3D Printed Hinges
12,223
71
4
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author ...
I designed some hinges which can be printed out on UV-curing printers. This was partially to figure out how to make compound parts using an Objet printer and partially to figure out the various tolerances. I found that I can scale the hinges down to have roughly a 10mm height. At this size they will work with even a 0.25mm gap between the pin and the hinge. Although, it is preferable to have a 0.5mm gap. These hinges can be scaled up and scaled down as needed, and consists of three parts. The only difference between each set of hinges is the diameter of the center pin. Hopefully these files will prove useful to someone.
Update: The files that start with 5 and 7 are better and beefier hinges. They have 5 and 7 rungs respectively.
Supplies:
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    4 Discussions
    DivyanshuC
    3 years ago
    Awesome Stuff! Why don't you post these over http://sinter3d.com and get them 3D printed by top 3D printers. Sinter3D is a cool new 3D printing & makers freelancing projects platform. Built exclusively for the #3DPrinting Community! You can search for and apply as designer too.
    If you plan to use them on a small scale, they will need some redesigning. The joint between the rungs and the plate is weak and it kept snapping when I attached it to an actual object. I fixed this by making that joint thicker and the plate thicker. I also widened the rungs a little, but I am not sure that necessary. I'll be posting the project shortly with the better hinges. Maybe I'll upload the hinges to here as well.
