3-D printer, print each piece of the fishing pole holder.
Step 4: Thermoforming
Using a heat-gun or water, thermoform the cuff to desired shape.
Using a heat-gun or water, thermoform the z-piece around fishing pole securing it in place. Pay special attention to ensure that the holes on the z-piece align with the holes on the base of the cuff. Feel free to use screws, pins, or anything else to keep the two pieces aligned.
Step 5: Assembly
Place fishing rod in the basin on the cuff.
Cover the rod with the z-piece and secure it in place with screws.
If rod is not tightly secured, drill a screw through the bottom of the rod through the base of the cuff.
Put padding on the inside of the cuff, as to not cause any irritation to the skin.
Loop velcro through the cuff to be used to secure the cuff to the arm.
Step 6: FISH
Go fish.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    2 Discussions
    Jobar007
    2 years ago
    I'm going to parrot what tomatoskins said that ask for that STL as well. This is a great idea that would help people with low grip strength get into (or back into) fishing.
    tomatoskins
    2 years ago
    I'd love to see your print file so I could look into making my own!
