3D Printed Gadgets for Woodworking
8,607
277
42
This is a collection of simple 3D printed gadgets for my woodworking workshop. All where designed in Autodesk Fusion 360, and I have included the stl files so you can print your own. The designs are pretty simple, so it should not be difficult for you to modify any of the parts.
Step 1: Clamping Brackets for Mitered Corners
The brackets are used to clamp mitered joints like picture frames and boxes. The miter angle does not need to be 45 degrees. When 3D printing use 50% or more infill for strength. Glue 80 or 100 grit sandpaper to the flat inside surface to prevent the bracket from slipping during use. The pictures show how the clamp brackets are used.
Step 2: Knobs
Make threaded knobs and handles for fixtures and jigs. The interior threads are 1/4-20 and 5/16-18. Thread in a hex bolt and super-glue in place.
Step 3: Rounded Corner Layout Templates
These templates allow you to mark rounded corners for 1/2", 3/4", 1", and 1.5" corner radii. Hook the template over the corner and mark with a sharp pencil. Then saw and sand to the line.
Step 4: Mortise Layout Templates
These templates are useful for laying out mortises on your stock for routing, chiseling, or a mortising machine. Draw the centerline of the mortise across the stock, line up the template, and mark it with pencil or marking knife. Templates are included for 1/4", 3/8", and 1/2" mortises for 3/4" stock.
Step 5: Temporary Corner Brackets
They provide extra 'hands' during the assembly of your workpieces. Useful for alignment during glueing, clamping, assembly with screws, etc. Use on corners or for T-joints. Sized for 3/4" stock.
Step 6: Angle Gauge
Set your saw blade to exact tilt or miter angles. 30, 60, 90 degrees. Design your own for other angles.
Step 7: Height or Cutting Depth Gauge
Easily set the height (cutting depth) of your table saw blade or dado blade for creating grooves, rabbets, or dados. The gauge includes 1/16", 1/8", 3/16", and 1/4" settings. 3D print standing on edge - no supports needed.
Step 8: Miter Slot Bars
These fit into miter slots on you table saw, band saw, router table, or sander. Use as stop, or attach to jig/fence/sled. Modify to fit your saw/sander/router table.
Step 9: Band Saw Insert
Replace a worn band saw insert. The file is for my Grizzly G0555 bandsaw. You may have to tweak the dimension to fit your bandsaw. Omit the center slot to make it a zero-clearance insert.
Step 10: Magswitch Jigs
Make your own Magswitch jigs. Shown is a featherboard using the commercially available Magswitch magnets (MAGJIG 95). You can design other jigs and reuse the same Magswitch magnets as needed.
Step 11: Dust Collector Adaptors
Make your own adaptors and fittings for dust collection systems and shop vacuums. The second picture shows a belt sander to shop vac adaptor. Use blue painters tape when you don't get the fit quite right! The dimensions are very specific to your machinery, so you'll have to design your own. I use a 2.4 mm wall thickness, 0.2mm layer height, 3 top/bottom layers, 3 outside/perimeter shells, and 35% infill where needed.
Step 12: Center Marker
Use this simple gadget with 8d nails to mark the centerline of a board.
Step 13: More ...
More gadgets to come. Feel free to improve the designs or add your own ideas. Share what you create!
Epilog X Contest
Runner Up in the
Epilog X Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    42 Discussions
    steegs8319
    19 days ago
    Love these ideas, now I need a printer!
    Some suggestions for the next post- a Dowelling joint jig, & a pocket hole jig?
    rschoenmsteegs8319
    Reply 19 days ago
    Thanks for the suggestions. I have a doweling (mortising) jig designed, printed, and tested for my next Instructable; to be published before too long. Not sure about the pocket hole jig; I haven't used pocket holes so I haven't thought about it. Working on a bunch of clamping aids.
    Any further suggestions are welcome.
    youngrh
    Question 24 days ago
    I decided to post this again as a question in case Instructables handles questions differently than comments.Thank you for these! I would like to make several of these. But being relatively new to Fusion 360, I do not know how to 'inspect' the wire frame drawings for dimensions. My question is what size 3d printer do I need and do you have a recommendation for a particular 3d printer to consider?
    rschoenmyoungrh
    Answer 23 days ago
    The largest thing on the list is the featherboard, about 7.5 inches by 3.5 inches. The tallest gadget would be one of the vacuum hose adaptors, about 2.5 inches tall and 2 inches diameter. All stl files are in millimeter units.
    After importing a mesh (stl file) into Fusion 360 (“Insert > Insert Mesh”), use the “Inspect > Measure” menu item and click on different nodes of the mesh to get distances and angles.
    If you just want to 3d-print the stl file use the free Autodesk Print Studio program to process the file for your specific 3d printer. Again, import stl files with mm units.
    To modify any files you would need the original Fusion 360 files. If you have a specific gadget in mind I could send you the file. Many of the designs are simple enough for you to recreate quickly and learn Fusion 360 in the process.
    Regarding recommendations for specific 3d printers, I don’t have experience with many available systems. I am using an older Dremel 3d20 Idea Builder. It has worked well and reliably for me. Search the internet for current recommendations.
    youngrhrschoenm
    Reply 23 days ago
    Thank you so much, Sir! Exactly the kind of response I was hoping for, and then some!! I look forward to learning something new while making a few very useful things for my woodworking. Looks like the Tevo Tornado may fit the bill but I will be researching some more before buying. Thanks again and my best wishes to you in your endeavors.
    vistamachine
    4 weeks ago
    I love these. You are making good use of your printer. Can't wait for your next post.
    youngrh
    26 days ago
    Philbert D
    4 weeks ago
    Excellent, practical collection. Allows me to justify both melting plastic and creating sawdust at the same time. I've purchased several of these items over the years and this will allow me to expand my collection of them for much less money while having much more fun. Thanks.
    BonJiba
    Question 4 weeks ago on Step 5
    Great design on the temporary corner brackets. I also use Fusion 360 and would like to modify them for 1/2" width material. Could you also please post the .f3d fusion files. Thanks...
    TheMainMan
    4 weeks ago
    Love these gadgets! And it introduced me to Magswitch so I've now got something to get my father-in-law for his birthday!
    What is the notch for in the rounded corner templates?
    rschoenmTheMainMan
    Reply 4 weeks ago
    Thanks. The Magswitch magnets are really useful to me.
    The notch in the rounded corner templates indicates a 45 degree line from the corner. It's really not that useful, so feel free to ignore it.
    JohnI7
    4 weeks ago
    What a fantastic collection of useful gadget!I might download some.
    A good collection for learning to use the 3d printer for more practical gadgets. Thanks for posting.
    DraganS7
    4 weeks ago
    These are great tools for the job! I just have one minor objection - the upper part of the knobs will be much sturdier if the top side is shaped so that the nut comes into the hex tray. Sometimes, a glue isn't strong enough for fastening, I think.
    rschoenmDraganS7
    Reply 4 weeks ago
    Thanks for the suggestion. The interior holes of the knobs are threaded and I put some glue/epoxy on the threads as well. If you take the threads out and make a hex shaped recess then your suggestion will work very well.
    TheNottingHammer
    4 weeks ago
    Brilliant, and in the tradition of woodworkers making the tools that they needed. I don't have access to a 3D printer, but when I do...
